回复: 4
用MSP430F149驱动不带中文字库12864液晶显示时钟
发表于 2011-9-22 11:56:32 | 显示全部楼层 |阅读模式
菜鸟做的一个用MSP430F149驱动不带中文字库12864液晶显示时钟程序。分别显示时、分、秒、毫秒。不过现在只能做秒表用用还行。用按键来调时间还没有做进去。呵呵
   主函数里的程序  main.c
#include "io430.h"
#include "lcd.h"
#include "delay.h"
int main( void )
  WDTCTL = WDTPW + WDTHOLD;
   InitClock();            //初始化系统时钟
   P4DIR=0xff;            // 初始化IO
   P4OUT=0xff;
   P1DIR=0xff;
   P1OUT=0xff;
   P2DIR=0XFF;
   P2OUT=0XFB;
   RW=0;                  //LCD设置为写数据状态
   RST=0;                 //LCD复位
   delay_50ms(1);
   RST=1;                 //LCD复位结束
   Init_LCD();            //初始化液晶显示器
   Initialization();      //初始化函数
   CleanScreen(0X00);     //清屏
uchar h1=0,h=0,t1=0,t=0,s1=0,s=0,ms1=0,ms=0,q=2;
    { Shi_jian(3,4, h1,h,t1,t,s1,s,ms);     //显示时、分、秒、毫秒
    if(h1==q)
      { h=0;q=16; }
       else if(q/h==4)
        { h1=0;h=0;t1=0;t=0;s1=0;s=0; }
         else if(h==10)
          { h=0;h1++; }
           else if(t1==6)
            { t1=0; h++; }
             else if(t==10)
              {  t=0;t1++; }
               else if(s1==6)
                { s1=0;t++; }
                 else if(s==10)
                  {  s=0;s1++; }
              //    else if(ms1==10)
                //   {  ms1=0; s++; }
                    else if(ms==10)
                     {  ms=0;s++; }
                      else if(ms<=9)
                       { delay_50ms(1362);  ms++; }       //延时1362为1秒
子函数、被调用函数程序 LCD.C
#include "io430.h"
#include "lcd.h"
#include "delay.h"
#define Character_array         43        //字符数组的长度为43个
#define Chinese_character         68+6+4        //汉字数组的长度为78
//字符点阵数据结构
typedef const  struct
         const signed char hanz;
         const signed char code[16];
}Character;
//汉字点阵数据结构
         const unsigned char hanzi[2];       //汉字
         const unsigned char code[32];      //代码
}hanzi;
结构字符数组库、由hanzi类型定义的ChineseCharacter数组库
Character  shuzi[Character_array]=
        {'0',  {0x00,0xF8,0xFC,0x04,0x04,0x04,0xFC,0xF8,0x00,0x1F,0x3F,0x20,0x20,0x20,0x3F,0x1F}},
        //0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00
        {'1',  {0x00,0x00,0x30,0x18,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x00,0x00}},
        //0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00
        {'2',  {0x00,0x18,0x1C,0x04,0x84,0x84,0xFC,0x78,0x00,0x3E,0x3F,0x21,0x21,0x20,0x20,0x20}},
        //0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00
        {'3',  {0x00,0x08,0x0C,0x44,0x44,0x44,0xFC,0xB8,0x00,0x10,0x30,0x20,0x20,0x20,0x3F,0x1F}},
        //0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00
        {'4',  {0x00,0x80,0xC0,0x60,0x30,0xF8,0xFC,0x00,0x00,0x03,0x03,0x02,0x02,0x3F,0x3F,0x02}},
        //0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00
        {'5',  {0x00,0xFC,0xFC,0x44,0x44,0x44,0xC4,0x80,0x00,0x10,0x30,0x20,0x20,0x20,0x3F,0x1F}},
        //0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00
        {'6',  {0x00,0xF8,0xFC,0x44,0x44,0x44,0xCC,0x88,0x00,0x1F,0x3F,0x20,0x20,0x20,0x3F,0x1F}},
        //0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00
        {'7',  {0x00,0x04,0x04,0x04,0x84,0xE4,0x7C,0x1C,0x00,0x00,0x00,0x3E,0x3F,0x01,0x00,0x00}},
        //0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00
        {'8',  {0x00,0xB8,0xFC,0x44,0x44,0x44,0xFC,0xB8,0x00,0x1F,0x3F,0x20,0x20,0x20,0x3F,0x1F}},
        //0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00
        {'9',  {0x00,0xF8,0xFC,0x04,0x04,0x04,0xFC,0xF8,0x00,0x10,0x31,0x21,0x21,0x21,0x3F,0x1F}},
        //0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00
        //10
        {'A',  {0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20}},
        {'B',  {0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00}},
        {'C',  {0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00}},
        {'D',  {0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00}},
        {'E',  {0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00}},
        {'F',  {0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00}},
        {'G',  {0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00}},
        {'H',  {0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20}},
        {'I',  {0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00}},
        {'J',  {0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00}},
        //20
        {'K',  {0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00}},
        {'L',  {0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00}},
        {'M',  {0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00}},
        {'N',  {0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00}},
        {'O',  {0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00}},
        {'P',  {0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00}},
        {'Q',  {0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00}},
        {'R',  {0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20}},
        {'S',  {0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00}},
        {'T',  {0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00}},
        //30
        {'U',  {0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00}},
        {'V',  {0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00}},
        {'W',  {0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00}},
        {'X',  {0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20}},
        {'Y',  {0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00}},
        {'Z',  {0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00}},
        {'?',  {0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00}},
        //{' ',  {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}},
        {':',  {0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00}},
        {'<',  {0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00}},
        //40
        {'-',  {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01}},
        {'>',  {0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00}},
        {'+',  {0x00,0x00,0x00,0x40,0x20,0x10,0x08,0x04,0x00,0x00,0x00,0x02,0x04,0x08,0x10,0x20}},
        {'_',{0xE2,0x04,0x08,0x10,0x20,0x40,0x00,0x00,0x47,0x20,0x10,0x08,0x04,0x02,0x00,0x00}}
        //44
汉字库结构数组、由hanzi类型定义的ChineseCharacter数组库
hanzi zi[Chinese_character]=
  {"有", {0x80,0x40,0x20,0xF8,0x87,0x80,0x84,0x84,
      0x84,0xFC,0x84,0x82,0x82,0xC0,0x80,0x00,
      0x00,0x00,0x00,0xFF,0x00,0x20,0x20,0x20,
      0x20,0x3F,0x20,0x20,0x30,0x20,0x00,0x00,}},
    {"计",{ 0x84,0x14,0x24,0x64,0x0F,0x14,0x14,0x94,
      0x54,0x34,0x1F,0x14,0x04,0x86,0x04,0x00,
      0x08,0x09,0xFC,0x02,0x40,0x21,0x19,0x47,
      0x21,0x19,0x47,0x81,0x41,0x3F,0x01,0x00}}
uint sz[11][16]=
        {0x00,0xF8,0xFC,0x04,0x04,0x04,0xFC,0xF8,0x00,0x1F,0x3F,0x20,0x20,0x20,0x3F,0x1F},
        {0x00,0x00,0x30,0x18,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x00,0x00},
        {0x00,0x18,0x1C,0x04,0x84,0x84,0xFC,0x78,0x00,0x3E,0x3F,0x21,0x21,0x20,0x20,0x20},
        {0x00,0x08,0x0C,0x44,0x44,0x44,0xFC,0xB8,0x00,0x10,0x30,0x20,0x20,0x20,0x3F,0x1F},
        {0x00,0x80,0xC0,0x60,0x30,0xF8,0xFC,0x00,0x00,0x03,0x03,0x02,0x02,0x3F,0x3F,0x02},
        {0x00,0xFC,0xFC,0x44,0x44,0x44,0xC4,0x80,0x00,0x10,0x30,0x20,0x20,0x20,0x3F,0x1F},
        {0x00,0xF8,0xFC,0x44,0x44,0x44,0xCC,0x88,0x00,0x1F,0x3F,0x20,0x20,0x20,0x3F,0x1F},
        {0x00,0x04,0x04,0x04,0x84,0xE4,0x7C,0x1C,0x00,0x00,0x00,0x3E,0x3F,0x01,0x00,0x00},
        {0x00,0xB8,0xFC,0x44,0x44,0x44,0xFC,0xB8,0x00,0x1F,0x3F,0x20,0x20,0x20,0x3F,0x1F},
        {0x00,0xF8,0xFC,0x04,0x04,0x04,0xFC,0xF8,0x00,0x10,0x31,0x21,0x21,0x21,0x3F,0x1F},
        {0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00}     //:
void Instruction(uchar data)    //写指令函数
  RS=0;
  delay_50us(1);
    E=1;
  LCD_DATAOUT=data;                       //把数据准备好
  delay_50us(8);
  E=0;
  delay_50us(2);
void Data(uchar data)      //写数据函数
  RS=1;
  delay_50us(1);
   E=1;
  LCD_DATAOUT=data;
  delay_50us(8);
  E=0;
  delay_50us(2);
void CleanScreen(unsigned char data)    //清屏
        unsigned char i=0,page=0;
        for(page=0;page<8;page++)
                CSA=0;
                CSB=0;
                Instruction(0xB8|page);  //设置DDRAM地址(显示位置)、第一行:80H--87H、第二行:90H--97H
                Instruction(0x40);      //设置CGRAM地址(自定义字形)
                for(i=0;i<64;i++)
                        Data(data);  //设一个DDRAM地址送64次数据
void Initialization(void)               //液晶初始化 上电等待40MS RST复位由低电平变成高电平,
   delay_50ms(2);
   Instruction(0x30);          //功能设置
   delay_50ms(4);
   delay_50ms(4);
   Instruction(0x0f);         //显示开关控制,D必须打开,否则屏幕什么都没有
   delay_50ms(4);
   Instruction(0x01);         //清屏,清除显示
   delay_50ms(240);
   Instruction(0x06);         //进入模式设置
   delay_50ms(10);
void InitClock(void)    //初始化系统时钟
           //#define  SMCLK   0x10              //SMCLK Single output    _ZHENG
           //#define  MCLK    0x10              //MCLK Single output     _ZHENG
                                        //attach HF crystal (1.8432MHz) to XIN/XOUT
           //BCSCTL1=DIVA1+DIVA0+XTS+XT2OFF;        //ACLK 8分频(460.8KHz),XT2IN关闭,XTIN接外部晶振1.8432MHz
           BCSCTL1=XTS+XT2OFF;
          do
                     IFG1&=~OFIFG;                //清除振荡器失效标志 、wait in loop until crystal is stable
             }while(OFIFG&IFG1);            //判断XT2是否起振
           //P2DIR|=ACLK;                           //ACLK 四分频(460.8KHz),通过P2.0口输出,作为MODEM的输入时钟
           IFG1&=~OFIFG;                   //Reset osc. fault flag again
           BCSCTL2=SELM0+SELM1;        //and MCLK = 1.8432MHz)
                                           //USE MCLK AS INPUT CLOCK
                                        //wait in loop until crystal is stable
           do
                     IFG1&=~OFIFG;
             }while(OFIFG&IFG1);                //wait in loop until crystal is stable
void Init_LCD(void)    //初始化液晶显示器
        CSA=0;
        CSB=0;
        Instruction(0x3F);  //功能设定、8位数据端口、扩充指令操作
        Instruction(0xC0);  //设置绘图RAM地址、先设置垂直(列)、再设水平(行)、将16位连续写入即可
显示函数、X为显示的列坐标、Y为显示的行坐标(显示在屏幕的位置)
void Show(unsigned char x,unsigned char y, unsigned char *code)
      while(*code!='\0')            //判断代码指针不为数组代码的结束标语
                  if(*code<0x80)//ascII码,机内码是小于128的
                  Show_Character(x,y,code);   //显示字符
                        x++;
                        code++;
                else if(*code>0xB0)// 汉字是GB2312码。大于176的
                        Show_hanzi(x,y,code);     //显示汉字
                        x=x+2;
                        code=code+2;
显示字符函数、X为显示的列坐标、Y为显示的行坐标(显示在屏幕的位置)
void Show_Character(unsigned char x,unsigned char y, unsigned char *code)
          unsigned char length=0,j=0;
        unsigned char page=0,col=0;
        Character * number;    //定义字符结构指针number变量
        number=shuzi;    //将结构字符数组库的地址number指针变量
        for(length=0;Character_array;length++)
                if(*code==number->hanz) //结构体hanz成员与*code指针是否相等
                        for(page=0;page<2;page++)
                                  col=x*8;
                                  if(col<64)//左屏
                                        CSA=0;
                                        CSB=1;
                                else//右屏
                                        CSA=1;
                                        CSB=0;
                                        col=col-64;
                                Instruction(0xB8|page|y);        //显示的行,它是16*16的,显示时分二行如果为单数只显示一半
                                Instruction(0x40|col);       //显示的列
                                for(j=0;j<8;j++)
                                        Data(number->code[j+8*page]);   //将数据(汉字)写入
                        }break;
                number++;
显示汉字函数、X为显示的列坐标、Y为显示的行坐标(显示在屏幕的位置)
void Show_hanzi(unsigned char x,unsigned char y, unsigned char *code)
          unsigned char length=0,j=0,h=0;
        hanzi * hz;
        hz=zi;
        for(length=0;length<Chinese_character;length++)
                if((* code==hz->hanzi[0])&&(*(code+1)==hz->hanzi[1]))//汉字内码
                        for(page=0;page<2;page++)//上下2页
                                  for(h=0;h<2;h++)//左右半汉字
                                          col=x*8+h*8;
                                          if(col<64)//左屏
                                        CSA=0;
                                        CSB=1;
                                        else//右屏
                                        CSA=1;
                                        CSB=0;
                                        col=col-64;
                                        for(j=0;j<8;j++)
                                                Data(hz->code[j+h*8+page*16]);
                        }break;
                hz++;
                          显示时、分、秒、毫秒
void Shi_jian(uchar x,uchar y,uchar shi1,uchar shi,uchar fen1,uchar fen,uchar miao1,uchar miao,uchar mmiao)
      uchar length=0,j=0,h=0;
      uchar page=0,col=0,t,d=0,m,n=10;
    for(m=0;m<10;m++)
      if(d==0)
      {t=shi1; d++;}
      else if(d==1)
       { t=shi;x++;y+2;d++;}
        else if(d==2)
         { t=n;x++;y+2;d++;}
          else if(d==3)
           { t=fen1;x++;y+2;d++;}
            else if(d==4)
             { t=fen;x++;y+2;d++;}
              else if(d==5)
               { t=n;x++;y+2;d++;}
                else if(d==6)
                 { t=miao1;x++;y+2;d++;}
                  else if(d==7)
                   { t=miao;x++;y+2;d++;}
                   else if(d==8)
                    { t=n;x++;y+2;d++;}
                //    else if(d==9)
             //        { t=mmiao1;x++;y+2;d++;}
                      else if(d==9)
                       { t=mmiao;x++;y+2;d++;}
                                  col=x*8;
                                  if(col<64)//左屏
                                        CSA=0;
                                        CSB=1;
                                else//右屏
                                        CSA=1;
                                        CSB=0;
                                        col=col-64;
                                for(j=0;j<8;j++)
                                  Data(sz[t][j+8*page]);   //将数据(汉字)写入
延时函数  delay.c
#include "io430.h"
#include "lcd.h"
延时函数,在12MHZ的晶振频率下
大约50US的延时
void delay_50us(uint t)
  uchar j ;
   for(;t>0;t--)
     for(j=19;j>0;j--);
延时函数,在12MHZ的晶振频率下
大约50US的延时
void delay_50ms(uint t)
  uchar j ;
   for(;t>0;t--)
     for(j=6245;j>0;j--);
呵呵、菜鸟献丑了,不足之处还望高手多多指点、
程序打包
MSP430F149驱动不带中文字库12864液晶显示时钟ourdev_678553VUNGNT.rar(文件大小:330K) (原文件名:lcd1.rar)
发表于 2011-9-28 10:50:50 | 显示全部楼层
不错,要做到精准是件难事。
发表于 2011-10-13 17:34:17 | 显示全部楼层
想请教一下,如果你的12864是电源电压为5v的,其引脚可以和430直接相连吗?能把你的电路图发上来看看吗?
发表于 2011-12-8 09:18:57 | 显示全部楼层
回复【楼主位】fanhuamin1988
我本想用msp430驱动一块12864液晶,能够使它计时也能显示字幕。谢谢楼主,为我减轻了不少负担!!!
 楼主| 发表于 2011-12-14 16:14:23 | 显示全部楼层
回复【2楼】swordman000
430引脚是3.3V的。这个我也没有试过。怕是不行的吧!电路我是参照这个设计的。自己画的找不到了你可以参考一下
(原文件名:5552E2}CW7Z(%0FB@J[%VSH.jpg)
其背光可以用三极管控制
GMT+8, 2024-7-28 10:26
