Altera.Complete.Design.Suite.v11.0.SP1-SPYRAL光盘里的cra_ck部分
Run the application setup, select the (Paid) edition of Quartus II and/or ModelSim-Altera.
Wait for it, or take a lunch break...
When asked for a license, cancel the dialog box.
Unzip the cra_ck into the install dir e.g. \altera\11.0sp1\ and overwrite folders/files.
Run the LicenseMaker.exe from the install dir with administrator privilege.
It will create a license.dat and set the required system environment variables
LM_LICENSE_FILE and MGLS_LICENSE_FILE which point to the location of the license.dat
Launch the program.
点击此处下载 ourdev_676358X5NM90.zip(文件大小:2.99M) (原文件名:cra_ck.zip)
点击此处下载 ourdev_676359K5I53T.txt(文件大小:822字节) (原文件名:instructions.txt)
When asked for the license, select the option to specify valid license file,
and "Use LM_LICENSE_FILE variable" (or browse to the license.dat)
You can do the same procedure (or verify the license status) from the program
by going to the "Tools", "License Setup".
Enjoy. |
