如下程序没有问题,显示12345678
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity scan8led is
port(clk:in std_logic;
led_adder:out std_logic_vector(7 downto 0);
seg7_data:out std_logic_vector(6 downto 0));
end entity;
architecture wen of scan8led is
signal data_temp:std_logic_vector(7 downto 0):="11111110";
signal clk1:std_logic;
begin
process(clk)
variable Q:std_logic_vector(16 downto 0);
begin
if clk'event and clk='1' then
if(Q="11000011010100000") then
Q:="00000000000000000";
else Q:=Q+1;
end if;
end if;
clk1<=Q(16);
end process;
process(clk1,data_contral)is
variable c: integer range 1 to 8 :=1;
begin
if(clk1'event and clk1='1')then
led_adder<=data_temp;
data_temp<=data_temp(6 downto 0)&data_temp(7);
case c is
when 1=>seg7_data<="1111001";
when 2=>seg7_data<="0100100";
when 3=>seg7_data<="0110000";
when 4=>seg7_data<="0011001";
when 5=>seg7_data<="0010010";
when 6=>seg7_data<="0000010";
when 7=>seg7_data<="1111000";
when 8=>seg7_data<="0000000";
end case;
c:=c+1;
if(c=9)then
c:=1;
end if;
end if;
end process;
end architecture wen;
但做如下修改后本想显示三位动态扫描,结果位码就乱了,数码不能在固定的位显示,三个位轮流跑,而且会出现一个没有设置过的码夹杂在中间,请高手看看怎么回事情?
library ieee;
entity scan3led is
led_adder:out std_logic_vector(2 downto 0);
end entity;
architecture wen of scan3led is
signal data_temp:std_logic_vector(2 downto 0):="110";
begin
process(clk)
begin
else Q:=Q+1;
end if;
end if;
clk1<=Q(16);
end process;
variable c: integer range 1 to 3 :=1;
begin
data_temp<=data_temp(1 downto 0)&data_temp(2);
case c is
end case;
c:=c+1;
if(c=4)then
c:=1;
end if;
end if;
end process;
end architecture wen; |
