我在学习2440+WinCE5.0系统,正在看中断相关的。
在文件2440init.s里找到如下代码
AREA Init,CODE,READONLY
ENTRY
;1)The code, which converts to Big-endian, should be in little endian code.
;2)The following little endian code will be compiled in Big-Endian mode.
; The code byte order should be changed as the memory bus width.
;3)The pseudo instruction,DCD can't be used here because the linker generates error.
ASSERT :DEF:ENDIAN_CHANGE
b ResetHandler ; 0x00 Reset
b . ; 0x04 Undefined
b . ; 0x08 Supervisor
b . ; 0x0c Prefetch Abort
b . ; 0x10 Data Abort
b . ; 0x14 Reserved
b . ; 0x18 IRQ
b . ; 0x1c FIQ
地址0x04-0x1C均无有效跳转代码,是否意味着这些异常没有使用?但是在后面又看到如下些代码,很疑惑。上面那段代码存在flash里而下面这段是在RAM里?请知道的朋友讲解一下。
AREA RamData, DATA, READWRITE
^ _ISR_STARTADDRESS
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4 |
