U1733C 100Hz/120Hz/1kHz/10kHz/100kHz Handheld LCR Meter
http://www.home.agilent.com/agilent/product.jspx?nid=-34196.980702.00&lc=chi&cc=CN
(原文件名:a.JPG)
主要特性与技术指标
20,000 counts resolution
0.2% accuracy
Wide LCR ranges with 5 selectable test frequencies (100Hz, 120Hz and 1kHz, 10kHz and 100kHz)
Auto identification(Ai) which automatically determines and displays component type and measurements
Detailed component analysis with DCR, ESR, Z, D, Q, Ө functions
Battery life of 16 hours/Ac-powered
IR-to-USB connectivity for data logging to PC
描述
Now you can measure at frequencies as high as 100 kHz, a capability that is typically found only in benchtop meters. With the auto identification, Ai which conveniently displays component type and detailed component analysis such as Z, ESR, DCR, you can get measurements done faster. Better yet, the battery lasts up to 16 hours, ideal for testing on the go. With the U1730 Series, you can perform quick, basic LCR measurements at your convenience, without burning a hole in your pocket. |
