#include <reg52.h> // 引用标准库的头文件
#include <absacc.h>
#include <stdio.h>
#define uint unsigned int
#define REG00 XBYTE[0x8000] // 端口300H,命令寄存器CR
#define REG01 XBYTE[0x8100] // 端口301H
#define REG02 XBYTE[0x8200] // 端口302H
#define REG03 XBYTE[0x8300] // 端口303H
#define REG04 XBYTE[0x8400] // 端口304H
#define REG05 XBYTE[0x8500] // 端口305H
#define REG06 XBYTE[0x8600] // 端口306H
#define REG07 XBYTE[0x8700] // 端口307H
#define REG08 XBYTE[0x8800] // 端口308H
#define REG09 XBYTE[0x8900] // 端口309H
#define REG0a XBYTE[0x8a00] // 端口30aH
#define REG0b XBYTE[0x8b00] // 端口30bH
#define REG0c XBYTE[0x8c00] // 端口30cH
#define REG0d XBYTE[0x8d00] // 端口30dH
#define REG0e XBYTE[0x8e00] // 端口30eH
#define REG0f XBYTE[0x8f00] // 端口30fH
#define REG10 XBYTE[0x9000] // 端口310H
#define REG11 XBYTE[0x9100] // 端口311H
#define REG12 XBYTE[0x9200] // 端口312H
#define REG13 XBYTE[0x9300] // 端口313H
#define REG14 XBYTE[0x9400] // 端口314H
#define REG15 XBYTE[0x9500] // 端口315H
#define REG16 XBYTE[0x9600] // 端口316H
#define REG17 XBYTE[0x9700] // 端口317H
#define REG18 XBYTE[0x9800] // 端口318H
#define REG19 XBYTE[0x9900] // 端口319H
#define REG1a XBYTE[0x9a00] // 端口31aH
#define REG1b XBYTE[0x9b00] // 端口31bH
#define REG1c XBYTE[0x9c00] // 端口31cH
#define REG1d XBYTE[0x9d00] // 端口31dH
#define REG1e XBYTE[0x9e00] // 端口31eH
#define REG1f XBYTE[0x9f00] // 端口31fH
void delay(uint t);
void NICRst();
void SelectPage(uchar pagenum);
void ClearISR();
void setmac();
void RTL8019Init();
void sentdata(struct packet *mypk );
receivedata(char *dat);
#include "Ethernet.h"
/* 主函数 */
sbit k=P1^6;
sbit k2=P1^5;
struct ethhead {
unsigned char destmac[6];
unsigned char sourcemac[6];
unsigned int nextprot;
}myeth;
struct arppk{
unsigned int hardware;
unsigned int prottype;
unsigned char hardlen;
unsigned char protlen;
unsigned int operation;
unsigned char sendermac[6];
unsigned char senderip[4];
unsigned char targetmac[6];
unsigned char targetip[4];
}myarp;
struct packet{
unsigned char *dat;
unsigned int len;
struct packet *nextpk;
} ethpacket,arppacket={0};
unsigned char code str[60]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x27,0x27,0x27,0x27,0x27,0x27, 0x08,0x06//, 0x00,0x01,
//0x08,0x00, 0x06, 0x04, 0x00,0x01, 0x27,0x27,0x27,0x27,0x27,0x27, 0xAC,0x10,0x2A,0xFD,
//0x00,0x00,0x00,0x00,0x00,0x00, 0xAC,0x10,0x2A,0xFE
unsigned char mymac[6]={0x27,0x27,0x27,0x27,0x27,0x27};
unsigned char myip[4]={0xC0,0xA8,0x01,0x66};
unsigned char destip[4]={0xC0,0xA8,0x01,0x65};
unsigned char rec[512];
unsigned int reclen;
init()
TMOD=0x20;
PCON=0x00;
SCON=0x50;
TH1=0xfd;
TL1=0xfd;
TR1=1;
EA=0;
sent(unsigned char ch)
{SBUF=ch;
while(!TI);
TI=0;
sentstr(unsigned char *ch,len)
unsigned int i;
i=0;
while(i<len)
sent(ch);
i++;
arpans()
unsigned char i;
if(rec[38]==myip[0]&&rec[39]==myip[1]&&rec[40]==myip[2]&&rec[41]==myip[3]&&((struct arppk*)(rec+14))->operation==0x0001)
for(i=0;i<6;i++){
myeth.sourcemac=mymac;
myeth.destmac=rec[i+6];
myarp.sendermac=mymac;
myarp.targetmac=rec[i+6];
for(i=0;i<4;i++)
myarp.senderip=myip;
myarp.targetip=rec[i+38];
myeth.nextprot=0x0806;
myarp.hardware=0x0001;
myarp.prottype=0x0800;
myarp.hardlen=0x06;
myarp.protlen=0x04;
myarp.operation=0x0002; //01rewquest //02respond
ethpacket.dat=(unsigned char *)&myeth;
ethpacket.len=14;
ethpacket.nextpk=&arppacket;
arppacket.dat=(unsigned char *)&myarp;
arppacket.len=28;
arppacket.nextpk=NULL;
sentdata(ðpacket);
arpreq()
unsigned char i;
for(i=0;i<6;i++){
myeth.destmac=0xff;
myarp.targetmac=0;
for(i=0;i<4;i++)
myarp.targetip=destip;
myarp.hardlen=0x06;
myarp.protlen=0x04;
myarp.operation=0x0001; //01rewquest //02respond
ethpacket.len=14;
arppacket.len=28;
sentdata(ðpacket);
unsigned char ks,ks2;
ks=0;
init();
delay(1000); // 延时1s,保证电源稳定和网卡自身的上电完成
NICRst(); // RTL8019AS热复位
ClearISR(); // 清除ISR寄存器
RTL8019Init(); // 初始化RTL8019AS
if(k2==0&&ks2==0)
arpreq();
ks2=1;
if(k2!=0)ks2=0;
// if(!k)
if( receivedata(rec))
if(((struct ethhead*)rec)->nextprot==0x0806)arpans();
sentstr(rec,reclen);
/* 延时t毫秒 */
void delay(uint t)
uint i;
while(t--)
/* 对于12M时钟,约延时1ms */
for (i=0;i<125;i++)
/* RTL8019AS热复位 */
void NICRst()
uchar i,tmp;
tmp = REG1f; // 读RTL8019AS的复位端口
REG1f = tmp; // 写RTL8019AS的复位端口
for(i=0;i<250;i++); // 适当延时
/* 通过CR寄存器的PS1和PS0设置寄存器页 */
uchar tmp;
tmp = REG00;
tmp = tmp&0x3B; // 注意不是0x3F,TXP位在不发送时要置0
pagenum = pagenum<<6;
tmp = tmp|pagenum;
REG00 = tmp;
/* 初始化RTL8019AS,PAGE2寄存器只读,PAGE3寄存器不是NE2000兼容的,均不用设置 */
/* 使用0x40-0x4b为网卡的发送缓冲区,共12页,刚好存储2个最大的以太网数据包。
使用0x4c-0x7f为网卡的接收缓冲区,共52页。因此PSTART=0x4c,PSTOP=0x80
(0x80为停止页,接收缓冲区直到0x7f,不包括0x80)。刚开始时,网卡没有接收
到任何数据包,因此BNRY设置为指向第一个接收缓冲区的页0x4c) */
void RTL8019Init()
REG00 = 0x21; // 选择页0的寄存器,网卡停止运行,因为还没有初始化
REG01 = 0x4c; // 寄存器PSTART,设置接收缓冲区的起始页的地址
REG02 = 0x80; // 寄存器PSTOP,设置接收缓冲区的结束页的地址
REG03 = 0x4c; // 寄存器BNRY,设置为指向第一个接收缓冲区的页0x4c(用作读指针)
REG04 = 0x40; // 寄存器TPSR,发送起始页地址初始化为指向第一个发送缓冲区的页
REG0c = 0xcc; /* 接收配置寄存器RCR,设置为仅接收自己地址的数据包以及广播地址
和多点播送地址数据包,小于64字节的包丢弃,校验错的数据包不接收 */
REG0d = 0xe0; // 发送配置寄存器TCR,设置为启用crc自动生成和校验,正常模式工作
REG0e = 0xc8; /* 数据配置寄存器DCR,设置为使用FIFO缓存,普通模式,8位数据传输,
字节顺序为高位字节在前,低位字节在后 */
REG0f = 0xff; // 中断屏蔽寄存器IMR,设置为屏蔽所有中断,若为0xff则使能所有中断
SelectPage(1); // 选择页1的寄存器
REG07=0x4d; // 寄存器CURR,设置为指向当前正在写的页的下一页(用作写指针)
/* 多址地址寄存器MAR0-MAR7均设置为0x00 */
REG08 = 0x00; // MAR0
REG09 = 0x00; // MAR1
REG0a = 0x00; // MAR2
REG0b = 0x00; // MAR3
REG0c = 0x00; // MAR4
REG0d = 0x00; // MAR5
REG0e = 0x00; // MAR6
REG0f = 0x00; // MAR7
setmac(); // 获取以太网物理地址
REG00 = 0x22; // 选择页0寄存器,执行命令。
/* 上电后清除ISR寄存器 */
void ClearISR()
SelectPage(0);
REG07 = REG07|0xff;
/* 获取以太网物理地址 */
void setmac()
// SelectPage(0); // 选择页0
// REG08 = 0; // 远程DMA起始地址低位寄存器RSAR0,设置为0
// REG09 = 0; // 远程DMA起始地址高位寄存器RSAR1,设置为0
// REG0a = 12; // 远程DMA计数器低位寄存器RBCR0,设置为12
// REG0b = 0; // 远程DMA计数器高位寄存器RBCR1,设置为0
// REG00 = 0x0a; // 远程DMA,启动命令
// tmp = REG10; // 读取一个字节
REG01 = mymac[0]; // 写入PAR0
// tmp = REG10; // 读取一个重复的字节,这个字节被丢弃
REG02 = mymac[1]; // 写入PAR1
REG03 = mymac[2]; // 写入PAR2
REG04 =mymac [3]; // 写入PAR3
REG05 = mymac[4]; // 写入PAR4
REG06 = mymac[5]; // 写入PAR5
SelectPage(0);
{unsigned int i,len;
struct packet *tmppk;
len =mypk->len;
tmppk=mypk->nextpk;
while(tmppk!=NULL)
len+=tmppk->len;
tmppk=tmppk->nextpk;
REG00=0x21;
REG07=0x0a;
//REG08=0x40;
//REG09=0x00;
REG08=0x00;
REG09=0x40;
REG0b=len>>8;
REG0a=len&0x00ff;
REG00=0x12;
tmppk=mypk;
while(tmppk!=NULL)
for(i=0;i<tmppk->len;i++)
REG10=*((tmppk->dat)+i);
REG04=0x40;
if(len<60) len=60;
REG05=len&0xff;
REG06=len>>8;
REG00=0x24;
void sentdata(struct ethhead *eth,unsigned char ethlen, struct arppk *arp,unsigned int arplen)
REG00=0x21;
REG07=0x0a;
//REG08=0x40;
//REG09=0x00;
REG08=0x00;
REG09=0x40;
len=ethlen+arplen;
REG0b=len>>8;
REG0a=len&0x00ff;
REG00=0x12;
for(i=0;i<ethlen;i++)
REG10=*eth;
eth++;
for(i=0;i<arplen;i++)
REG10=*arp;
arp++;
REG04=0x40;
if(len<60) len=60;
REG05=len&0xff;
REG06=len>>8;
REG00=0x24;
void sentdata(unsigned char *dat,unsigned int len)
{unsigned int i;
REG00=0x21;
REG07=0x0a;
//REG08=0x40;
//REG09=0x00;
REG08=0x00;
REG09=0x40;
REG0b=len>>8;
REG0a=len&0x00ff;
REG00=0x12;
for(i=0;i<len;i++)
REG10=*dat;
dat++;
REG04=0x40;
if(len<60) len=60;
REG05=len&0xff;
REG06=len>>8;
REG00=0x24;
unsigned char tmp,nextpage;
unsigned int i;
char bnry,curr;
SelectPage(0);
bnry=REG03;
SelectPage(1);
curr=REG07;
bnry++;
if(bnry>0x7f)bnry=0x4c;
if(bnry!=curr)
SelectPage(0);
REG08=0x00;
REG09=bnry;
REG0a=0x00;
REG0b=04;
REG00=0x0a;
tmp=REG10;
nextpage=REG10;
reclen=REG10;
tmp=REG10;
reclen+=tmp<<8;
REG00=0x22;
REG08=4;
REG09=bnry;
REG0b=reclen>>8;
REG0a=reclen&0x00ff;
reclen-=4;
REG00=0x0a;
for(i=0;i<reclen;i++)
{dat=REG10;
REG00=0x0a;
bnry=nextpage-1;
if(bnry<0x4c)bnry=0x7f;
REG03=bnry;
REG07=0xff;
return 1;
return 0;
