1. GENERAL DESCRIPTION
The GPM8F3132A is a highly integrated microcontroller. Besides integrating a pipelined 1T 8051 CPU, 1K-byte XRAM, 256Byte IDM SRAM and 32K Byte program Flash, it also includes 34 programmable multi-functional I/Os, Timer0/1/2, UARTs, SPI (master), Motor control unit with built-in OP and comparators, audio and one up to 8 channel of 12-bit ADC for general-purpose application. It operates over a wide voltage range of 2.4V - 5.5V with different clock sources. It has three modes in power management unit. There is also one on chip debug circuit with two pins to facilitate full speed in-system debug. The detail are described in the following sections
2. FEATURES
CPU
High speed, high performance 1T 8051
100% software compatible with industry standard 8051
Pipeline RISC architecture enables to execute instructions 10 times faster than standard 8051
Up to 24.5MHz clock operation
Memories
1K Bytes XRAM
256 Bytes internal Data Memory (IDM) SRAM
32K Bytes Flash with high endurance
Minimum 200,000 program/erase cycles
Minimum 20 years data retention
Programming lock level for software security
Reset Management
Power On Reset (POR)
Low Voltage Reset (LVR)
Pad Reset (PAD_RST)
Watchdog Reset (WDT_RST)
Software Reset (S/W_RST)
Stop mode Reset (STOP_RST)
Miss Clock Reset (MISS_CLK_RST)
Flash Related Error Reset (FLASH_ERR_RST)
Interrupt Management
16 interrupt sources
Up to 7 external interrupt sources
I/O Ports
Max 34 multifunction bi-directional I/Os
Each incorporate with pull-up resistor, pull-down resistor, output high, output low or floating input, depending on programmer’s settings on the corresponding registers
I/O ports with 20mA current sink
I/O ports with 8mA current drive
Clock Management
Internal oscillator: 24.5MHz±2%, @ 2.4V~5.5V
External clock input max 24.5MHz
Crystal input with 32768Hz or 1MHz~25MHz
Power Management
1 STOP mode for power saving
1 IDLE mode for only peripheral operation
1 PMM mode for low-speed operation (clock/256)
Two 16-bit Timer/Counter (Timer 0/1)
Timer mode with clock source selectable
Auto reload 8 bit timers
Externally gated event counters
One powerful timer2 with 16-bit Compare/Capture Unit
Auto reload 16 bit timers
Event capturing
Digital signals generation
Pulse width modulation and measurement
Programmable Watchdog Timer
Other Peripherals
Digital parts
UART0
SPI (master mode)
Motor control unit
Audio module
Debug unit
Analog parts
Power on reset (POR)
Low voltage reset (LVR)
One 8-channel 12-bit resolution A/D converter
Four comparators on Motor Control Unit
One OP on Motor control Unit
引脚及封装ourdev_668276EZDIIZ.pdf(文件大小:265K) (原文件名:gpm8f3132a_LQFP44.pdf)
![](http://cache.amobbs.com/bbs_upload782111/files_44/ourdev_668277DO3B27.jpg)
3个可独立控制的PWM (原文件名:PWMA.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_44/ourdev_668278XJPV18.jpg)
(原文件名:PWMB.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_44/ourdev_668280DO4XWW.jpg)
电机驱动模块的部分电路 (原文件名:PWMB1.jpg)
可驱动2个无刷,由于文档打了水印,传不了!只裁了一点上来! |
