* Copyright (c) 2011,
* All rights reserved.
* 当前版本:1.0
* 作者:杨永贞QQ534117529
* 开始日期:2011年8月10日
#include <reg51.h>
#include <string.h>
#include "radio.h"
#include"spi.h"
#include"uart.h"
#define U8 unsigned char
#define SEND_OUT_MESSAGE_WITH_ACK "NEED_ACK"
#define SEND_OUT_MESSAGE_NO_ACK "NO_ACK"
#define SEND_OUT_ACK "ACK!"
#define SEND_OUT_MESSAGE_WITH_ACK_LEN 8
#define SEND_OUT_MESSAGE_NO_ACK_LEN 6
#define SEND_OUT_ACK_LEN 4
#define SNED_OUT_MSG_MAX_LEN 8 //It is the maxium length of the send out packet.
extern idata U8 ItStatus1,ItStatus2;
void delay_ms(unsigned int ms)
unsigned int i;
unsigned char j;
for(i=0;i<ms;i++)
for(j=0;j<200;j++);
for(j=0;j<102;j++);
void Init_Device(void)
// Reset_Sources_Init();
// PCA_Init();
// Port_IO_Init(); // Oscillator_Init();
// Timer0_Init();
SPI_Init();
EA = 1; //Enable Gloable interruption.
//启动射频模块,模块的SDN引脚拉低后必须延时至少30ms,实际上可以直接把SDN引脚接地,这样就不用在程序中初始化了;
RF_SDN=0;
delay_ms(30);
delay_ms(30);
// RF_SDN = 0;
// DelayMs(30);
// NSEL = 1;
// SCLK = 0;
SpiWriteRegister(0x0B, 0xCA);
SpiWriteRegister(0x0C, 0xCA);
SpiWriteRegister(0x0D, 0xCA);
//1.Blink the LED to show that the initialization is finished.
//2.Wait for more than 16ms to wait for the radio chip to work correctly.
// TurnOnAllLEDs();
// DelayMs(20);
delay_ms(20);
// TurnOffAllLEDs();
U8 length,temp8, *str, sendLen;
U8 payload[10];
//Initialize the MCU:
UART_Init();
Init_Device();
UART_Send_Str("MCU初始化完毕....\n");
//读取中断状态寄存器清除中断标志以便释放NIRQ引脚
//如果中断来了,那么NIRQ引脚会被拉低;如果这时候中断状态寄存器0x03和0x04被读取,那么NIRQ引脚会被释放恢复高电平
ItStatus1 = SpiReadRegister(0x03); //read the Interrupt Status1 register
ItStatus2 = SpiReadRegister(0x04); //read the Interrupt Status2 register
//SW reset,软件复位这个模块主控芯片
SpiWriteRegister(0x07, 0x80); //write 0x80 to the Operating & Function Control1 register
// DelayMs(20);
delay_ms(20);
delay_ms(20);
//wait for POR interrupt from the radio (while the nIRQ pin is high)
//wait for chip ready interrupt from the radio (while the nIRQ pin is high)
//等待软复位完成,当软复位完成后有中断发生。客户也可以在这里直接延时至少20ms而不用等待中断来;等待至少20ms后复位完成,这时候必须读中断状态寄存器释放中断引脚
while ( NIRQ == 1);
//read interrupt status registers to clear the interrupt flags and release NIRQ pin
//根据不同的射频参数初始化射频模块;
RF_init();
UART_Send_Str("RF芯片si4432初始化完毕....\n");
//Enable two interrupts:
// a) one which shows that a valid packet received: 'ipkval'
// b) second shows if the packet received with incorrect CRC: 'icrcerror'
//设置中断使能寄存器,这里设置为只有当有效的数据包被接收或者接收到的数据包数据CRC校验出错才来中断;具体设置参考0x05和0x06寄存器
SpiWriteRegister(0x05, 0x03); //write 0x03 to the Interrupt Enable 1 register
SpiWriteRegister(0x06, 0x00); //write 0x00 to the Interrupt Enable 2 register
//output dummy data.
PB1_TX = 1;
PB2_TX = 1;
str = SEND_OUT_MESSAGE_WITH_ACK;
sendLen = SEND_OUT_MESSAGE_WITH_ACK_LEN;
//设置模块处于接收状态,当没有按键按下的时候一直处于接收状态,等待接收数据
RFSetRxMode();
UART_Send_Str("模块处于接收状态....\n");
/*MAIN Loop*/
//当按键被按下就有一个数据包被发出;
if(PB1_TX == 0)
while( PB1_TX == 0 );
UART_Send_Str("按键按下,开始发送....\n");
RFFIFOSendData(sendLen, str);
//after packet transmission set the interrupt enable bits according receiving mode
//发射完毕后设置模块让它又工作在接收状态下;
RFSetRxMode();
UART_Send_Str("发送完毕,恢复到接收状态....\n");
//check whether interrupt occured
//查询中断是否到来,如果中断来了,根据我们前面中断使能寄存器的设置,说明有效数据包已经收到,或者收到的数据包CRC校验出错;
//如果客户采用中断触发的方式,那么服务程序必须包括这些内容。在中断服务程序中必须判断被使能的那些中断的状态位是否被置位,然后根据不同的
//状态位进行处理
if( NIRQ == 0 )
//设置模块处于空闲模式,处理收到的数据包,不继续接收数据
RFSetIdleMode();
UART_Send_Str("中断来了....\n");
/*CRC Error interrupt occured*/
//判断是否由于CRC校验出错引发的中断;在RFSetIdleMode中已经读出了中断状态寄存器的值
if( (ItStatus1 & 0x01) == 0x01 )
//reset the RX FIFO
//如果是CRC校验出错,那么接收FIFO复位;
SpiWriteRegister(0x08, 0x02); //write 0x02 to the Operating Function Control 2 register
SpiWriteRegister(0x08, 0x00); //write 0x00 to the Operating Function Control 2 register
//blink all LEDs to show the error
//闪灯提示,客户移植代码的时候这个闪灯操作根据不同客户不同操作
// TurnOnAllLEDs();
// DelayMs(2);
UART_Send_Str("CRC校验出错中断....\n");
/*packet received interrupt occured*/
//判断是否是数据包已经被正确接收。
if( (ItStatus1 & 0x02) == 0x02 )
//Read the length of the received payload
//数据包已经被正确接收,读取收到的数据包长度
length = SpiReadRegister(0x4B); //read the Received Packet Length register
//根据长度判断相应的操作。客户可以不做这些,而直接从FIFO读出收到的数据;
//check whether the received payload is not longer than the allocated buffer in the MCU
if(length <= SNED_OUT_MSG_MAX_LEN)
//Get the reeived payload from the RX FIFO
//直接从FIFO中读取收到的数据。客户只要读出FIFO的数据就算收到数据。
for(temp8=0;temp8 < length;temp8++)
payload[temp8] = SpiReadRegister(0x7F); //read the FIFO Access register
UART_Send_Byte(payload[temp8]); //向串口发送接收到的数据
UART_Send_Str("向串口发送接收到的数据....\n");
//check whether the acknowledgement packet received
//判断是否是预先设定的数据;一般应用情况客户可以不理会这个,这个判断只是我们demo板的应用。客户只要读出FIFO的数据就算收到数据;
if(( length == SEND_OUT_ACK_LEN ) || (length == SEND_OUT_MESSAGE_NO_ACK_LEN))
if((memcmp(&payload[0], SEND_OUT_ACK, SEND_OUT_ACK_LEN - 1) == 0 )
|| (memcmp(&payload[0], SEND_OUT_MESSAGE_NO_ACK, SEND_OUT_MESSAGE_NO_ACK_LEN - 1) == 0))
//blink LED2 to show that ACK received
// RxLEDOn();
//Show the Rx LED for about 10ms
UART_Send_Str("数据包已经被正确接收....\n");
// DelayMs(2);
//check whether an expected packet received, this should be acknowledged
//判断是否是需要发送回答信号的数据包。这个只是根据收到的数据做的不同操作,在客户那里可能是根据收到的数据做的特定的操作,例如控制某个开关
if( length == SEND_OUT_MESSAGE_WITH_ACK_LEN )
//必须发送应答信号,启动发送
if( memcmp(&payload[0], SEND_OUT_MESSAGE_WITH_ACK, SEND_OUT_MESSAGE_WITH_ACK_LEN - 1) == 0 )
//blink LED2 to show that the packet received
//RxLEDOn();
// DelayMs(2);
UART_Send_Str("发送应答....\n");
//发送应答信号。
/*send back an acknowledgement*/
RFFIFOSendData(SEND_OUT_ACK_LEN, SEND_OUT_ACK);
//read interrupt status registers to release all pending interrupts
//reset the RX FIFO
RFSetRxMode();
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
