如题,想看看,学习一下,多谢
下面是刷屏点屏的代码,我想显示字符串
#define Bus_16 //16位数据模式,如果使用8位模式,请注释此语句,如果使用16位模式,请打开此句
#define LCD_DataPortH P2 //高8位数据口,8位模式下只使用高8位
#define LCD_DataPortL P0 //低8位数据口 ,8位模式下低8位可以不接线,请确认P0口已经上拉10K电阻,不宜太小,最小4.7K,推荐10K.
sbit LCD_RS = P1^2; //数据/命令切换
sbit LCD_WR = P1^3; //写控制
sbit LCD_RD =P1^4; //读控制
sbit LCD_CS=P1^0; //片选
sbit LCD_REST = P1^1; //复位
void delayms(int count) // /* X1ms */
int i,j;
for(i=0;i<count;i++)
for(j=0;j<1000;j++);
#ifdef Bus_16 //条件编译-16位数据模式
void LCD_Writ_Bus(char VH,char VL) //并行数据写入函数
LCD_DataPortH=VH;
LCD_DataPortL=VL;
LCD_WR=0;
LCD_WR=1;
#else //条件编译-8位数据模式
LCD_DataPortH=VH;
LCD_WR=0;
LCD_WR=1;
LCD_DataPortH=VL;
LCD_WR=0;
LCD_WR=1;
void Lcd_Write_Com(char VH,char VL) //发送命令-8位参数
LCD_RS=0;
LCD_Writ_Bus(VH,VL);
void Lcd_Write_Data(char VH,char VL) //发送数据-8位参数
LCD_RS=1;
void Lcd_Write_Com_Data(int com,int val) //发送数据命令
Lcd_Write_Com(com>>8,com);
Lcd_Write_Data(val>>8,val);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
Lcd_Write_Com(0x00,0x20);Lcd_Write_Data(x1>>8,x1); //设置X坐标位置
Lcd_Write_Com(0x00,0x21);Lcd_Write_Data(y1>>8,y1); //设置Y坐标位置
Lcd_Write_Com(0x00,0x50);Lcd_Write_Data(x1>>8,x1); //开始X
Lcd_Write_Com(0x00,0x52);Lcd_Write_Data(y1>>8,y1); //开始Y
Lcd_Write_Com(0x00,0x51);Lcd_Write_Data(x2>>8,x2); //结束X
Lcd_Write_Com(0x00,0x53);Lcd_Write_Data(y2>>8,y2); //结束Y
Lcd_Write_Com(0x00,0x22);
void Lcd_Init(void)
LCD_REST=1;
delayms(5);
LCD_REST=0;
delayms(5);
LCD_REST=1;
LCD_CS=1;
LCD_RD=1;
LCD_WR=1;
delayms(5);
LCD_CS =0; //打开片选使能
//************* Start Initial Sequence **********//
Lcd_Write_Com_Data(0x0001, 0x0100); // set SS and SM bit
Lcd_Write_Com_Data(0x0002, 0x0200); // set 1 line inversion
Lcd_Write_Com_Data(0x0003, 0x1030); // set GRAM write direction and BGR=1.
Lcd_Write_Com_Data(0x0004, 0x0000); // Resize register
Lcd_Write_Com_Data(0x0008, 0x0207); // set the back porch and front porch
Lcd_Write_Com_Data(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
Lcd_Write_Com_Data(0x000A, 0x0000); // FMARK function
Lcd_Write_Com_Data(0x000C, 0x0000); // RGB interface setting
Lcd_Write_Com_Data(0x000D, 0x0000); // Frame marker Position
Lcd_Write_Com_Data(0x000F, 0x0000); // RGB interface polarity
//*************Power On sequence ****************//
Lcd_Write_Com_Data(0x0010, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
Lcd_Write_Com_Data(0x0011, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
Lcd_Write_Com_Data(0x0012, 0x0000); // VREG1OUT voltage
Lcd_Write_Com_Data(0x0013, 0x0000); // VDV[4:0] for VCOM amplitude
Lcd_Write_Com_Data(0x0007, 0x0001);
delayms(200); // Dis-charge capacitor power voltage
Lcd_Write_Com_Data(0x0010, 0x1690); // SAP, BT[3:0], AP, DSTB, SLP, STB
Lcd_Write_Com_Data(0x0011, 0x0227); // Set DC1[2:0], DC0[2:0], VC[2:0]
delayms(50); // Delay 50ms
Lcd_Write_Com_Data(0x0012, 0x000D); // 0012
Lcd_Write_Com_Data(0x0013, 0x1200); // VDV[4:0] for VCOM amplitude
Lcd_Write_Com_Data(0x0029, 0x000A); // 04 VCM[5:0] for VCOMH
Lcd_Write_Com_Data(0x002B, 0x000D); // Set Frame Rate
Lcd_Write_Com_Data(0x0020, 0x0000); // GRAM horizontal Address
Lcd_Write_Com_Data(0x0021, 0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
Lcd_Write_Com_Data(0x0030, 0x0000);
Lcd_Write_Com_Data(0x0031, 0x0404);
Lcd_Write_Com_Data(0x0032, 0x0003);
Lcd_Write_Com_Data(0x0035, 0x0405);
Lcd_Write_Com_Data(0x0036, 0x0808);
Lcd_Write_Com_Data(0x0037, 0x0407);
Lcd_Write_Com_Data(0x0038, 0x0303);
Lcd_Write_Com_Data(0x0039, 0x0707);
Lcd_Write_Com_Data(0x003C, 0x0504);
Lcd_Write_Com_Data(0x003D, 0x0808);
//------------------ Set GRAM area ---------------//
Lcd_Write_Com_Data(0x0050, 0x0000); // Horizontal GRAM Start Address
Lcd_Write_Com_Data(0x0051, 0x00EF); // Horizontal GRAM End Address
Lcd_Write_Com_Data(0x0052, 0x0000); // Vertical GRAM Start Address
Lcd_Write_Com_Data(0x0053, 0x013F); // Vertical GRAM Start Address
Lcd_Write_Com_Data(0x0060, 0xA700); // Gate Scan Line
Lcd_Write_Com_Data(0x0061, 0x0001); // NDL,VLE, REV
Lcd_Write_Com_Data(0x006A, 0x0000); // set scrolling line
//-------------- Partial Display Control ---------//
Lcd_Write_Com_Data(0x0080, 0x0000);
Lcd_Write_Com_Data(0x0081, 0x0000);
Lcd_Write_Com_Data(0x0082, 0x0000);
Lcd_Write_Com_Data(0x0083, 0x0000);
Lcd_Write_Com_Data(0x0084, 0x0000);
Lcd_Write_Com_Data(0x0085, 0x0000);
//-------------- Panel Control -------------------//
Lcd_Write_Com_Data(0x0090, 0x0010);
Lcd_Write_Com_Data(0x0092, 0x0000);
Lcd_Write_Com_Data(0x0007, 0x0133); // 262K color and display ON
LCD_CS =1; //关闭片选使能
void Pant(char VH,char VL)
int i,j;
LCD_CS =0; //打开片选使能
Address_set(0,0,240,320);
for(i=0;i<320;i++)
for (j=0;j<240;j++)
Lcd_Write_Data(VH,VL);
LCD_CS =1; //关闭片选使能
main()
Lcd_Init(); //TFT初始化
Pant(0xff,0xff); //TFT清屏
Pant(0xf8,0x00); //红色
delayms(2000);
Pant(0X07,0xE0); //绿色
delayms(2000);
Pant(0x00,0x1f); //蓝色
delayms(2000);
