发表于 2011-8-10 12:40:05
汗,被误导了。。。
这个电路增益很高的。俺的输入信号太高了,所以失真非常大。。
The cascaded amplifiers operate in sequential gain. Here, the
offset voltage between Pin 2 (GNEG) of A1 and A2 is 1.05 V
(42.14 dB × 25 mV/dB), provided by a voltage divider consisting of
Resistors R5, R6, and R7. Using standard values, the offset is not
exact, but it is not critical for this application.
The gain of both A1 and A2 is programmed by Resistors R13
and R14, respectively, to be about 42 dB; therefore, the maximum
gain of the circuit is twice that, or 84 dB. The gain control range
can be shifted up by as much as 20 dB by appropriate choices of
R13 and R14. |
