#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/Bladder_Scanner_EP3C40/dev/software/bladder_english/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="E:/Bladder_Scanner_EP3C40/
dev/Bladder_Scanner.sof" --output="Bladder_Scanner.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert E:/Bladder_Scanner_EP3C40/dev/B
ladder_Scanner.sof Bladder_Scanner.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 58 megabytes
Info: Processing ended: Fri Aug 05 11:33:38 2011
Info: Elapsed time: 00:00:01
Info: Total CPU time (on all processors): 00:00:00
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x02000000
--id=2095008322 --timestamp=1312512631 --accept-bad-sysid --instance=0 "Bladder
_Scanner.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x02000000:
ID value does not match: read 0xFFFFFFFF; expected 0x7CDF4A42
Timestamp value does not match: image on board is older than expected
Read timestamp 7:59:59 1970/01/01; expected 10:50:31 2011/08/05
Warning: The software you are downloading may not run on the system which
is currently configured into the device.
: Checksumming existing contents
00000000 : Reading existing contents
00020000 : Reading existing contents
00040000 : Reading existing contents
00060000 : Reading existing contents
00080000 : Reading existing contents
000A0000 : Reading existing contents
000C0000 : Reading existing contents
000E0000 : Reading existing contents
00100000 : Reading existing contents
00120000 : Reading existing contents
Checksummed/read 117kB in 3.7s
00000000 ( 0%): Erasing
00020000 (10%): Erasing
00040000 (20%): Erasing
00060000 (30%): Erasing
00080000 (40%): Erasing
000A0000 (50%): Erasing
000C0000 (60%): Erasing
000E0000 (70%): Erasing
00100000 (80%): Erasing
00120000 (90%): Erasing
Erased 1280kB in 3.9s (328.2kB/s)
00000000 ( 0%): Programming
00020000 (10%): Programming
00040000 (20%): Programming
00060000 (30%): Programming
00080000 (40%): Programming
000A0000 (50%): Programming
000C0000 (60%): Programming
000E0000 (70%): Programming
00100000 (80%): Programming
00120000 (90%): Programming
Programmed 1164KB +116KB in 26.2s (48.8KB/s)
Verify failed at offset 0
Verify failed at offset 20000
Verify failed at offset 40000
Verify failed at offset 60000
Verify failed at offset 80000
Verify failed at offset A0000
Verify failed at offset C0000
Verify failed at offset E0000
Verify failed at offset 100000
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00000000 --end=0x1ffffff --reset=0x0 --
input="bladder_english.elf" --output="cfi_flash.flash" --boot="C:/altera/91/ip/a
ltera/nios2_ip/altera_nios2/boot_loader_cfi.srec"
# Programming flash with the project
--id=2095008322 --timestamp=1312512631 --accept-bad-sysid --instance=0 "cfi_fla
sh.flash"
00160000 : Verifying existing contents
001A0000 : Verifying existing contents
001E0000 : Verifying existing contents
00220000 : Verifying existing contents
00260000 : Verifying existing contents
002A0000 : Verifying existing contents
00140000 : Reading existing contents
00180000 : Reading existing contents
001C0000 : Reading existing contents
00200000 : Reading existing contents
00240000 : Reading existing contents
00280000 : Reading existing contents
Checksummed/read 721kB in 21.8s
00020000 ( 6%): Erasing
00040000 (12%): Erasing
00060000 (18%): Erasing
00080000 (25%): Erasing
000A0000 (31%): Erasing
000C0000 (37%): Erasing
000E0000 (43%): Erasing
00100000 (50%): Erasing
00120000 (56%): Erasing
00140000 (62%): Erasing
00180000 (68%): Erasing
001C0000 (75%): Erasing
00200000 (81%): Erasing
00240000 (87%): Erasing
00280000 (93%): Erasing
Erased 2048kB in 5.8s (353.1kB/s)
00020000 ( 4%): Programming
00040000 ( 9%): Programming
00060000 (13%): Programming
00080000 (18%): Programming
000A0000 (23%): Programming
000C0000 (27%): Programming
000E0000 (32%): Programming
00100000 (36%): Programming
00120000 (41%): Programming
00140000 (46%): Programming
00160000 (50%): Programming
00180000 (50%): Programming
001A0000 (55%): Programming
001C0000 (55%): Programming
001E0000 (60%): Programming
00200000 (60%): Programming
00220000 (64%): Programming
00240000 (64%): Programming
00260000 (69%): Programming
00280000 (69%): Programming
002A0000 (73%): Programming
Programmed 2769KB in 42.0s (65.9KB/s)
Verify failed at offset 120000
Verify failed at offset 140000
Verify failed at offset 180000
Verify failed at offset 1C0000
Verify failed at offset 200000
Verify failed at offset 240000
Verify failed at offset 280000
这是怎么回事呢 上电重启还是没反应 |
