我现在的系统是ubuntu11.04,交叉编译工具是在mini的官方网站上下载的arm-gcc-4.4.1-20100409.tar.gz,但是解压缩后进入到目录下
/usr/local/arm/4.4.1/bin
root@xx:/workdir/android/tools/usr/local/arm/4.4.1/bin# ls
arm-linux-addr2line arm-linux-gdb arm-linux-sprite arm-none-linux-gnueabi-gcc arm-none-linux-gnueabi-ranlib
arm-linux-ar arm-linux-gdbtui arm-linux-strings arm-none-linux-gnueabi-gcc-4.4.1 arm-none-linux-gnueabi-readelf
arm-linux-as arm-linux-gprof arm-linux-strip arm-none-linux-gnueabi-gcov arm-none-linux-gnueabi-size
arm-linux-c++ arm-linux-ld arm-none-linux-gnueabi-addr2line arm-none-linux-gnueabi-gdb arm-none-linux-gnueabi-sprite
arm-linux-c++filt arm-linux-nm arm-none-linux-gnueabi-ar arm-none-linux-gnueabi-gdbtui arm-none-linux-gnueabi-strings
arm-linux-cpp arm-linux-objcopy arm-none-linux-gnueabi-as arm-none-linux-gnueabi-gprof arm-none-linux-gnueabi-strip
arm-linux-g++ arm-linux-objdump arm-none-linux-gnueabi-c++ arm-none-linux-gnueabi-ld
arm-linux-gcc arm-linux-ranlib arm-none-linux-gnueabi-c++filt arm-none-linux-gnueabi-nm
arm-linux-gcc-4.4.1 arm-linux-readelf arm-none-linux-gnueabi-cpp arm-none-linux-gnueabi-objcopy
arm-linux-gcov arm-linux-size arm-none-linux-gnueabi-g++ arm-none-linux-gnueabi-objdump
root@xx:/workdir/android/tools/usr/local/arm/4.4.1/bin# ls -l
total 15740
lrwxrwxrwx 1 root root 32 2010-04-08 14:40 arm-linux-addr2line -> arm-none-linux-gnueabi-addr2line
lrwxrwxrwx 1 root root 25 2010-04-08 14:40 arm-linux-ar -> arm-none-linux-gnueabi-ar
lrwxrwxrwx 1 root root 25 2010-04-08 14:40 arm-linux-as -> arm-none-linux-gnueabi-as
lrwxrwxrwx 1 root root 26 2010-04-08 14:40 arm-linux-c++ -> arm-none-linux-gnueabi-c++
lrwxrwxrwx 1 root root 30 2010-04-08 14:40 arm-linux-c++filt -> arm-none-linux-gnueabi-c++filt
lrwxrwxrwx 1 root root 26 2010-04-08 14:40 arm-linux-cpp -> arm-none-linux-gnueabi-cpp
lrwxrwxrwx 1 root root 26 2010-04-08 14:40 arm-linux-g++ -> arm-none-linux-gnueabi-g++
lrwxrwxrwx 1 root root 26 2010-04-08 14:40 arm-linux-gcc -> arm-none-linux-gnueabi-gcc
lrwxrwxrwx 1 root root 32 2010-04-08 14:40 arm-linux-gcc-4.4.1 -> arm-none-linux-gnueabi-gcc-4.4.1
lrwxrwxrwx 1 root root 27 2010-04-08 14:40 arm-linux-gcov -> arm-none-linux-gnueabi-gcov
lrwxrwxrwx 1 root root 26 2010-04-08 14:40 arm-linux-gdb -> arm-none-linux-gnueabi-gdb
lrwxrwxrwx 1 root root 29 2010-04-08 14:40 arm-linux-gdbtui -> arm-none-linux-gnueabi-gdbtui
lrwxrwxrwx 1 root root 28 2010-04-08 14:40 arm-linux-gprof -> arm-none-linux-gnueabi-gprof
lrwxrwxrwx 1 root root 25 2010-04-08 14:40 arm-linux-ld -> arm-none-linux-gnueabi-ld
lrwxrwxrwx 1 root root 25 2010-04-08 14:40 arm-linux-nm -> arm-none-linux-gnueabi-nm
lrwxrwxrwx 1 root root 30 2010-04-08 14:40 arm-linux-objcopy -> arm-none-linux-gnueabi-objcopy
lrwxrwxrwx 1 root root 30 2010-04-08 14:40 arm-linux-objdump -> arm-none-linux-gnueabi-objdump
lrwxrwxrwx 1 root root 29 2010-04-08 14:40 arm-linux-ranlib -> arm-none-linux-gnueabi-ranlib
lrwxrwxrwx 1 root root 30 2010-04-08 14:40 arm-linux-readelf -> arm-none-linux-gnueabi-readelf
lrwxrwxrwx 1 root root 27 2010-04-08 14:40 arm-linux-size -> arm-none-linux-gnueabi-size
lrwxrwxrwx 1 root root 29 2010-04-08 14:40 arm-linux-sprite -> arm-none-linux-gnueabi-sprite
lrwxrwxrwx 1 root root 30 2010-04-08 14:40 arm-linux-strings -> arm-none-linux-gnueabi-strings
lrwxrwxrwx 1 root root 28 2010-04-08 14:40 arm-linux-strip -> arm-none-linux-gnueabi-strip
-rwxrwxrwx 1 root root 547548 2009-10-17 01:24 arm-none-linux-gnueabi-addr2line
-rwxrwxrwx 2 root root 572276 2009-10-17 01:24 arm-none-linux-gnueabi-ar
-rwxrwxrwx 2 root root 954556 2009-10-17 01:24 arm-none-linux-gnueabi-as
-rwxrwxrwx 2 root root 210380 2009-10-17 01:24 arm-none-linux-gnueabi-c++
-rwxrwxrwx 1 root root 547324 2009-10-17 01:24 arm-none-linux-gnueabi-c++filt
-rwxrwxrwx 1 root root 209228 2009-10-17 01:24 arm-none-linux-gnueabi-cpp
-rwxrwxrwx 2 root root 210380 2009-10-17 01:24 arm-none-linux-gnueabi-g++
-rwxrwxrwx 2 root root 207948 2009-10-17 01:24 arm-none-linux-gnueabi-gcc
-rwxrwxrwx 2 root root 207948 2009-10-17 01:24 arm-none-linux-gnueabi-gcc-4.4.1
-rwxrwxrwx 1 root root 26760 2009-10-17 01:24 arm-none-linux-gnueabi-gcov
-rwxrwxrwx 1 root root 2840960 2009-10-17 01:24 arm-none-linux-gnueabi-gdb
-rwxrwxrwx 1 root root 2840960 2009-10-17 01:24 arm-none-linux-gnueabi-gdbtui
-rwxrwxrwx 1 root root 607456 2009-10-17 01:24 arm-none-linux-gnueabi-gprof
-rwxrwxrwx 2 root root 959396 2009-10-17 01:24 arm-none-linux-gnueabi-ld
-rwxrwxrwx 2 root root 556092 2009-10-17 01:24 arm-none-linux-gnueabi-nm
-rwxrwxrwx 2 root root 705268 2009-10-17 01:24 arm-none-linux-gnueabi-objcopy
-rwxrwxrwx 2 root root 836092 2009-10-17 01:24 arm-none-linux-gnueabi-objdump
-rwxrwxrwx 2 root root 572308 2009-10-17 01:24 arm-none-linux-gnueabi-ranlib
-rwxrwxrwx 1 root root 307848 2009-10-17 01:24 arm-none-linux-gnueabi-readelf
-rwxrwxrwx 1 root root 551680 2009-10-17 01:24 arm-none-linux-gnueabi-size
-rwxrwxrwx 1 root root 342540 2009-10-17 01:24 arm-none-linux-gnueabi-sprite
-rwxrwxrwx 1 root root 547516 2009-10-17 01:24 arm-none-linux-gnueabi-strings
-rwxrwxrwx 2 root root 705268 2009-10-17 01:24 arm-none-linux-gnueabi-strip
但是我想先执行下看是否OK:
root@xx:/workdir/android/tools/usr/local/arm/4.4.1/bin# arm-linux-c++
arm-linux-c++: command not found
为什么会出现这个情况呢!
我换了几个版本的也是一样哈! |
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
