library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity VGA_MAO is
port(clk50MHz: in std_logic;
HS,VS: out std_logic;
R,G,B: out std_logic
end entity VGA_MAO;
architecture first of VGA_MAO is
signal clk: std_logic;
signal clk_1Hz: std_logic;
SIGNAL SHI : INTEGER RANGE 0 TO 23;
SIGNAL FEN : INTEGER RANGE 0 TO 59;
SIGNAL MIAO : INTEGER RANGE 0 TO 59;
signal count_h: std_logic_vector(9 downto 0);
signal count_v: std_logic_vector(9 downto 0);
signal x,y: integer range 0 to 900;
--signal xx,yy: integer range 0 to 40; --水平方向分成40块,垂直方向分成30块
signal temp: std_logic;
signal RGB: std_logic_vector(0 to 2);
signal HS1,VS1: std_logic;
signal data1,data2,data3,data4,data5,data6,data7,data8,data9,data10,data11: std_logic_vector(7 downto 0);
signal hour_1,hour_2,min_1,min_2,sec_1,sec_2: integer range 0 to 9;
type mao is array(0 to 199) of std_logic_vector(7 downto 0);
type zi_16_16 is array(0 to 31) of std_logic_vector(7 downto 0);
type shu_8_16 is array(0 to 15) of std_logic_vector(7 downto 0);
--阴码,逐行式,逆向
constant shu_0:shu_8_16:=( x"00",x"00",x"00",x"38",x"44",x"82",x"82",x"82",
x"82",x"82",x"82",x"82",x"44",x"38",x"00",x"00");
constant shu_1:shu_8_16:=( x"00",x"00",x"00",x"08",x"0C",x"0E",x"08",x"08",
x"08",x"08",x"08",x"08",x"08",x"08",x"00",x"00");
constant shu_2:shu_8_16:=( x"00",x"00",x"00",x"18",x"24",x"42",x"42",x"40",
x"20",x"10",x"08",x"04",x"02",x"7E",x"00",x"00");
constant shu_3:shu_8_16:=( x"00",x"00",x"00",x"3C",x"42",x"42",x"40",x"40",
x"30",x"40",x"40",x"42",x"42",x"3C",x"00",x"00");
constant shu_4:shu_8_16:=( x"00",x"00",x"00",x"40",x"60",x"50",x"48",x"48",
x"44",x"42",x"FE",x"40",x"40",x"40",x"00",x"00");
constant shu_5:shu_8_16:=( x"00",x"00",x"00",x"7E",x"02",x"02",x"3E",x"42",
x"40",x"40",x"40",x"42",x"42",x"3C",x"00",x"00");
constant shu_6:shu_8_16:=( x"00",x"00",x"00",x"38",x"44",x"42",x"02",x"3A",
x"46",x"42",x"42",x"42",x"44",x"38",x"00",x"00");
constant shu_7:shu_8_16:=( x"00",x"00",x"00",x"7E",x"40",x"40",x"20",x"20",
x"20",x"10",x"10",x"10",x"08",x"08",x"00",x"00");
constant shu_8:shu_8_16:=( x"00",x"00",x"00",x"38",x"44",x"82",x"82",x"44",
x"38",x"44",x"82",x"82",x"44",x"38",x"00",x"00");
constant shu_9:shu_8_16:=( x"00",x"00",x"00",x"1C",x"22",x"42",x"42",x"42",
x"62",x"5C",x"40",x"42",x"22",x"1C",x"00",x"00");
constant shu_mh:shu_8_16:=( x"00",x"00",x"00",x"00",x"00",x"00",x"18",x"18",
x"00",x"00",x"18",x"18",x"00",x"00",x"00",x"00");
shared variable shi_shi,shi_ge,fen_shi,fen_ge,miao_shi,miao_ge:shu_8_16;
constant rom:zi_16_16:=( x"00",x"00",x"80",x"0F",
x"FE",x"1F",x"FE",x"00",
x"C0",x"00",x"C0",x"0F",
x"FE",x"0F",x"FE",x"00",
x"C0",x"3F",x"FF",x"3F",
x"FF",x"00",x"C0",x"00",
x"C0",x"30",x"C0",x"3F",
x"80",x"1F",x"00",x"00");--两个数为一行 1为白色 0为黑色
constant rom1:zi_16_16:=(x"12",x"00",x"DA",x"3B",
x"CC",x"3B",x"3F",x"33",
x"3F",x"33",x"4C",x"37",
x"BE",x"3B",x"3E",x"33",
x"8C",x"33",x"7F",x"3B",
x"3F",x"37",x"0C",x"33",
x"0C",x"33",x"86",x"3B",
x"83",x"19",x"00",x"00");
constant bmp1:mao:=( x"00",x"00",x"00",x"00",x"00",
x"00",x"FC",x"FF",x"00",x"00",
x"00",x"0F",x"C0",x"03",x"00",
x"80",x"01",x"00",x"06",x"00",
x"C0",x"00",x"00",x"0C",x"00",
x"60",x"00",x"00",x"18",x"00",
x"30",x"00",x"00",x"30",x"00",
x"90",x"07",x"80",x"27",x"00",
x"58",x"08",x"40",x"68",x"00",
x"08",x"00",x"00",x"40",x"00",
x"18",x"00",x"00",x"60",x"00",
x"10",x"00",x"00",x"20",x"00",
x"30",x"00",x"03",x"20",x"00",
x"20",x"80",x"07",x"10",x"00",
x"20",x"80",x"04",x"10",x"00",
x"40",x"80",x"04",x"08",x"00",
x"80",x"80",x"04",x"04",x"00",
x"00",x"07",x"83",x"03",x"00",
x"00",x"7C",x"FB",x"00",x"00",
x"00",x"E8",x"5F",x"00",x"00",
x"00",x"28",x"50",x"00",x"00",
x"00",x"24",x"90",x"00",x"00",
x"00",x"E4",x"9F",x"00",x"00",
x"00",x"28",x"53",x"00",x"00",
x"00",x"30",x"33",x"00",x"00",
x"00",x"E0",x"1F",x"00",x"00",
x"00",x"00",x"00",x"00",x"00"); --bmp 位图40*40
constant bmp2:mao:=(x"00",x"00",x"00",x"00",x"00",
x"00",x"80",x"FF",x"03",x"00",
x"00",x"E0",x"00",x"0E",x"00",
x"00",x"30",x"00",x"18",x"00",
x"00",x"0C",x"00",x"60",x"00",
x"00",x"76",x"00",x"DC",x"00",
x"00",x"CB",x"00",x"A6",x"01",
x"00",x"DD",x"00",x"6E",x"03",
x"80",x"FD",x"00",x"7E",x"03",
x"80",x"FC",x"00",x"7E",x"02",
x"80",x"78",x"00",x"38",x"02",
x"80",x"00",x"00",x"00",x"02",
x"80",x"01",x"00",x"00",x"03",
x"00",x"01",x"38",x"00",x"01",
x"00",x"03",x"24",x"80",x"01",
x"00",x"06",x"24",x"C0",x"00",
x"00",x"0C",x"38",x"60",x"00",
x"00",x"38",x"00",x"38",x"00",
x"00",x"E0",x"01",x"0F",x"00",
x"00",x"40",x"01",x"05",x"00",
x"00",x"40",x"FF",x"05",x"00",
x"00",x"C0",x"AA",x"06",x"00",
x"00",x"80",x"AB",x"03",x"00",
x"00",x"00",x"EE",x"00",x"00",
begin
p0:process(clk50MHz)
variable aa: integer range 0 to 25000000;
begin
if clk50MHz'event and clk50MHz='1' then
clk<=not clk;
if aa<24999900 then aa:=aa+1;
else clk_1Hz<=not clk_1Hz;aa:=0;
end if;
end if;
end process p0;
p1:process(clk) --行像素点计数
begin
if clk'event and clk='1' then
if count_h<800 then
count_h<=count_h+1;
else count_h<="0000000000";
end if;
end if;
end process p1;
p2:process(count_h) --行消隐信号
begin
if count_h<96 then HS1<='0';
else HS1<='1';
end if;
end process p2;
p3:process(HS1) --场像素点计数
begin
if HS1'event and HS1='1' then
if count_v<525 then
count_v<=count_v+1;
else count_v<="0000000000";
end if;
end if;
end process p3;
P4:process(count_v) --场消隐信号
begin
if count_v<2 then VS1<='0';
else VS1<='1';
end if;
end process p4;
p5:process(x,clk) --水平方向上扫描
begin
if clk'event and clk='0' then
if count_v>=35 and count_v<=515 then --行读数时,一定还要场消隐!!!
if y>=0 and y<=480 then
if x>=0 and x<=7 then temp<=data1(x); --八列八列的扫描
elsif x>=8 and x<=15 then temp<=data2(x-8);
elsif x>=16 and x<=23 then temp<=data3(x-16);
elsif x>=24 and x<=31 then temp<=data4(x-24);
elsif x>=32 and x<=39 then temp<=data5(x-32);
elsif x>=40 and x<=47 then temp<=data6(x-40);
elsif x>=48 and x<=55 then temp<=data7(x-48);
elsif x>=56 and x<=63 then temp<=data8(x-56);
elsif x>=64 and x<=71 then temp<=data9(x-64);
elsif x>=72 and x<=79 then temp<=data10(x-72);
elsif x>=80 and x<=87 then temp<=data11(x-80);
else temp<='0';
end if;
end if;
else temp<='0'; --场消隐!!!
end if;
end if;
end process p5;
p7:process(count_h,count_v,x,y,data1,data2,data3,data4,data5,data6,data7,data8,data9,data10,data11) --分配坐标 X,Y
begin
if count_h>143 and count_h<785 then x<=conv_integer(count_h)-144; -- 0~640
else x<=900;
end if;
if count_v>34 and count_v<515 then y<=conv_integer(count_v)-35; -- 0~480
else y<=900;
end if;
if y>=0 and y<=15 then --确定哪一行显示什么
data1<=rom(2*y);
data2<=rom(2*y+1);
data3<=rom1(2*y);
data4<=rom1(2*y+1);
elsif y>=16 and y<=55 then
data1<=bmp1(5*(y-16));
data2<=bmp1(5*(y-16)+1);
data3<=bmp1(5*(y-16)+2);
data4<=bmp1(5*(y-16)+3);
data5<=bmp1(5*(y-16)+4);
data6<=bmp2(5*(y-16));
data7<=bmp2(5*(y-16)+1);
data8<=bmp2(5*(y-16)+2);
data9<=bmp2(5*(y-16)+3);
data10<=bmp2(5*(y-16)+4);
elsif y>=64 and y<=79 then
data1<=shi_shi(y-64);
data2<=shi_ge(y-64);
data3<=shu_mh(y-64);
data4<=fen_shi(y-64);
data5<=fen_ge(y-64);
data6<=shu_mh(y-64);
data7<=miao_shi(y-64);
data8<=miao_ge(y-64);
-- data9<=shu_8(y-64);
-- data10<=shu_9(y-64);
-- data11<=shu_mh(y-64);
data1<=x"00";
data2<=x"00";
data3<=x"00";
data4<=x"00";
data5<=x"00";
data6<=x"00";
data7<=x"00";
data8<=x"00";
data9<=x"00";
data10<=x"00";
data11<=x"00";
end if;
end process p7;
p8:process(temp) --1为白色 0为黑色
begin
if temp='0' then RGB<="000";
else RGB<="111";
end if;
end process p8;
-- p9:process(x,y)
-- begin
-- if x>=0 and x<=7 then xx<=0;
-- elsif x>=8 and x<=15 then xx<=1;
-- elsif x>=16 and x<=23 then xx<=2;
-- elsif x>=24 and x<=31 then xx<=3;
-- elsif x>=32 and x<=39 then xx<=4;
-- elsif x>=40 and x<=47 then xx<=5;
-- elsif x>=48 and x<=55 then xx<=6;
-- elsif x>=56 and x<=63 then xx<=7;
-- elsif x>=64 and x<=71 then xx<=8;
-- else null;
-- end if;
-- end process p9;
p10:process(clk_1Hz) --时,分,秒进位进程
begin
if clk_1Hz'event and clk_1Hz='1' then
if MIAO<59 then MIAO<=MIAO+1;
elsif MIAO=59 then
MIAO<=0;
if FEN<59 then FEN<=FEN+1;
elsif FEN=59 then
FEN<=0;
if SHI<23 then SHI<=SHI+1;
elsif SHI=23 then SHI<=0;
end if;
end if;
end if;
end if;
end process p10;
p11:process(hour_1,hour_2,min_1,min_2,sec_1,sec_2)
begin
case hour_1 is
when 0 => shi_shi:=shu_0;
when 1 => shi_shi:=shu_1;
when 2 => shi_shi:=shu_2;
when 3 => shi_shi:=shu_3;
when 4 => shi_shi:=shu_4;
when 5 => shi_shi:=shu_5;
when 6 => shi_shi:=shu_6;
when 7 => shi_shi:=shu_7;
when 8 => shi_shi:=shu_8;
when 9 => shi_shi:=shu_9;
when others => null;
end case;
case hour_2 is
when 0 => shi_ge:=shu_0;
when 1 => shi_ge:=shu_1;
when 2 => shi_ge:=shu_2;
when 3 => shi_ge:=shu_3;
when 4 => shi_ge:=shu_4;
when 5 => shi_ge:=shu_5;
when 6 => shi_ge:=shu_6;
when 7 => shi_ge:=shu_7;
when 8 => shi_ge:=shu_8;
when 9 => shi_ge:=shu_9;
end case;
case min_1 is
when 0 => fen_shi:=shu_0;
when 1 => fen_shi:=shu_1;
when 2 => fen_shi:=shu_2;
when 3 => fen_shi:=shu_3;
when 4 => fen_shi:=shu_4;
when 5 => fen_shi:=shu_5;
when 6 => fen_shi:=shu_6;
when 7 => fen_shi:=shu_7;
when 8 => fen_shi:=shu_8;
when 9 => fen_shi:=shu_9;
end case;
case min_2 is
when 0 => fen_ge:=shu_0;
when 1 => fen_ge:=shu_1;
when 2 => fen_ge:=shu_2;
when 3 => fen_ge:=shu_3;
when 4 => fen_ge:=shu_4;
when 5 => fen_ge:=shu_5;
when 6 => fen_ge:=shu_6;
when 7 => fen_ge:=shu_7;
when 8 => fen_ge:=shu_8;
when 9 => fen_ge:=shu_9;
end case;
case sec_1 is
when 0 => miao_shi:=shu_0;
when 1 => miao_shi:=shu_1;
when 2 => miao_shi:=shu_2;
when 3 => miao_shi:=shu_3;
when 4 => miao_shi:=shu_4;
when 5 => miao_shi:=shu_5;
when 6 => miao_shi:=shu_6;
when 7 => miao_shi:=shu_7;
when 8 => miao_shi:=shu_8;
when 9 => miao_shi:=shu_9;
end case;
case sec_2 is
when 0 => miao_ge:=shu_0;
when 1 => miao_ge:=shu_1;
when 2 => miao_ge:=shu_2;
when 3 => miao_ge:=shu_3;
when 4 => miao_ge:=shu_4;
when 5 => miao_ge:=shu_5;
when 6 => miao_ge:=shu_6;
when 7 => miao_ge:=shu_7;
when 8 => miao_ge:=shu_8;
when 9 => miao_ge:=shu_9;
end case;
end process p11;
hour_1<=SHI/10;
hour_2<=SHI mod 10;
min_1<=FEN/10;
min_2<=FEN mod 10;
sec_1<=MIAO/10;
sec_2<=MIAO mod 10;
HS<=HS1;
VS<=VS1;
R<=RGB(2);
G<=RGB(1);
B<=RGB(0);
end first;
本来是想把数据存在ROM里的。结果弄了半天不知道写程序了。最后还是把它放在数组里。新手上路,欢迎交流经验。。。
本来想把680*480 分成一块块16*16的,结果写的时候发现会有时延不知道怎么处理,p5进程里的if条件用XX表示就出不图像。
效果图 (原文件名:图像683.jpg) |
