发表于 2011-7-25 20:36:28
我自己顶一下吧。
现在芯片可以初始化了,但是紧接着的寻卡,怎么都不行,我也参考了网上好多的例子,我觉得我的可以啊,但是怎么都没用,我把程序源代码贴在这,哪位大侠做过,热心帮帮忙,大家都理解那种想做找不到问题解决方法抓狂的心理,帮帮忙,谢谢了。
#include<reg52.h>
#include<intrins.h>
#include<FM1702.h>
#define uint unsigned int
uchar code keya[]={0xff,0xff,0xff,0xff,0xff,0xff};
uchar code keyb[]={0xff,0xff,0xff,0xff,0xff,0xff};//卡的密匙
uchar code changekey[12]={0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f};//密匙变换存储区
uchar Fbuff[16]; //发送FIFO缓存
uchar Jbuff[16]; //接收FIFO缓存
uchar UID[7]; //卡型及卡号
uchar change[4];
sbit cs=P2^0;
sbit sck=P2^1;
sbit mosi=P2^2;
sbit miso=P2^3;
sbit FM1702rst=P3^4;
sbit led9=P1^0;
sbit led8=P1^1;
sbit led7=P1^2;
sbit led6=P1^3;
sbit led5=P1^4;
/*****************函数声明**************************/
//void spi_write(uchar m);
uchar spi(uchar m);
void fifo_clear();
void resig_write(uchar reg,uchar da);
uchar resig_read(uchar reg);
uchar fifo_read(uchar count,uchar *s);
void fifo_write(uchar count,uchar *s);
uchar inti_1702();
void card_halt();
void card_scan();
uchar card_type();
uchar card_anticoll();
void card_select();
void card_authtication1(uchar m);
uchar card_authtication2();
uchar card_read(uchar m);
uchar card_write(uchar m);
uchar card_incre(uchar m,uchar x);
uchar card_dec(uchar m,uchar x);
uchar loadkey();
void delay(uchar m);
uchar HL_card_active (uchar picc_k);
uchar spi(uchar m)
uchar i,temp=0;
for(i=0;i<8;i++)
sck=0;
if(m&0x80)
mosi=1;
mosi=0;
m<<=1;
sck=1;
temp<<=1;
if(miso)
temp|=0x01;
sck=0;
mosi=0;
return temp;
sck=0;
reg<<=1;
cs=0;
reg=reg&0x7e;
spi(reg);
spi(da);
cs=1;
uchar temp;
sck=0;
_nop_();
_nop_();
cs=0;
reg<<=1;
reg|=0x80;
spi(reg);
temp=spi(0x00);
cs=1;
return temp;
void fifo_clear()
uchar temp;
temp=resig_read(Control);
temp=temp|0x01;
resig_write(Control,temp);
while(resig_read(FIFOLength)) ;
uchar i,temp;
temp=resig_read(FIFOLength);
if(temp<count)
return 0;
for(i=0;i<count;i++)
temp=resig_read(FIFODaTa);
*(s+i)=temp;
uchar i,temp;
fifo_clear();
temp=*(s+i);
resig_write(FIFODaTa,temp);
uchar inti_1702()
uchar temp;
FM1702rst=1;
delay(0x0a);
FM1702rst=0;
delay(0x0f);
temp=resig_read(Command);
if(temp==0)
resig_write(0x00,0x80);
while(temp);
if(temp==0x00)
return 1;
return 0;
void delay(uchar m) //单次定时为10ms
TMOD=0x01;
while(m--)
TH0=0xdc;
TL0=0x00 ;
TR0=1;
while(!TF0);
TF0=0;
TR0=0;
void card_scan()
uchar temp;
resig_write(CRCResultLSB,0x63);
resig_write(CWConductance,0x3f);
resig_write(BitFraming,0x07);
resig_write(ChannelRedundancy,0x03);
temp=temp&0x7f;
Fbuff[0]=0x52;
fifo_write(1,Fbuff);
resig_write(Command,0x1e);
fifo_clear();
uchar card_type()
uchar temp1,temp2;
// fifo_read(2,UID);
// temp1=UID[0];
// temp2=UID[1];
temp1=resig_read(FIFOLength);
// if((temp1==0x04)||(temp1==0x03)||(temp1==0x05)||(temp1==0x53)&&(temp2==0))
if(temp1==0x02)
return 0x01;
return 0;
uchar card_anticoll() //防冲突函数
uchar temp,i;
Fbuff[0]=0x93;
Fbuff[1]=0x20;
fifo_write(2,Fbuff);
delay(1);
if(temp==0x05)
temp=0;
fifo_read(5,UID);
for(i=0;i<5;i++)
temp=temp^UID;
if(temp==0)
return 1;
return 0;
return 0;
void card_select()
uchar i;
resig_write(Control,0x01) ;
Fbuff[0]=0x93;
Fbuff[0]=0x70;
for(i=0;i<5;i++)
Fbuff[i+2]=UID;
resig_write(ChannelRedundancy,0x0f);
fifo_write(7,Fbuff);
Fbuff[0]=0x60;
Fbuff[1]=m;
fifo_write(6,Fbuff);
resig_write(Command,0x0c);
uchar temp;
resig_write(Command,0x14);
temp=temp&0x08;
if(temp!=0x08)
return 1;
return 0;
uchar temp;
resig_write(Control,0x01);
Fbuff[0]=0x30;
Fbuff[1]=m;
if(temp==16)
return 1;
fifo_read(16,Jbuff);
return 0;
uchar temp;
Fbuff[0]=0xA0;
Fbuff[1]=m;
if(temp==1)
return 1;
fifo_write(16,Fbuff);
return 0;
uchar temp;
resig_write(ChannelRedundancy,0x07);
Fbuff[0]=0xC1;
Fbuff[1]=m;
if(temp==0x01)
change[0]=x;
fifo_write(4,change);
resig_write(Command,0x1a);
return 1;
return 0;
uchar temp;
Fbuff[0]=0xC0;
Fbuff[1]=m;
if(temp==0x01)
return 1;
change[0]=x;
return 0;
uchar loadkey()
uchar temp;
fifo_write(12,changekey);
resig_write(Command,0x19);
temp=resig_read(ErrorFlag);
temp=temp&0x40;
if(temp==0x40)
return 0;
return 0x01;
void card_halt()
Fbuff[0]=0x50;
Fbuff[0]=0x00;
uchar temp;
card_halt();
temp=card_type();
if(temp)
temp=card_anticoll();
if(temp)
card_select();
card_authtication1(picc_k);
if(temp)
temp=card_authtication2();
if(temp)
temp=loadkey();
if(temp)
return 1 ;
return 0;
void main()
uchar temp;
temp=inti_1702();
if(temp==0x01)
led9=0;
card_scan();
temp=resig_read(PrimaryStatus);
temp=temp&0xf0;
if(temp==0x00)
led8=0;
{ card_scan();
temp=card_type();
if(temp==0x01)
led8=~led8;
delay(0x0f);
// card_anticoll() ;
目前程序状态寄存器说明读卡器和卡都是空闲状态,不明白,求解,拜托大侠们了。 |
