这是在ISE12.4上编译,链接到modelsim se6.5仿真的模块代码和测试代码。
//StateMachine.v version 1 状态机模块
module StateMachine(Clock, Reset, A, K2, K1, state);
input Clock, Reset, A;
output K2, K1;
output[1:0] state;
reg K2, K1;
reg[1:0] state;
parameter Idle = 2'b 00,
Start = 2'b 01,
Stop = 2'b 10,
Clear = 2'b 11;
always @(posedge Clock)
if(!Reset)
begin
state <= Idle;
K2 <= 0;
K1 <= 0;
end
case(state)
Idle:
if(A)
begin
state <= Start;
K1 <= 0;
end
begin
state <= Idle;
K2 <= 0;
K1 <= 0;
end
Start:
if(!A) state <= Stop;
else state <= Start;
Stop:
if(A)
begin
state <= Clear;
K2 <= 1;
end
begin
state <= Stop;
K2 <= 0;
K1 <= 0;
end
Clear:
if(!A)
begin
state <= Idle;
K2 <= 0;
K1 <= 0;
end
begin
state <= Clear;
K2 <= 0;
K1 <= 1;
end
default: state <= 2'b xx;
endcase
endmodule
//StateMachineTest.v测试代码
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 10:02:04 07/15/2011
// Design Name: z StateMachine
// Module Name: E:/FPGA Projects/ISE Projects/StateMachine/StateMachineTest.v
// Project Name: StateMachine
// Target Device:
// Tool versions:
// Description:
// Verilog Test Fixture created by ISE for module: StateMachine
// Dependencies:
// Revision:*
// Revision 0.01 - File Created
// Additional Comments:
module StateMachineTest;
// Inputs
reg Clock;
reg Reset;
reg A;
// Outputs
wire K2;
wire K1;
wire [1:0] state;
// Instantiate the Unit Under Test (UUT)
StateMachine uut (
.Clock(Clock),
.Reset(Reset),
.A(A),
.K2(K2),
.K1(K1),
.state(state)
initial
begin
// Initialize Inputs
Clock = 0;
// Wait 100 ns for global reset to finish
forever #5 Clock = ~Clock;//产生驱动时钟
// Add stimulus here
end
initial
begin
A = 0;
forever #4 A = ~A;
end
initial
begin
Reset = 0;
#50
Reset = 1;
end
endmodule
从波形上看,每一个状态所持续的时间是相等的。
//StateMachine.v version 2 只是把case语句中的条件全部变成if(!A),而version1 的条件是一个if(A)下来一个if(!A)间隔出现。 同样的测试代码
output K2, K1;
output[1:0] state;
reg K2, K1;
reg[1:0] state;
Start = 2'b 01,
Stop = 2'b 10,
Clear = 2'b 11;
if(!Reset)
begin
state <= Idle;
K2 <= 0;
K1 <= 0;
end
case(state)
Idle:
if(!A)
begin
state <= Start;
K1 <= 0;
end
begin
state <= Idle;
K2 <= 0;
K1 <= 0;
end
Start:
Stop:
if(!A)
begin
state <= Clear;
K2 <= 1;
end
begin
state <= Stop;
K2 <= 0;
K1 <= 0;
end
Clear:
if(!A)
begin
state <= Idle;
K2 <= 0;
K1 <= 0;
end
begin
state <= Clear;
K2 <= 0;
K1 <= 1;
end
endcase
endmodule
version 1的测试代码的的仿真波形如下
version 1 仿真波形 (原文件名:StateMachineTestWaveV1.png)
version 2 仿真波形如下
version 2 仿真波形 (原文件名:StateMachineTestWaveV2.png)
产生这种仿真波形的原因是什么呢,这两种状态跳变条件的写法有什么不同,会对它的下一级产生追求者以影响 。 |
