发表于 2011-7-15 09:37:29
here is the source file
===============send1.c=======================
//using 1 wire to send serial data
//msb first
//on the rising edge
#include <regx51.h> //we use keil c51
#include "gpio.h"
#include "delay.h" //we use delay
#include "send1.h" //we use send1 protocol
//hardware configuration
//end hardware configuration
//initialize send1
void send1_init(void) {
//IO_SET(SEND1_PORT, SEND1_SCO); //clear sco
//IO_OUT(SEND1_DDR, SEND1_SCO); //sco as output
#define send1_delay() {delay_us(SEND1_DLY);}
//send bit 1
#define send1_1() {IO_CLR(SEND1_PORT, SEND1_SCO); IO_SET(SEND1_PORT, SEND1_SCO);}
//send bit 0
#define send1_0() {IO_CLR(SEND1_PORT, SEND1_SCO); send1_delay(); IO_SET(SEND1_PORT, SEND1_SCO);}
//send a byte
void send1_write(unsigned char dat) {
unsigned char mask = 0x80; //msb first
do {
//initialize the bus - bring SCO to high
IO_SET(SEND1_PORT, SEND1_SCO); //set sco
send1_delay(); //charge up the cap
if (dat & mask) send1_1() //send 1
else send1_0(); //send 0
mask = mask >> 1; //shift to the next bit
} while (mask);
