发表于 2011-8-12 15:45:31
资源: micro2440 , 800x600 彩屏 (GUI_Gdev.c 中修改) ; Nandflash:K9F1G08 (已经单选 #define K9FG08)
效果: 屏幕下方有4个平均分布的长方形,灰色的,有立体感,屏幕是灰白色的 (颜色相近,拍不出相片),其它没有了,
点触摸屏,串口有数据出.
到下面的提示出错,请楼主帮忙分析原因.
* RO 80000000H - 8008641CH; Size: 549916
* RW 8008641CH - 8055B7B8H; Size: 5067676
* ZI 8008647CH - 8055B7B8H; Szie: 5067580
* [00001234][00005678][00000000][00000000]
atoi=805320608,atoi=805320604,strlen=4
abs=-1234,1234
0000_0000: 3F 00 00 EA 12 00 00 EA 17 00 00 EA 22 00 00 EA
0000_0010: 1B 00 00 EA FE FF FF EA 07 00 00 EA 00 00 00 EA
0000_0020: B0 01 00 EA 04 D0 4D E2 01 00 2D E9 E4 05 9F E5
0000_0030: 00 00 90 E5 04 00 8D E5 01 80 BD E8 04 D0 4D E2
* System Startup *
System Build Date: Jul 01 2011
System Build Time: 14:10:31
System Local Time: 2037-8-5 22:02:06
ProcessorInfo:
-> Family: ARM920T
-> String: S3C2440A-40
-> ID: 00002440
-> Clock: 400MHZ
KerelHeapInfo:
-> BaseAddr: 82000000H
-> PageSize: 128Byte
-> TotalSize: 32505855Byte
UserHeapInfo:
-> BaseAddr: 81000000H
-> PageSize: 1048576Byte
-> TotalSize: 16777215Byte
set_intr -> 8 - -7FFF8CC4H
CreateThread -> 82000300H,255
CreateThread -> 82000780H,254
CreateThread -> 82004A00H,16
OS Core Startup
OSStatInit
OSIdleCounterMax =2699165
Kernel_API_Entry: 8004A41CH
FFFE_4000: 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC
FFFE_4010: 04 F0 1F E5 0C 02 01 80 01 04 00 00 00 00 00 00
kernel_api_init
ram_disk_addr_base =80800000H
RegisterDrive -> 0 - 'RAM Disk'
disk->get_sector_size=512
#### -> fmt=0 - 512,512
f_mount -> 0 - 0
Init. Frequency is 200000Hz
In idle
CMD55:rSDICSTA=0xc00, rSDIRSP0=0x0
Initialize fail ------------------> 出错了
No Card assertion ------------------> 必须使用SD卡?
SD Card Init Fail! ------------------> 必须使用SD卡?
**** fs info ****
drive: 0
fs_type: FAT16
c_size: 2
s_size: 512
n_fats: 1
wflag: 0
n_rootdir: 512
sects_fat: 34
max_clust: 8159
free_clust: 8157
fat_base: 2
dir_base: 36
data_base: 68
TotalSize: 8320000 Byte
FreeSize: 8352768 Byte
RegisterDevice -> 'COM1'
GUI_Init
GWIS_API_Entry: 800490DCH
FFFE_8000: 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC
FFFE_8010: 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC 33 CC
gwis_api_init
LCDInit End(800x600,16bpp)
ScreenWidth=800;ScrHeigh=600;Bpp=16
GUI_Font Init OK!
GUI_Resource_Init!
SetWallpaper -> 'B:\kernel\res\desktop.jpg'
GUI_Timer_Init!
GUI_Window_Init!
RegisterClass -> 'button' - 00000000H
RegisterClass -> 'static' - 00000000H
RegisterClass -> 'edit' - 00000000H
RegisterClass -> 'scrollbar' - 00000000H
RegisterClass -> 'listbox' - 00000000H
RegisterClass -> 'imagebox' - 00000000H
RegisterClass -> 'toolbar' - 00000000H
CreateThread -> 820F0C00H,128
ts_load_config Error ------------------> 出错了
CreateThread -> 820F1E80H,200
CreateThread -> 820F6100H,128
CreateThread -> 820F7380H,128
MultiMedia_API_Entry: 8004AA9CH
FFFE_C000: 04 F0 1F E5 34 00 03 80 00 0C 00 00 00 00 00 00
FFFE_C010: 04 F0 1F E5 38 00 03 80 01 0C 00 00 00 00 00 00
multimedia_api_init
CreateThread -> 820FB600H,128
CreateThread -> 820FC880H,129
CreateThread -> 820FDB00H,130
CreateThread -> 820FED80H,131
CreateThread -> 82107000H,132
CreateThread -> 82108280H,133
CreateThread -> 82109500H,134
CreateThread -> 8210A780H,135
CreateThread -> 8210BA00H,136
CreateThread -> 8210CC80H,137
CreateThread -> 8210DF00H,138
DestroyThread! - 820FDB00H
DestroyThread! - 82108280H
DestroyThread! - 82109500H
DestroyThread! - 8210A780H
DestroyThread! - 8210BA00H
DestroyThread! - 8210CC80H
TouchPanel Thread Startup!
Desktop -> WM_ERASEBKGND - 0,0,800,600
GUI_Desktop Start!
Desktop->pMsgQ=820FCC80H
SetTimer -> 820FD080H - 500
DestroyThread! - 820FED80H
SetTimer -> 820FEA80H - 300
DestroyThread! - 820FC880H
**** Main Menu ****
Select Function(0~5):
[0]. USB MassStoeage
[1]. GUI Demo
[2]. TouchScreen Calibrate
[3]. FS Test
[4]. TCB View
[5]. Custom
