发表于 2011-6-29 15:44:06
启动文件如下:
; EXCEPTION VECTORS & STARTUP CODE
; File : cstartup.s
; For : ARM7 or ARM9
; Toolchain : IAR EWARM V5.10 and higher
; MACROS AND DEFINIITIONS
; Mode, correspords to bits 0-5 in CPSR
MODE_BITS DEFINE 0x1F ; Bit mask for mode bits in CPSR
USR_MODE DEFINE 0x10 ; User mode
FIQ_MODE DEFINE 0x11 ; Fast Interrupt Request mode
IRQ_MODE DEFINE 0x12 ; Interrupt Request mode
SVC_MODE DEFINE 0x13 ; Supervisor mode
ABT_MODE DEFINE 0x17 ; Abort mode
UND_MODE DEFINE 0x1B ; Undefined Instruction mode
SYS_MODE DEFINE 0x1F ; System mode
; ARM EXCEPTION VECTORS
SECTION .intvec:CODE:NOROOT(2)
PUBLIC __vector
PUBLIC __iar_program_start
IMPORT OS_CPU_ARM_ExceptUndefInstrHndlr
IMPORT OS_CPU_ARM_ExceptSwiHndlr
IMPORT OS_CPU_ARM_ExceptPrefetchAbortHndlr
IMPORT OS_CPU_ARM_ExceptDataAbortHndlr
IMPORT OS_CPU_ARM_ExceptIrqHndlr
IMPORT OS_CPU_ARM_ExceptFiqHndlr
ARM
__vector:
LDR PC, [PC,#24] ; Absolute jump can reach 4 GByte
LDR PC, [PC,#24] ; Branch to undef_handler
LDR PC, [PC,#24] ; Branch to swi_handler
LDR PC, [PC,#24] ; Branch to prefetch_handler
LDR PC, [PC,#24] ; Branch to data_handler
__vector_0x14:
DC32 0 ; Reserved
LDR PC, [PC,#24] ; Branch to irq_handler
LDR PC, [PC,#24] ; Branch to fiq_handler
DC32 __iar_program_start
DC32 OS_CPU_ARM_ExceptUndefInstrHndlr
DC32 OS_CPU_ARM_ExceptSwiHndlr
DC32 OS_CPU_ARM_ExceptPrefetchAbortHndlr
DC32 OS_CPU_ARM_ExceptDataAbortHndlr
DC32 0
DC32 OS_CPU_ARM_ExceptIrqHndlr
DC32 OS_CPU_ARM_ExceptFiqHndlr
; LOW-LEVEL INITIALIZATION
SECTION FIQ_STACK:DATA:NOROOT(3)
SECTION IRQ_STACK:DATA:NOROOT(3)
SECTION SVC_STACK:DATA:NOROOT(3)
SECTION ABT_STACK:DATA:NOROOT(3)
SECTION UND_STACK:DATA:NOROOT(3)
SECTION CSTACK:DATA:NOROOT(3)
SECTION text:CODE:NOROOT(2)
REQUIRE __vector
EXTERN ?main
EXTERN lowlevel_init
__iar_program_start:
; STACK POINTER INITIALIZATION
MRS r0,cpsr ; Original PSR value
BIC r0,r0,#MODE_BITS ; Clear the mode bits
ORR r0,r0,#SVC_MODE ; Set SVC mode bits
MSR cpsr_c,r0 ; Change the mode
LDR sp,=SFE(SVC_STACK) ; End of SVC_STACK
ORR r0,r0,#UND_MODE ; Set UND mode bits
LDR sp,=SFE(UND_STACK) ; End of UND_STACK
ORR r0,r0,#ABT_MODE ; Set ABT mode bits
LDR sp,=SFE(ABT_STACK) ; End of ABT_STACK
ORR r0,r0,#FIQ_MODE ; Set FIQ mode bits
LDR sp,=SFE(FIQ_STACK) ; End of FIQ_STACK
ORR r0,r0,#IRQ_MODE ; Set IRQ mode bits
LDR sp,=SFE(IRQ_STACK) ; End of IRQ_STACK
ORR r0,r0,#SYS_MODE ; Set System mode bits |
