如题 Testbench代码如下
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY uart_bench IS
END uart_bench;
ARCHITECTURE behavior OF uart_bench IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT uart_top
PORT(
rs232_rx : IN std_logic;
rs232_tx : OUT std_logic;
clk : IN std_logic;
rst_n : IN std_logic
END COMPONENT;
--Inputs
signal rs232_rx : std_logic := '0';
signal clk : std_logic := '0';
signal rst_n : std_logic := '0';
--Outputs
signal rs232_tx : std_logic;
-- Clock period definitions
constant clk_period : time := 20 ns;
constant pbit_time : time := 104166 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: uart_top PORT MAP (
rs232_rx => rs232_rx,
rs232_tx => rs232_tx,
clk => clk,
rst_n => rst_n
stim_proc: process
begin
rst_n <= '1';
wait for 50 ns;
rst_n <= '0';
wait for 100 ns;
rst_n <= '1';
wait for 100*pbit_time;
end process;
process (clk,rst_n)
begin
IF rst_n = '0' THEN
clk <= '0';
-- rs232_rx <= '1';
ELSE
clk <= NOT clk AFTER 20 ns;
END IF;
end process;
process
begin
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '0';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '0';
wait for pbit_time;
rs232_rx <= '0';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '0';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '0';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
rs232_rx <= '1';
wait for pbit_time;
end process;
END;
是不是要把其它4个小模块给例化到Testbench中啊??? 多模块的联合仿真到底该怎么做啊???
![](http://cache.amobbs.com/bbs_upload782111/files_42/ourdev_653067S403QC.jpg)
顶层模块图(源自特权_uart) (原文件名:my_uart_top.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_42/ourdev_653068EMGVO4.png)
ModelsimSE中的信号列表 (原文件名:signal.png)
如图 怎么才能在ModelsimSE的信号列表中看到 bps_start,clk_bps,rx_int等这些中间信号?? |
