模仿写的UART,但只在发送一个字母或数字时正常,传输一串字母却乱码?为什么?
module uart2(clk,rst_n,rs_232_rx,rs_232_tx);
input clk;
input rst_n;
input rs_232_rx;
output rs_232_tx;
wire clk_bps_tx,clk_bps_rx;
wire bps_start_tx,bps_start_rx;
wire rx_int;
wire [7:0] rx_data;
speed_select speed_rx(
.clk(clk),
.rst_n(rst_n),
.bps_start(bps_start_rx),
.clk_bps(clk_bps_rx)
uart_rx uart_rx(
.clk(clk),
.rst_n(rst_n),
.clk_bps(clk_bps_rx),
.rs232_rx(rs_232_rx),
.rx_data(rx_data),
.rx_int(rx_int)
speed_select speed_tx(
.clk(clk),
.rst_n(rst_n),
.bps_start(bps_start_tx),
.clk_bps(clk_bps_tx)
uart_tx uart_tx(
.clk(clk),
.rst_n(rst_n),
.clk_bps(clk_bps_tx),
.rx_int(rx_int),
.rx_data(rx_data),
.rs232_tx(rs_232_tx)
endmodule
module speed_select(bps_start,clk,rst_n,clk_bps);
input clk; //系统时钟50M
input bps_start; //波特率开始信号
input rst_n; //异步复位
output clk_bps; //
parameter BPS_PARA = 5207;
parameter BPS_PARA_2 = 2603;
reg [12:0] cnt;
reg clk_bps_r;
always @ (posedge clk or negedge rst_n)
begin
if(!rst_n)
cnt <= 13'd0;
else if (cnt == BPS_PARA || !bps_start)
cnt <= 13'd0;
cnt <= cnt + 1'd1;
end
begin
if(!rst_n)
clk_bps_r <= 1'd0;
else if(cnt == BPS_PARA_2)
clk_bps_r <= 1'd1;
clk_bps_r <= 1'd0;
end
assign clk_bps = clk_bps_r;
endmodule
module uart_rx(clk,clk_bps,rs232_rx,rst_n,bps_start,rx_int,rx_data);
input clk;
input clk_bps;
input rs232_rx;
input rst_n;
output bps_start;
output rx_int;
output [7:0] rx_data;
reg rs232_rx0,rs232_rx1,rs232_rx2,rs232_rx3;
wire neg_rs232_rx;
begin
if(!rst_n)
begin
rs232_rx0 <= 1'd0;
rs232_rx1 <= 1'd0;
rs232_rx2 <= 1'd0;
rs232_rx3 <= 1'd0;
end
begin
rs232_rx0 <= rs232_rx;
rs232_rx1 <= rs232_rx0;
rs232_rx2 <= rs232_rx1;
rs232_rx3 <= rs232_rx2;
end
end
assign neg_rs232_rx = rs232_rx3 && rs232_rx2 && ~rs232_rx1 && ~rs232_rx0;
reg bps_start_r;
reg rx_int;
reg [3:0] num;
begin
if(!rst_n)
begin
bps_start_r <= 1'd0;//bps_start_r <= 1'dz;
rx_int <= 1'd0;
end
else if(neg_rs232_rx)
begin
bps_start_r <= 1'd1;
rx_int <= 1'd1;
end
else if(num == 4'd12)
begin
rx_int <= 1'd0;
end
end
assign bps_start = bps_start_r;
reg [7:0] rx_data_r;
reg [7:0] rx_temp_data;
begin
if(!rst_n)
begin
rx_data_r <= 8'd0;
rx_temp_data <= 8'd0;
num <= 4'd0;
end
else if(rx_int)
if(clk_bps)
begin
num <= num + 4'd1;
case (num)
4'd1 : rx_temp_data[0] <= rs232_rx;
4'd2 : rx_temp_data[1] <= rs232_rx;
4'd3 : rx_temp_data[2] <= rs232_rx;
4'd4 : rx_temp_data[3] <= rs232_rx;
4'd5 : rx_temp_data[4] <= rs232_rx;
4'd6 : rx_temp_data[5] <= rs232_rx;
4'd7 : rx_temp_data[6] <= rs232_rx;
4'd8 : rx_temp_data[7] <= rs232_rx;
default : ;
endcase
end
begin
num <= 4'd0;
rx_data_r <= rx_temp_data;
end
end
assign rx_data = rx_data_r;
endmodule
module uart_tx(clk,rst_n,clk_bps,rx_int,rx_data,bps_start,rs232_tx);
input clk;
input rst_n;
input clk_bps;
input rx_int;
input [7:0] rx_data;
output bps_start;
output rs232_tx;
reg rx_int0,rx_int1,rx_int2,rx_int3;
wire neg_rx_int;
begin
if(!rst_n)
begin
rx_int0 <= 1'd0;
rx_int1 <= 1'd0;
rx_int2 <= 1'd0;
rx_int3 <= 1'd0;
end
begin
rx_int0 <= rx_int;
rx_int1 <= rx_int0;
rx_int2 <= rx_int1;
rx_int3 <= rx_int2;
end
end
assign neg_rx_int = rx_int3 && rx_int2 && ~rx_int1 && ~rx_int0;
reg [7:0] tx_data;
reg bps_start_r;
reg [3:0] num;
reg tx_en;
begin
if(!rst_n)
begin
tx_en <= 1'd0;
tx_data <= 8'd0;
end
else if (neg_rx_int)
begin
tx_en <= 1'd1;
tx_data <= rx_data;
end
else if(num == 4'd11) //else if(num == 4'd12)
begin
tx_en <= 1'd0;
tx_data <= 8'd0;
end
end
reg rs232_tx_r;
begin
if(!rst_n)
begin
rs232_tx_r <= 1'd0;
num <= 4'd0;
end
else if(tx_en)
begin
if(clk_bps)
begin
num <= num + 4'd1;
case (num)
4'd0 : rs232_tx_r <= 1'd0;
4'd1 : rs232_tx_r <= tx_data[0];
4'd2 : rs232_tx_r <= tx_data[1];
4'd3 : rs232_tx_r <= tx_data[2];
4'd4 : rs232_tx_r <= tx_data[3];
4'd5 : rs232_tx_r <= tx_data[4];
4'd6 : rs232_tx_r <= tx_data[5];
4'd7 : rs232_tx_r <= tx_data[6];
4'd8 : rs232_tx_r <= tx_data[7];
4'd9 : rs232_tx_r <= 1'd1;
default : ;//rs232_tx_r <= 1'd1;
endcase
end
else if(num == 4'd11) // else if(num == 4'd12)
begin
num <= 4'd0;
end
end
end
assign rs232_tx = rs232_tx_r;
endmodule |
