开发环境: Fedora 15
交叉编译工具链: arm-none-eabi-gcc (Sourcery G++ Lite 2011.03-42) 4.5.2
仿真器: JLink v7
开发工具: openocd 0.4.0
用的libmaple的库,范例代码main.cpp,网站:leaflabs.com
本来问题是发到他们论坛上的,暂时也没有人回,就直接粘过来了,莫太见怪额 :P
Hi, I am attracted by the architecture of libmaple, so planning to try it on my board (stm32f103rbt6). However, it comes up with a Handler HardFault while downloading use openocd.
Here is my steps:
$ git clone git://github.com/leaflabs/libmaple.git
$ cd libmaple
$ cp main.cpp.example main.cpp
$ make flash
Because I am using jlink, then I modified support/openocd/flash_0.4.cfg as:
$ git diff
diff --git a/support/openocd/flash_0.4.cfg b/support/openocd/flash_0.4.cfg
index 32c06c6..d99c48c 100644
--- a/support/openocd/flash_0.4.cfg
+++ b/support/openocd/flash_0.4.cfg
@@ -1,9 +1,10 @@
# script for stm32
-interface ft2232
-ft2232_device_desc "Olimex OpenOCD JTAG"
-ft2232_layout olimex-jtag
-ft2232_vid_pid 0x15ba 0x0003
+interface jlink
+#interface ft2232
+#ft2232_device_desc "Olimex OpenOCD JTAG"
+#ft2232_layout olimex-jtag
+#ft2232_vid_pid 0x15ba 0x0003
After that, do
$ openocd -f support/openocd/flash_0.4.cfg
Results below is printed
Open On-Chip Debugger 0.4.0 (2011-02-09-04:28)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
1000 kHz
jtag_nsrst_delay: 100
jtag_ntrst_delay: 100
srst_only separate srst_gates_jtag srst_open_drain
Info : J-Link initialization started / target CPU reset initiated
Info : J-Link ARM V7 compiled Jun 30 2009 11:05:27
Info : JLink caps 0xb9ff7bbf
Info : JLink hw version 70000
Info : JLink max mem block 9152
Info : Vref = 3.377 TCK = 1 TDI = 0 TDO = 1 TMS = 0 SRST = 0 TRST = 0
Info : J-Link JTAG Interface ready
Info : clock speed 1000 kHz
Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : stm32.cpu: hardware has 6 breakpoints, 4 watchpoints
Warn : stm32.cpu -- clearing lockup after double fault
Halting...
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08007844 msp: 0x20005000
Unlocking flash...
Info : device id = 0x20036410
Info : flash size = 128kbytes
cleared protection for sectors 0 through 127 on flash bank 0
Erasing...
erased address 0x08000000 (length 131072) in 0.040999s (3122.027 kb/s)
Flashing image...
wrote 13136 bytes from file build/maple.bin to flash bank 0 at offset 0x00000000 in 0.924966s (13.869 kb/s)
Verifying image...
verified 13136 bytes in 0.529968s (24.205 kb/s)
Checksum verified, resetting chip
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x01000003 pc: 0x08007064 msp: 0x20004fe0
Daemon shutdown
shutdown command invoked
So, I don't know what on earth resulted in this. Something wrong about using openocd? Or linkerscripts? Need maple-bootloader? Any ideas?
Thanks a lot.
Support your excellent works as before. :P
I tried to download flash step by step with openocd:
> init
> targets
TargetName Type Endian TapName State
0* stm32.cpu cortex_m3 little stm32.cpu running
> reset halt
xPSR: 0x01000000 pc: 0x080000d4 msp: 0x20000100
> flash erase_address 0x08000000 0x20000
erased address 0x08000000 (length 131072) in 0.038003s (3368.155 kb/s)
> flash write_image maple.bin 0x08000000 bin
not enough working area available(requested 16384, free 16336)
wrote 13136 bytes from file maple.bin in 1.157949s (11.078 kb/s)
> verify_image maple.bin 0x08000000 bin
verified 13136 bytes in 0.528980s (24.251 kb/s)
> reset halt
> resume
in maple.map:
.text 0x08007060 0x60 build/./libmaple/exc.o
0x08007060 __exc_nmi
0x08007064 __exc_hardfault
0x08007068 __exc_memmanage
0x0800706c __exc_busfault
0x08007070 __exc_usagefault
.text 0x08007844 0x10 ./support/ld/libcs3_stm32_med_density.a(start.o)
0x08007844 _start
.text 0x08007854 0x108 ./support/ld/libcs3_stm32_med_density.a(start_c.o)
0x08007854 __cs3_start_c
According to above information, I find that after "flash write_image" & "verify_image", "reset halt", the "pc: 0x08007844" is no problem, exactly the "_start" entry point.
But just after that I try "resume" or "reset run", it went into HardFault straight forward.
原帖链接:
http://forums.leaflabs.com/topic.php?id=872&replies=2#post-5337 |
