发表于 2011-8-3 01:24:46
经测试,将“CHC_Compiler”添加到AD10.INI 文件中,然后生成的License文件可以激活CHC(用C语言设计FPGA)的功能。
简单尝试一下加法运算。
(原文件名:1.PNG)
(原文件名:2.PNG)
(原文件名:4.PNG)
// TASKING HDL generator v1.3r1 Build 088
// options: -f ProjectOutputs\PCB Configuration\Main_Designator\Main_Designator.vhd.opt --toplevel=Main_Designator --wishbone-address-width=0 --wishbone-prefix= --vhdl=ProjectOutputs\PCB Configuration\Main_Designator\Main_Designator.vhd --verilog=ProjectOutputs\PCB Configuration\Main_Designator\Main_Designator.v
module Main_Designator
DATA3,
DATA4,
DATA5
input [7:0] DATA3;
input [7:0] DATA4;
output [7:0] DATA5;
wire [7:0] DATA3;
wire [7:0] DATA4;
wire [7:0] DATA5;
chc_Main_Designator_FunctionName FunctionName_0 (
.DATA5( DATA5 ),
.DATA3( DATA3 ),
.DATA4( DATA4 )
endmodule // Main_Designator
module chc_Main_Designator_ALU8
in0,
in1,
oper,
retval
input [7:0] in0;
input [7:0] in1;
input oper;
output [7:0] retval;
wire [7:0] in0;
wire [7:0] in1;
wire oper;
wire [7:0] retval;
assign retval = extract_8_9_8(({in0, oper} + {in1 ^ {8{oper}}, oper}));
function [7:0] extract_8_9_8;
input [8:0]x;
extract_8_9_8 = x[8:1];
endfunction
endmodule // chc_Main_Designator_ALU8
module chc_Main_Designator_FunctionName
DATA3,
DATA4,
DATA5
input [7:0] DATA3;
input [7:0] DATA4;
output [7:0] DATA5;
wire [7:0] ALU8_0_in0;
wire [7:0] ALU8_0_in1;
wire [7:0] ALU8_0_retval;
wire [7:0] DATA3;
wire [7:0] DATA4;
wire [7:0] DATA5;
wire [7:0] w1;
wire [7:0] w2;
wire [7:0] w3;
chc_Main_Designator_ALU8 ALU8_0 (
.in0( ALU8_0_in0 ),
.in1( ALU8_0_in1 ),
.retval( ALU8_0_retval ),
.oper( 1'b0 )
assign ALU8_0_in0 = DATA3;
assign ALU8_0_in1 = DATA4;
assign DATA5 = ALU8_0_retval;
endmodule // chc_Main_Designator_FunctionName
// end verilog |
