#include <avr/io.h>
#include <avr/twi.h>
#include <avr/signal.h>
#define fosc 7372800
#define sla 0xa0
#define slav 0xa2
#define TW_WRITE 0
#define TW_READ 1
#define max 3
#define uint unsigned int
#define ulong unsigned long
void Twi_Init( void )
TWBR = 0x20;//设置波特率
TWSR &= 0xfc;//设置预分频因子,则SCL频率为92160Hz
功 能:将读出的时间数据的无关位屏蔽掉
说 明:hym8563时钟寄存器的有些无关位的状态是不定的,所以应该将无效位屏蔽掉
void Datajust(void)
trdata[0]=trdata[0]&0x7f;
trdata[1]=trdata[1]&0x7f;
trdata[2]=trdata[2]&0x3f;
trdata[3]=trdata[3]&0x3f;
trdata[4]=trdata[4]&0x07;
trdata[5]=trdata[5]&0x1f;
trdata[6]=trdata[6]&0xff;
uchar FM24C256_Write( uint address,uchar write_data )
uchar twst,n=0x0,rv=0x1;
restart:
if(n++>=max)
goto error;
begin:
TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN);//发送开始信号
while((TWCR & _BV(TWINT))==0x0);//等待发送完毕
switch((twst = TW_STATUS))
case TW_REP_START://有可能出现
case TW_START:
case TW_MT_ARB_LOST:
goto begin;
default:
goto error;
TWDR = sla | TW_WRITE;//发送SLA+W
TWCR = _BV(TWINT) | _BV(TWEN);//清TWINT,开始传输
while((TWCR & _BV(TWINT))==0x0);//等待传输完毕
case TW_MT_SLA_ACK:
case TW_MT_SLA_NACK://器件忙,有可能处于内部写周期
goto restart;
goto begin;
default:
goto error;
TWDR = address>>8;//传输地址高8位
case TW_MT_DATA_ACK:
case TW_MT_DATA_NACK:
goto quit;
goto begin;
default:
goto error;
TWDR = address;//传输地址低8位
goto quit;
goto begin;
default:
goto error;
TWDR = write_data;
default:
goto error;
quit:
TWCR = _BV(TWINT) | _BV(TWSTO) | _BV(TWEN);//发送停止信号
return rv;
error:
rv=0x0;
goto quit;
uchar FM24C256_Read( uint address )
restart:
if(n++>=max)
goto error;
begin:
case TW_START:
goto begin;
default:
goto error;
case TW_MT_SLA_ACK:
goto restart;
goto begin;
default:
goto error;
goto quit;
goto begin;
default:
goto error;
goto quit;
goto begin;
default:
goto error;
TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN);//发送(重新)开始信号
case TW_REP_START://正确的状态
goto begin;
default:
goto error;
TWDR = sla | TW_READ;//发送SLA+R
case TW_MR_SLA_ACK:
case TW_MR_SLA_NACK://器件忙,有可能处于内部写周期
goto restart;
case TW_MR_ARB_LOST:
goto begin;
default:
goto error;
TWCR = _BV(TWINT) | _BV(TWEN) ;//清TWINT,开始传输
case TW_MR_DATA_NACK:
rv = TWDR;
default:
goto error;
quit:
return rv;
error:
rv=0x0;
goto quit;
uchar SetHym8563(uchar suba,uchar *s,uchar no )
uchar twst,i,n=0x0,rv=0x1;
restart:
if(n++>=max)
goto error;
begin:
case TW_START:
goto begin;
default:
goto error;
TWDR = slav | TW_WRITE;//发送SLAV+W
case TW_MT_SLA_ACK:
goto restart;
goto begin;
default:
goto error;
TWDR = suba | TW_WRITE;//发送SUBA+W
case TW_MT_DATA_NACK://器件忙,有可能处于内部写周期
goto restart;
goto begin;
default:
goto error;
for(i=0;i<no;i++)
TWDR = *s | TW_WRITE;
goto restart;
goto begin;
default:
goto error;
s++;
quit:
return rv;
error:
rv=0x0;
goto quit;
uchar GetHym8563(uchar suba,uchar *s,uchar no)
restart:
if(n++>=max)
goto error;
begin:
case TW_START:
goto begin;
default:
goto error;
case TW_MT_SLA_ACK:
goto restart;
goto begin;
default:
goto error;
goto restart;
goto begin;
default:
goto error;
goto begin;
default:
goto error;
TWDR = slav | TW_READ;//发送SLAV+R
case TW_MR_SLA_ACK:
goto restart;
goto begin;
default:
goto error;
for(i=0;i<no;i++)
if(i==(no-1))
TWCR = _BV(TWINT) | _BV(TWEN) ;//清TWINT,开始传输(无应答)
TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWEA) ;//清TWINT,开始传输(有应答)
case TW_MR_DATA_ACK:
*s = TWDR;
s++;
default:
goto error;
quit:
return rv;
error:
rv=0x0;
goto quit;
