最近刚把linux-2.6.38移植到s3c2440上 用arm-linux-gcc4.3.3交叉编译器 busybox-18.2 tslib-1.4.1 移植成功 不过移植QT4.7.0到内核时一般程序可也运行,但是用movie读文件时出现QThread::start: Thread creation error: Resource temporarily unavailable 错误 该怎么解决呢
Booting Linux ...
Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00300000 ... Copy Ker.
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.38.6-NETC (root@netcreate-Crestline-ICH8M) (gcc version 4.3.31
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: SMDK2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
Kernel command line: root=/dev/mtdblock2 ro init=/bin/bash console=ttySAC0
PID hash table entries: 64 (order: -4, 256 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 16MB = 16MB total
Memory: 12132k/12132k available, 4252k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc1800000 - 0xf6000000 ( 840 MB)
lowmem : 0xc0000000 - 0xc1000000 ( 16 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0022000 ( 104 kB)
.text : 0xc0022000 - 0xc039a530 (3554 kB)
.data : 0xc039c000 - 0xc03c4ce0 ( 164 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:85 nr_irqs:85 85
irq: clearing pending ext status 00080000
irq: clearing subpending status 00000002
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
pid_max: default: 32768 minimum: 301
CPU: Testing write buffer coherency: ok
gpiochip_add: gpios 288..303 (GPIOK) failed to register
gpiochip_add: gpios 320..334 (GPIOL) failed to register
gpiochip_add: gpios 352..353 (GPIOM) failed to register
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c1808000, irq 33
DMA channel 1 at c1808040, irq 34
DMA channel 2 at c1808080, irq 35
DMA channel 3 at c18080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 97 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.23.
cfg80211: Calling CRDA to update world regulatory domain
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
msgmni has been set to 23
alg: No test for stdrng (krng)
io scheduler noop registered (default)
Console: switching to colour frame buffer device 40x30
fb0: s3c2410fb frame buffer device
s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c24xx-nand s3c2440-nand: Tacls=1, 10ns Twrph0=3 30ns, Twrph1=1 10ns
s3c24xx-nand s3c2440-nand: NAND ECC disabled
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-b)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 681 at 0x000005520000
Bad eraseblock 1417 at 0x00000b120000
cmdlinepart partition parsing not available
Creating 3 MTD partitions on "NAND":
0x000000000000-0x000000040000 : "NETC_uboot"
0x000000200000-0x000000400000 : "NETC_kernel"
0x000000400000-0x00000ff80000 : "NETC_yaffs2"
dm9000 Ethernet Driver, V1.31
usbmon: debugfs is not available
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.38.6-NETC ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usblp
usbcore: registered new interface driver cdc_wdm
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mousedev: PS/2 mouse device common for all mice
NETC2440 TouchScreen successfully loaded
input: NETC2440 TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
i2c /dev entries driver
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
yaffs: dev is 32505858 name is "mtdblock2" ro
yaffs: passed flags ""
VFS: Mounted root (yaffs filesystem) readonly on device 31:2.
Freeing init memory: 104K
Failed to execute /bin/bash. Attempting defaults...
hwclock: can't open '/dev/misc/rtc': No such file or directory
insmod: can't read '/lib/input-polldev.ko': No such file or directory
insmod: can't read '/lib/mac80211.ko': No such file or directory
insmod: can't read '/lib/rt2x00lib.ko': No such file or directory
insmod: can't read '/lib/rt2x00usb.ko': No such file or directory
insmod: can't read '/lib/rt73usb.ko': No such file or directory
insmod: can't read '/lib/zd1211rw.ko': No such file or directory
insmod: can't read '/lib/ov9650.ko': No such file or directory
/etc/init.d/rcS: line 42: net_set: Permission denied
/etc/rc.d/init.d/leds: line 16: led-player: not found
/etc/rc.d/init.d/httpd: line 16: /sbin/boa: not found
Please press Enter to activate this console. Start Qt-4.7
[root@NETCreate /]#
[root@NETCreate /]# cd opt/qt-4.7/bin/
[root@NETCreate bin]# ./movie -qws
QThread::start: Thread creation error: Resource temporarily unavailable |
