发表于 2011-9-16 01:15:31
回复【96楼】liuweiele Liuwei
没改SD驱动居然也可以,o(∩_∩)o 哈哈,4G的卡
串口终端信息如下:
* RO 80000000H - 8008C858H; Size: 575576
* RW 8008C858H - 8052301CH; Size: 4810692
* ZI 8008C940H - 8052301CH; Szie: 4810460
* [00001234][00005678][00000000][00000000]
atoi=1,atoi=23,strlen=4
abs=1234,1234
* System Startup *
Version:0.0.1 (2011/07/09)
System Build Date: Jul 22 2011
System Build Time: 17:39:22
System Local Time: 2000-9-16 00:57:24
ProcessorInfo:
-> Family: ARM1176JZ
-> String: S3C6410X-66
-> ID: 00006410
-> Clock: 532MHZ
KerelHeapInfo:
-> BaseAddr: 83000000H
-> PageSize: 128Byte
-> TotalSize: 82837503Byte
UserHeapInfo:
-> BaseAddr: 81000000H
-> PageSize: 1048576Byte
-> TotalSize: 33554431Byte
set_intr -> 2 - -7FFF4540H
CreateThread -> 83000300H,255
CreateThread -> 83000780H,254
CreateThread -> 83004A00H,16
OS Core Startup
OSStatInit
OSIdleCounterMax =3017873
Kernel_API_Entry: 800521C4H
FFFE_4000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FFFE_4010: 04 F0 1F
E5 6C 84 01 80 01 04 00 00 00 00 00 00
kernel_api_init
ram_disk_addr_base =80800000H
RegisterDrive -> 0 - 'RAM Disk'
disk->get_sector_size=512
#### -> fmt=0 - 512,512
f_mount -> 0 - 0
Enter to the Idle State
CMD8 Support
Voltage range: 2.7V ~ 3.4V
High Capacity Card
S
D Ready
Product Name : SD04G�
=> RCA=0x8dcb
Enter to the Stand-by State
********* C
ard Info *********
READ_BL_LEN: 9
READ_BL_PARTIAL: 0
C_SIZE: 0
C_SIZE_M
ULT: 4
One Block Size: 512 Byte
Total Card Size: 1 MByte
SD_Init_End
RegisterDr
ive -> 1 - 'SD Card'
f_mount -> 1 - 0
NandFlash Chip Id = ECD3H
RegisterDrive -> 2 - 'NandFlash'
nand_disk_open
disk->get_sector_size=2048
#### -> fmt=2 - 0,2048
f_mount -> 2 - 13
**** fs info ****
drive:
0
fs_type: FAT16
c_size: 2
s_size: 512
n_fats: 1
wflag: 0
id:
1
n_rootdir: 512
sects_fat: 33
n_fatent: 8160
free_clust: 8158
fat_base: 1
dir_base: 34
data_base: 66
TotalSize: 8322048 Byte
FreeSize: 8353792 Byte
**** fs info ****
drive:
1
fs_type: FAT32
c_size: 8
s_size: 512
n_fats: 2
wflag: 0
id:
2
n_rootdir: 0
sects_fat: 7287
n_fatent: 932610
free_clust: 52166
fat_base:
1938
dir_base: 2
data_base: 16512
TotalSize: -483450880
Byte
FreeSize: 213671936 Byte
**** fs info ****
drive:
2
fs_type: Unknow
c_size: 0
s_size: 2048
n_fats: 0
wflag: 0
id:
0
n_rootdir: 0
sects_fat: 0
n_fatent: 0
free_clust: 0
fat_base: 0
dir_bas
e: 0
data_base: 0
TotalSize: -483450880 Byte
RegisterDevice -> 'COM1'
RegisterDevice -> 'COM3'
ALCO_Dev_PowerUp
RegisterDevice -> 'ALCO'
set_intr -> 0 - -7FFFBB58H
RegisterDevice -> 'COIN_SELECTOR'
set_intr -> 1 - -7FFF4DACH
DM9000AE ChipId is 90000a46
RegisterDevice -> 'DM9000'
GUI_Init
GWIS_API_Entry: 80050E84H
FFFE_8000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FFFE_8010: 00 00 00
gwis_api_init
LCDInit End(480x272,24bpp)
swi_add -> 0
a=1,b=2,c=3,d=4,e=5,e=6
ScreenWidth=480;ScrHeigh=272;Bpp=24
GUI_Font Init OK!
GUI_Resource_Init!
SetWallpap
er -> 'B:\kernel\res\desktop.jpg'
GUI_Timer_Init!
GUI_Window_Init!
RegisterClass -> 'button' - 00000000H
RegisterClas
s -> 'static' - 00000000H
RegisterClass -> 'edit' - 00000000H
RegisterClass -> 'sc
rollbar' - 00000000H
RegisterClass -> 'listbox' - 00000000H
RegisterClass -> 'imag
ebox' - 00000000H
RegisterClass -> 'toolbar' - 00000000H
CreateThread -> 83086400H
,128
KeyBoard Init
ts_hard_init.
0000_0000: 8D 3F 82 0C 57 09 9D 03 54 09 A7 03 3E 06 96 0C
0000_0010: 48 06 00
08 40 00 00 00 20 70 00 00 00 00 00 00
TouchScreen XY Ref=RightDown.
TS_LUAddata
=3202, 2391
TS_RUAddata =925, 2388
TS_RDAddata =935, 1598
TS_LDAddata =3222, 1608
T
S_XYSwap =0
ts_org =2
CreateThread -> 83087680H,200
CreateThread -> 8308B900H,128
CreateThread -> 8308CB80H,128
MultiMedia_API_Entry: 80052854H
FFFE_C000: 04 F0 1F E5 BC E1 01 80 00 0C 00 00 00 00 00 00
FFFE_C010: 04 F0 1F
E5 C0 E1 01 80 01 0C 00 00 00 00 00 00
multimedia_api_init
CreateThread -> 83090E00H,128
CreateThread -> 83092080H,129
CreateThread -> 83093300H,130
CreateThread -> 83094580H,131
CreateThread -> 8309C800H,2
CreateThread -> 8309DA80H,133
CreateThread -> 8309ED00H,134
CreateThread -> 8309FF80H,135
CreateThread -> 830A1200H,136
CreateThread -> 830A2480H,137
CreateThread -> 830A3700H,138
DestroyThread! - 83093300H
DestroyThread! - 8309DA80H
DestroyThread! - 8309ED00H
De
stroyThread! - 8309FF80H
DestroyThread! - 830A1200H
DestroyThread! - 830A2480H
Touc
hPanel Thread Startup!
Desktop -> WM_ERASEBKGND - 0,0,480,272
GUI_Desktop Start!
Desktop->pMsgQ=83092480H
SetTimer -> 83092880H - 500
DestroyThread! - 83094580H
SetTimer -> 83094000H - 300
DestroyThread! - 83092080H
**** Main Menu ****
Select Function(0~5):
[0]. USB MassStoeage
[1]. GUI Demo
[2
]. TouchScreen Calibrate
[3]. FS Test
[4]. TCB View
[5]. Custom
可以显示开机画面,和通过串口命令做一些测试,如GUI Demo
但我的屏是友善的一线精准触摸屏(4.3"),触摸驱动用不了 |
