一台cisco2611路由器,只连接e0/0、e0/1两个口,采用ospf协议。设置完成后两口之间不能ping通。求明白网友指正。因为好多年不弄这个,所以这么简单问题都束手无策,真不好意思。
配置如下:
Current configuration : 532 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Router
ip subnet-zero
interface Ethernet0/0
ip address 172.16.1.54 255.255.255.248
half-duplex
interface Ethernet0/1
ip address 172.16.1.70 255.255.255.248
half-duplex
router ospf 100
no log-adjacency-changes
network 172.16.1.48 0.0.0.7 area 0
network 172.16.1.64 0.0.0.7 area 0
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
login
end
路由表显示如下:
Router#show ip rou
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
172.16.0.0/29 is subnetted, 2 subnets
C 172.16.1.48 is directly connected, Ethernet0/0
C 172.16.1.64 is directly connected, Ethernet0/1
Router#copy runn star
Destination filename [startup-config]?
Building configuration...
[OK]
Router# |
