回复: 2
紧急求助:帮忙下载一份PUDN资料
发表于 2011-5-14 09:52:03 | 显示全部楼层 |阅读模式
http://www.pudn.com/downloads122/sourcecode/embed/detail517753.html
多谢!
 楼主| 发表于 2011-5-14 09:54:24 | 显示全部楼层
/****************************************Copyright (c)****************************************************
**                               Guangzhou ZHIYUAN electronics Co.,LTD.
**                                 http://www.embedtools.com
**--------------File Info---------------------------------------------------------------------------------
** File Name:               includes.h
** Last modified Date:      2008.7.18
** Last Version:            v1.0
** Description:             配置uIP TCP/IP协议栈通信的MAC地址,IP地址,子网掩码以及网关地址
** Created By:              任海波
** Created date:            2008.7.18
** Version:                 v1.0
** Descriptions:            The original version 初始版本
** Modified by:
** Modified date:
** Version:
** Description:
/**************************定义网络通信的IP地址、网关、子网掩码*********************************/
#define My_Mac_ID            {0X00,0x14,0x97,0x0F,0x1D,0xE3}  //存储以太网控制器的物理地址,即MAC地址
#define IP_MARK_ID             {255,255,255,0}                          //255.255.255.0,子网掩码
#define MY_IP_ID               {192,168,1,25}                   //以太网通信的IP地址
#define MY_GATEWAY_ID   {192,168,1,254}                  //以太网通信的网关地址
** Description:             uIP TCP/IP协议栈应用的头文件
** Created By:              任海波
** Version:                 v1.0
** Modified by:
** Modified date:
** Version:
** Description:
  Date types(Compiler specific)  数据类型(和编译器相关)
typedef unsigned char   uint8;                                          /* Unsigned  8 bit quantity     */
typedef signed   char   int8;                                           /* Signed    8 bit quantity     */
typedef unsigned short  uint16;                                         /* Unsigned  16 bit quantity    */
typedef signed   short  int16;                                          /* Signed    16 bit quantity    */
typedef unsigned int    uint32;                                         /* Unsigned  32 bit quantity    */
typedef signed   int    int32;                                          /* Signed    32 bit quantity    */
typedef float           fp32;                                           /* Single    precision          */
        /* floating  point              */
typedef double          fp64;                                           /* Double    precision          */
**Luminary提供的驱动库的头文件
#include "hw_ints.h"
#include "hw_memmap.h"
#include "hw_types.h"
#include "debug.h"
#include "interrupt.h"
#include "sysctl.h"
#include "systick.h"
#include "ethernet.h"
#include "flash.h"
#include "gpio.h"
**配置协议栈MAC地址,IP地址,子网掩码以及网关的头文件
#include"Eth_MAC_IP_Config.h"
**uIP CTP/IP协议栈的头文件
#include "uip.h"
#include "uip_arp.h"
**用户自定义应用程序的头文件
#include "httpd.h"
** File Name:          main.c
** Last Version:       1.0
** Description:        Luminary系列MicroControllers以太网应用uIP TCP/IP协议栈应用模板,包含了主函数控制
**                     循环
** Created By:         任海波
** Version:            1.0
** Modified by:
** Modified date:
** Version:
** Description:
#include"includes.h"
uint8 IPAddress[4]=MY_IP_ID;
uint8 IPNetMask[4]=IP_MARK_ID;
uint8 MACAddress[6]=My_Mac_ID;
uint8 IPGateWAY[4]=MY_GATEWAY_ID;
***设定系统时钟定时器的常数
#define SYSTICKHZ               100
#define SYSTICKMS               (1000 / SYSTICKHZ)
#define SYSTICKUS               (1000000 / SYSTICKHZ)
#define SYSTICKNS               (1000000000 / SYSTICKHZ)
**定义一个宏,可以访问缓冲区中以太网数据报的报头信息
#define BUF                     ((struct uip_eth_hdr *)&uip_buf[0])
**设置一些标志位,各标志位的定义如下:
**标志位0:指示一个系统时钟定时器中断发生
**标志位1:一个以太网数据包接收中断发生
#define FLAG_SYSTICK            0
#define FLAG_RXPKT              1
static volatile unsigned long g_ulFlags;
***uIP TCP/IP协议栈的定时器常数(以ms为单位)
#define UIP_PERIODIC_TIMER_MS   500
#define UIP_ARP_TIMER_MS        10000
***如果系统的驱动库调用出错,将会弹出提示,可以查出相应的错误
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
**函数原型:    SysTickIntHandler()
**入口参数:     无
**出口参数:     无
**返 回 值:    无
**说    明:   系统时钟定时器中断,标志中断发生
void
SysTickIntHandler(void)
    // 标志一个系统时钟定时器中断已经发生.
    HWREGBITW(&g_ulFlags, FLAG_SYSTICK) = 1;
**函数原型:    EthernetIntHandler()
**入口参数:     无
**出口参数:     无
**返 回 值:    无
**说    明:   以太网中断,标志中断发生
void
EthernetIntHandler(void)
    unsigned long ulTemp;
   /****************读取并清除中断*************/
    ulTemp = EthernetIntStatus(ETH_BASE, false);
    EthernetIntClear(ETH_BASE, ulTemp);
    // 检查发生的是否是一个数据包接收的中断
    if(ulTemp & ETH_INT_RX)
       // 指示一个数据包已经被接收
        HWREGBITW(&g_ulFlags, FLAG_RXPKT) = 1;
        // 禁止以太网接收中断
        EthernetIntDisable(ETH_BASE, ETH_INT_RX);
**函数原型:    main()
**入口参数:     无
**出口参数:     无
**返 回 值:    无
**说    明:   uIP TCP/IP协议栈应用的主函数,其中包含了底层的硬件驱动
int
main(void)
    uip_ipaddr_t ipaddr;
    static struct uip_eth_addr sTempAddr;
    long lPeriodicTimer, lARPTimer, lPacketLength;
    // 根据硬件电路的晶振设置系统时钟
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_8MHZ);
    // 使能并复位以太网控制器
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH);
    SysCtlPeripheralReset(SYSCTL_PERIPH_ETH);
    // 使能PF口的以太网控制器的发生接收指示灯.
    //  LED0        Bit 3   输出
    //  LED1        Bit 2   输出
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    GPIODirModeSet(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3, GPIO_DIR_MODE_HW);
    GPIOPadConfigSet(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3,
                     GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD);
    // 配置初始化系统时钟定时器,并使能该定时器中断
    SysTickPeriodSet(SysCtlClockGet() / SYSTICKHZ);
    SysTickEnable();
    SysTickIntEnable();
    // 初始化以太网控制器,并禁止以太网控制器的所有中断源
    EthernetIntDisable(ETH_BASE, (ETH_INT_PHY | ETH_INT_MDIO | ETH_INT_RXER |
                       ETH_INT_RXOF | ETH_INT_TX | ETH_INT_TXER | ETH_INT_RX));
    // 初始化以太网控制器,以便可以操作它
    EthernetInitExpClk(ETH_BASE, SysCtlClockGet());
    // 配置以太网控制器,使它以正常的模式工作.
    // - 全双工
    // - TX CRC 校验自动产生
    // - TX Padding Enabled
    EthernetConfigSet(ETH_BASE, (ETH_CFG_TX_DPLXEN | ETH_CFG_TX_CRCEN |
                                 ETH_CFG_TX_PADEN));
    // 使能以太网控制器.
    EthernetEnable(ETH_BASE);
    // 使能以太网控制器的中断.
    IntEnable(INT_ETH);
    // 使能以太网控制器的数据包接收中断.
    EthernetIntEnable(ETH_BASE, ETH_INT_RX);
    // 使能系统总中断
    IntMasterEnable();
    // 初始化 uIP TCP/IP 协议栈.
    uip_init();
    uip_ipaddr(ipaddr, IPAddress[0], IPAddress[1], IPAddress[2],
               IPAddress[3]);
    uip_sethostaddr(ipaddr);
    uip_ipaddr(ipaddr, IPNetMask[0], IPNetMask[1], IPNetMask[2],
               IPNetMask[3]);
    uip_setnetmask(ipaddr);
    //配置以太网控制器的硬件物理地址(即MAC地址)
    sTempAddr.addr[0] = MACAddress[0];
    sTempAddr.addr[1] = MACAddress[1];
    sTempAddr.addr[2] = MACAddress[2];
    sTempAddr.addr[3] = MACAddress[3];
    sTempAddr.addr[4] = MACAddress[4];
    sTempAddr.addr[5] = MACAddress[5];
     EthernetMACAddrSet(ETH_BASE, (unsigned char *)&sTempAddr);
    uip_setethaddr(sTempAddr);
/*********这这里初始化一个具体的应用***********************************/
     httpd_init();
    // 主控制应用程序循环.
    lPeriodicTimer = 0;
    lARPTimer = 0;
    while(true)
        //等待一个事件发生。该事件可以是一个系统时钟定时器的事件也可以是一个RX数据包接收的中断
        while(!g_ulFlags)
        //事件发生,如果是系统时钟定时器中断,则清除中断标志位,并给计数定时器加 1
        if(HWREGBITW(&g_ulFlags, FLAG_SYSTICK) == 1)
            HWREGBITW(&g_ulFlags, FLAG_SYSTICK) = 0;
            lPeriodicTimer += SYSTICKMS;
            lARPTimer += SYSTICKMS;
        //检查RX接收缓冲区中是否有数据,并读取.
        lPacketLength = EthernetPacketGetNonBlocking(ETH_BASE, uip_buf,
                                                     sizeof(uip_buf));
        if(lPacketLength > 0)
            // 设置 uip_len 用来指示uIP stack 可用.
            uip_len = (unsigned short)lPacketLength;
            // 清除RX数据包接收中断,并重新使能该中断
            if(HWREGBITW(&g_ulFlags, FLAG_RXPKT) == 1)
                HWREGBITW(&g_ulFlags, FLAG_RXPKT) = 0;
            // 这里处理IP数据包接收
            if(BUF->type == htons(UIP_ETHTYPE_IP))
                uip_arp_ipin();
                uip_input();
                // If the above function invocation resulted in data that
                // should be sent out on the network, the global variable
                // uip_len is set to a value > 0.
                if(uip_len > 0)
                    uip_arp_out();
                    EthernetPacketPut(ETH_BASE, uip_buf, uip_len);
                    uip_len = 0;
            // 这里处理ARP数据包接收
            else if(BUF->type == htons(UIP_ETHTYPE_ARP))
                uip_arp_arpin();
                if(uip_len > 0)
                    uip_len = 0;
        //这里处理Timer决定的TCP/IP周期性事件.
        if(lPeriodicTimer > UIP_PERIODIC_TIMER_MS)
            lPeriodicTimer = 0;
            for(ulTemp = 0; ulTemp < UIP_CONNS; ulTemp++)
                uip_periodic(ulTemp);
                if(uip_len > 0)
                    uip_arp_out();
                    uip_len = 0;
#if UIP_UDP
            for(ulTemp = 0; ulTemp < UIP_UDP_CONNS; ulTemp++)
                uip_udp_periodic(i);
                if(uip_len > 0)
                    uip_arp_out();
                    uip_len = 0;
#endif // UIP_UDP
        // Process ARP Timer here.
        if(lARPTimer > UIP_ARP_TIMER_MS)
            lARPTimer = 0;
            uip_arp_timer();
 楼主| 发表于 2011-5-14 09:55:02 | 显示全部楼层
哪位有完整版本?
GMT+8, 2024-9-27 11:52
