回复: 3
c8051f350AD采样
发表于 2011-5-11 09:53:09 | 显示全部楼层 |阅读模式
本人初学单片机,用f350AD采样。
#include <C8051F350.h>                 // SFR declarations
#include <stdio.h>
// 16-bit SFR Definitions for 'F35x
sfr16 TMR2RL = 0xCA;                   // Timer2 reload value
sfr16 TMR2 = 0xCC;                     // Timer2 counter
sfr16 ADC0DEC = 0x9A;                  // ADC0 Decimation Ratio Register
// Global CONSTANTS
#define SYSCLK       24500000          // SYSCLK frequency in Hz
#define MDCLK         2457600          // Modulator clock in Hz (ideal is
                                       // (2.4576 MHz)
#define OWR                20          // Desired Output Word Rate in Hz
#define BAUDRATE       115200          // Baud rate of UART in bps
sbit LED = P0^7;                       // LED='1' means ON
sbit SW2 = P1^0;                       // SW2='0' means switch pressed
typedef union LONGDATA{                // Access LONGDATA as an
   unsigned long result;               // unsigned long variable or
   unsigned char Byte[4];              // 4 unsigned byte variables
}LONGDATA;
// With the Keil compiler and union byte addressing:
// [0] = bits 31-24, [1] =  bits 23-16, [2] = bits 15-8, [3] = bits 7-0
#define Byte3 0
#define Byte2 1
#define Byte1 2
#define Byte0 3
// Function PROTOTYPES
void Oscillator_Init (void);
void Port_Init (void);
void UART0_Init (void);
void ADC0_Init(void);
// MAIN Routine
void main (void)
   PCA0MD = 0x00;                    // WDTE = 0 (clear watchdog timer
                                       // enable)
   Oscillator_Init();                  // Initialize system clock
   Port_Init();                        // Initialize Crossbar and GPIO
   UART0_Init();                       // Initialize UART0 for printf's
   ADC0_Init();                        // Initialize ADC0
   AD0INT = 0;
   ADC0MD = 0x83;                      // Start continuous conversions
   EA = 1;                             // Enable global interrupts
   while (1) {                         // Spin forever
// Initialization Subroutines
// Oscillator_Init
// Return Value : None
// Parameters   : None
// This routine initializes the system clock to use the internal 24.5MHz
// oscillator as its clock source.  Also enables missing clock detector reset.
   OSCICN = 0x83;                      // Configure internal oscillator for
                                       // its lowest frequency
   RSTSRC = 0x04;                      // Enable missing clock detector
// Port_Init
// This function initializes the GPIO and the Crossbar
// Pinout:
//   P0.4 - UART TX (digital, push-pull)
//   P0.5 - UART RX (digital, open-drain)
//   AIN0.2 - ADC0 input
   XBR0 = 0x01;                        // UART0 Selected
   XBR1 = 0x40;                        // Enable crossbar and weak pull-ups
   P0MDOUT |= 0xD0;                    // TX, LEDs = Push-pull
// UART0_Init
// Configure the UART0 using Timer1, for <BAUDRATE> and 8-N-1.
   SCON0 = 0x10;                       // SCON0: 8-bit variable bit rate
                                       //        level of STOP bit is ignored
                                       //        RX enabled
                                       //        ninth bits are zeros
                                       //        clear RI0 and TI0 bits
   if (SYSCLK/BAUDRATE/2/256 < 1) {
      TH1 = -(SYSCLK/BAUDRATE/2);
      CKCON |=  0x08;                  // T1M = 1; SCA1:0 = xx
   } else if (SYSCLK/BAUDRATE/2/256 < 4) {
      TH1 = -(SYSCLK/BAUDRATE/2/4);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 01
      CKCON |=  0x01;
   } else if (SYSCLK/BAUDRATE/2/256 < 12) {
      TH1 = -(SYSCLK/BAUDRATE/2/12);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 00
   } else if (SYSCLK/BAUDRATE/2/256 < 48) {
      TH1 = -(SYSCLK/BAUDRATE/2/48);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 10
      CKCON |=  0x02;
   } else {
      while (1);                       // Error.  Unsupported baud rate
   TL1 = TH1;                          // Init Timer1
   TMOD &= ~0xf0;                      // TMOD: timer 1 in 8-bit autoreload
   TMOD |=  0x20;
   TR1 = 1;                            // START Timer1
   TI0 = 1;                            // Indicate TX0 ready
// ADC0_Init
// Initialize the ADC to use the temperature sensor. (non-differential)
void ADC0_Init (void)
   //ADC0MD = 0x80;                   // 使能ADC0 ADC0=空闲模式
   REF0CN |= 0x03;                     // Enable internal Vref
   ADC0CN = 0x00;                      // Gain = 1, Unipolar mode
   ADC0CF = 0x00;                      // Interrupts upon SINC3 filter output
                                       // and uses internal VREF
   ADC0CLK = (SYSCLK/MDCLK)-1;         // Generate MDCLK for modulator.
                                       // Ideally MDCLK = 2.4576MHz
   // Program decimation rate for desired OWR
   ADC0DEC = ((unsigned long) MDCLK / (unsigned long) OWR /
              (unsigned long) 128) - 1;
   ADC0BUF = 0x00;                     // Turn off Input Buffers
   ADC0MUX = 0x08;                     // Select AIN0.0
   ADC0STA   = 0x00;                              // 清ADC0状态寄存器
   ADC0MD = 0x81;                      // Start internal calibration
   while(AD0CALC != 1);                // Wait until calibration is complete
    EIE1   |= 0x08;                     // Enable ADC0 Interrupts
        ADC0MD |= 0x03;                                       // ADC0开始连续转换
   ADC0MD  = 0x80;                     // Enable the ADC0 (IDLE Mode)
// Interrupt Service Routines
// ADC0_ISR
// This ISR prints the result to the UART. The ISR is called after each ADC
// conversion.
void ADC0_ISR (void) interrupt 10
   static LONGDATA rawValue;
   unsigned long mV;
   while(!AD0INT);                     // Wait till conversion complete
   AD0INT = 0;                         // Clear ADC0 conversion complete flag
   // Copy the output value of the ADC
   rawValue.Byte[Byte3] = 0x00;
   rawValue.Byte[Byte2] = (unsigned char)ADC0H;
   rawValue.Byte[Byte1] = (unsigned char)ADC0M;
   rawValue.Byte[Byte0] = (unsigned char)ADC0L;
   //                           Vref (mV)
   //   measurement (mV) =   --------------- * result (bits)
   //                       (2^24)-1 (bits)
   //   measurement (mV) =  result (bits) / ((2^24)-1 (bits) / Vref (mV))
   //   With a Vref (mV) of 2500:
   //   measurement (mV) =  result (bits) / ((2^24)-1 / 2500)
   //   measurement (mV) =  result (bits) / (16777215 / 2500)
   //   measurement (mV) =  result (bits) / (6710)
   mV = rawValue.result / 6710;        // Because of bounds issues, this
                                       // calculation has been manipulated as
                                       // shown above
                                       // (i.e. 2500 (VREF) * 2^24 (ADC result)
                                       // is greater than 2^32)
   printf("AIN0.0 voltage: %5ld mV\n",mV);
// End Of File
串口一直打印2500mv,无法正确采样AIN0.0
请各位高手指点一下,问题所在。
发表于 2012-7-7 08:39:59 | 显示全部楼层
针对这个问题,我不知道是为什么 measurement (mV) =  result (bits) / (6710);此处的6710是怎么出现的?
发表于 2012-7-7 08:44:06 | 显示全部楼层
上面的问题我知道了,呵呵,问题还得自己深挖啊...希望大家一起进步...
发表于 2012-7-7 17:05:22 | 显示全部楼层
初始化最后一句去掉 ADC0MD  = 0x80;                     // Enable the ADC0 (IDLE Mode) 你相当于把adc又给关了!! 0x83已经启动了
GMT+8, 2024-8-27 00:17
