我自己做了一块FPGA的板,最近调NIOSII出了问题。
CYLONE II EP2C8Q208 NIOSII 软核往EPCS4配置芯片下载不了程序(JTAG下载),但是可以把VHDL程序下载到EOCS中。
以下是进行flash programmer时的显示:
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd C:/cs/lcd_cs/lcd_cs/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="C:/cs/cs.sof" --output="cs.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=cs.op
t C:/cs/cs.sof cs.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Sat May 07 08:57:20 2011
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:04
Info: Command: quartus_cpf --no_banner --convert cs.pof cs.rpd
Info: Peak virtual memory: 70 megabytes
Info: Processing ended: Sat May 07 08:57:27 2011
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:05
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00000000 --sidp=0x0
0001800 --id=1761980236 --timestamp=1304416708 --instance=0 "cs.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: FAILED
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="cs.flash" --input="lcd_cs.elf" -
-output="epcs.flash"
# Programming flash with the project
0001800 --id=1761980236 --timestamp=1304416708 --instance=0 "epcs.flash"
请问大虾这是哪儿的问题?好几天了一直调不出来。 |
