发表于 2011-5-6 14:59:48
回复【1楼】ppptawong
过两天回学校后把图片传上来,现在没相机。
初步完成图片的显示(只是倾斜了),可以用按键实现上翻,下翻,放大,缩小图片,代码如下:
* "Hello World" example.
* This example prints 'Hello from Nios II' to the STDOUT stream. It runs on
* the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example
* designs. It runs with or without the MicroC/OS-II RTOS and requires a STDOUT
* device in your system's hardware.
* The memory footprint of this hosted application is ~69 kbytes by default
* using the standard reference design.
* For a reduced footprint version of this template, and an explanation of how
* to reduce the memory footprint for a given application, see the
* "small_hello_world" template.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <alt_types.h>
#include "sys/alt_irq.h"
#include "system.h" //包含基本的硬件描述信息
#include "altera_avalon_pio_regs.h" //包含基本的I/O口信息
#include "image.h"
#include "image1.h"
#include "image2.h"
#define LCD_CS *(volatile unsigned char*)LCD_CS_BASE
#define LCD_RD *(volatile unsigned char*)LCD_RD_BASE
#define LCD_WR *(volatile unsigned char*)LCD_WR_BASE
#define LCD_RS *(volatile unsigned char*)LCD_RS_BASE
#define LCD_RESET *(volatile unsigned char*)LCD_RESET_BASE
#define LCD_DATAL *(volatile unsigned char*)LCD_DATAL_BASE
#define KEY_UPPER *(volatile unsigned char *) KEY_UPPER_BASE
#define KEY_NEXT *(volatile unsigned char *) KEY_NEXT_BASE
#define KEY_BIG *(volatile unsigned char *) KEY_BIG_BASE
#define KEY_SMALL *(volatile unsigned char *) KEY_SMALL_BASE
#define X_START 0x0050 // 水平的开始地址组
#define X_END 0x0051 // 水平的结束地址组
#define Y_START 0x0052 // 水平的开始地址组
#define Y_END 0x0053 // 水平的结束地址组
#define X_COUNT 0X0020 //水平地址计数器
#define Y_COUNT 0X0021 //垂直地址计数器
#define WR_GRAM 0X0022 //GRAM的写入和读取端口
int count=1,i=0,j=0,size=3;
//延时1ms子程序
void Delay_1ms(unsigned int count)
int i,j;
for(i=0;i<count;i++)
for(j=0;j<2000;j++);
// 通过8位的数据口LCD_DATAL写入16位的数据,先写高8位,再写低8位
void Write_Data(unsigned char DataH,unsigned char DataL)
LCD_CS=0;
LCD_RS=1; //RS=1时位写数据
LCD_DATAL=DataH;
LCD_WR=0; //RW的上升沿写入数据
LCD_WR=1;
LCD_DATAL=DataL; //先写高位,再写低位
LCD_WR=0;
LCD_WR=1;
LCD_CS=1;
// 通过8位的数据口LCD_DATAL写入16位的命令,先写高8位,再写低8位
void Write_Cmd(unsigned char DataH,unsigned char DataL)
LCD_CS=0;
LCD_RS=0; //RS=0时位写命令
LCD_DATAL=DataH;
LCD_WR=1;
LCD_WR=0;
LCD_WR=1;
LCD_CS=1;
// 先发命令,紧接着发送数据,调用该函数时比较方便
void Write_Cmd_Data(unsigned int Cmd,unsigned int Data)
unsigned char x,y,z;
x=(unsigned char)Cmd; //因为实际的命令高8位肯定位00,所以只需取其低8位
y=(unsigned char)(Data>>8); //取数据的高8位
z=(unsigned char)Data; //取数据的低8位
Write_Cmd(0x00,x);
Write_Data(y,z);
//16位模式下的驱动
void Lcd_Init()
// Delay_1ms(200);
LCD_RD=1;
LCD_RESET=1;
Delay_1ms(2);
LCD_RESET=0;
Delay_1ms(2);
LCD_RESET=1;
Delay_1ms(2);
//早期初始化序列
LCD_CS=0;
Write_Cmd_Data(0x00E5,0x78F0);
Write_Cmd_Data(0x0001,0x0100);
Write_Cmd_Data(0x0002,0x0700);
Write_Cmd_Data(0x0003,0x1030);
Write_Cmd_Data(0x0004,0x0000);
Write_Cmd_Data(0x0008,0x0207);
Write_Cmd_Data(0x0009,0x0000);
Write_Cmd_Data(0x000A,0x0000);
Write_Cmd_Data(0x000C,0x0000);
Write_Cmd_Data(0x000D,0x0000);
Write_Cmd_Data(0x000F,0x0000);
//上电后初始化序列
Write_Cmd_Data(0x0010,0x0000);
Write_Cmd_Data(0x0011,0x0007);
Write_Cmd_Data(0x0012,0x0000);
Write_Cmd_Data(0x0013,0x0000);
Write_Cmd_Data(0x0007,0x0001);
Delay_1ms(2);
Write_Cmd_Data(0x0010,0x1090); //这里修改了
Write_Cmd_Data(0x0011,0x0227);
Delay_1ms(2);
Write_Cmd_Data(0x0012,0x001F);//这里修改了
Delay_1ms(2);
Write_Cmd_Data(0x0013,0x1500);
// Delay_1ms(100);
Write_Cmd_Data(0x0029,0x0027); //这里修改了
Write_Cmd_Data(0x002B,0x000D);
Delay_1ms(2);
//gamma
Write_Cmd_Data(0x0020,0x0000);
Write_Cmd_Data(0x0021,0x0000);
Write_Cmd_Data(0x0030,0x0000);//这里修改了
Write_Cmd_Data(0x0031,0x0707);//这里修改了
Write_Cmd_Data(0x0032,0x0307);//这里修改了
Write_Cmd_Data(0x0035,0x0200);//这里修改了
Write_Cmd_Data(0x0036,0x0008);//这里修改了
Write_Cmd_Data(0x0037,0x0004); //这里修改了
Write_Cmd_Data(0x0038,0x0000);//这里修改了
Write_Cmd_Data(0x0039,0x0707);
Write_Cmd_Data(0x003C,0x0002);//这里修改了
Write_Cmd_Data(0x003D,0x1D04);//这里修改了
//ram
Write_Cmd_Data(0x0050,0x0000);
Write_Cmd_Data(0x0051,0x00EF);
Write_Cmd_Data(0x0052,0x0000);
Write_Cmd_Data(0x0053,0x013F);
Write_Cmd_Data(0x0060,0xA700);
Write_Cmd_Data(0x0061,0x0001);
Write_Cmd_Data(0x006A,0x0000);
Write_Cmd_Data(0x0080,0x0000);
Write_Cmd_Data(0x0081,0x0000);
Write_Cmd_Data(0x0082,0x0000);
Write_Cmd_Data(0x0083,0x0000);
Write_Cmd_Data(0x0084,0x0000);
Write_Cmd_Data(0x0085,0x0000);
Write_Cmd_Data(0x0090,0x0010);
Write_Cmd_Data(0x0092,0x0600);
// Write_Cmd_Data(0x0093,0x0003);
// Write_Cmd_Data(0x0095,0x0110);
// Write_Cmd_Data(0x0097,0x0000);
// Write_Cmd_Data(0x0098,0x0000);
Write_Cmd_Data(0x0007,0x0133);
LCD_CS=1;
//8位模式下的驱动
void Lcd_Init()
Delay_1ms(500);
//早期初始化序列
LCD_RD=1;
LCD_RESET=1;
Delay_1ms(2);
LCD_RESET=0;
Delay_1ms(2);
LCD_RESET=1;//此处的复位脚一定要设成为高电平,否则肯定不能显示。用单独的那个tft+sd卡模块时
// Delay_1ms(2);
// LCD_RD=0;
LCD_CS=0;
// Write_Cmd_Data(0x00E5,0x78F0);
//上电后初始化序列
// Write_Cmd_Data(0x0007,0x0001); //该模式下没有这1句
Delay_1ms(100);
Write_Cmd_Data(0x0010,0x1290); //这里修改了
Delay_1ms(100);
Write_Cmd_Data(0x0012,0x001d);//这里修改了
Delay_1ms(100);
Delay_1ms(100);
Write_Cmd_Data(0x0029,0x0018); //这里修改了
// Delay_1ms(100);
//gamma
// Write_Cmd_Data(0x0020,0x0000);//该模式下没有这2句
// Write_Cmd_Data(0x0021,0x0000);
Write_Cmd_Data(0x0030,0x0004);//这里修改了
Write_Cmd_Data(0x0031,0x0307);//这里修改了
Write_Cmd_Data(0x0032,0x0002);//这里修改了
Write_Cmd_Data(0x0035,0x0206);//这里修改了
Write_Cmd_Data(0x0036,0x0408);//这里修改了
Write_Cmd_Data(0x0037,0x0507); //这里修改了
Write_Cmd_Data(0x0038,0x0204);//这里修改了
Write_Cmd_Data(0x003C,0x0405);//这里修改了
Write_Cmd_Data(0x003D,0x0F02);//这里修改了
//ram
LCD_CS=1;
//定义坐标
void LCD_Set_Pos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1)
Write_Cmd_Data(X_START,x0);
Write_Cmd_Data(X_END,x1);
Write_Cmd_Data(Y_START,y0);
Write_Cmd_Data(Y_END,y1);
Write_Cmd_Data(X_COUNT,x0);
Write_Cmd_Data(Y_COUNT,y0);
Write_Cmd(0x00,0x22);//LCD_WriteCMD(GRAMWR);
void Clean_LCD(unsigned char ColourH,unsigned char ColourL)
unsigned int i,j;
LCD_CS=0;
LCD_Set_Pos(0,240,0,320);
for (i=0;i<320;i++)
for (j=0;j<240;j++)
Write_Data(ColourH,ColourL);
LCD_CS=1;
void key_scan( )
if(0==KEY_NEXT){
Delay_1ms(1);
if(0==KEY_NEXT){
count++;
if(6==count)count=1;
else if(0==KEY_UPPER){
Delay_1ms(1);
if(0==KEY_UPPER){
count--;
if(0==count)count=5;
else if(0==KEY_SMALL){
Delay_1ms(1);
if(0==KEY_SMALL){
size--;
if(1==size)size=2;
else if(0==KEY_BIG){
Delay_1ms(1);
if(0==KEY_BIG){
size++;
if(5==size)size=4;
void main()
Lcd_Init();
Clean_LCD(0x0f,0xf0);
// printf("My God!");
LCD_CS =0; //打开片选使能
key_scan();
// LCD_Set_Pos(0,240,0,320);//320x240
if(3==size){
if(1==count){
for(i=0;i<76800;i++)
Write_Data(image1[i*2+1],image1[i*2]);//数组的的前面是颜色的高位,后面是低位,这里注意
else if(2==count){
Write_Data(image2[i*2+1],image2[i*2]);//数组的的前面是颜色的高位,后面是低位,这里注意
else if(3==count){
Write_Data(image3[i*2+1],image3[i*2]);//数组的的前面是颜色的高位,后面是低位,这里注意
}else if(4==count){
Write_Data(image4[i*2+1],image4[i*2]);//数组的的前面是颜色的高位,后面是低位,这里注意
}else if(5==count){
Write_Data(image5[i*2+1],image5[i*2]);//数组的的前面是颜色的高位,后面是低位,这里注意
//缩小4倍
if(2==size){
Clean_LCD(0x00,0x00);
Write_Cmd_Data(0x0004,0x0001);
LCD_Set_Pos(60,180,80,240);//320x240
if(1==count){
for(i=0;i<76800;i=i+1)
else if(2==count){
else if(3==count){
}else if(4==count){
}else if(5==count){
//放大4倍
if(4==size){
// Clean_LCD(0x00,0x00);
// LCD_Set_Pos(60,180,80,240);//320x240
if(1==count){
for(j=0;j<320;j++)
for(i=0;i<240;i++)
if(i>=60&&i<180)
Write_Data(image1[(240*j+i-1)*2+1],image1[(240*j+i)*2]);
/* for(j=0;j<160;j++)
for(i=0;i<120;i++)
LCD_Set_Pos(2*i,2*i,2*j,2*j);
Write_Data(image1[]);
else if(2==count){
for(j=0;j<320;j++)
for(i=0;i<240;i++)
if(i>=60&&i<180)
Write_Data(image2[(240*j+i-1)*2+1],image2[(240*j+i)*2]);
else if(3==count){
for(j=0;j<320;j++)
for(i=0;i<240;i++)
if(i>=60&&i<180)
Write_Data(image3[(240*j+i-1)*2+1],image3[(240*j+i)*2]);
}else if(4==count){
for(j=0;j<320;j++)
for(i=0;i<240;i++)
if(i>=60&&i<180)
Write_Data(image4[(240*j+i-1)*2+1],image4[(240*j+i)*2]);
}else if(5==count){
for(j=0;j<320;j++)
for(i=0;i<240;i++)
if(i>=60&&i<180)
Write_Data(image5[(240*j+i-1)*2+1],image5[(240*j+i)*2]);
LCD_CS=1; //关闭片选使能
