SPI 的SCK配为1MHz
#include"msp430x54x.h"
#define uint unsigned int
//P32
#define SPI_CS (1<<0)
#define SPI_CS_H P3DIR|= SPI_CS,P3OUT|= SPI_CS
#define SPI_CS_L P3DIR|= SPI_CS,P3OUT&= ~SPI_CS
#define EEPROM_CMD_READ 0x03 // Read Command
#define EEPROM_CMD_PP 0x02 // Page Program Command
#define EEPROM_CMD_WRDI 0x04 // Reset Write Enable Latch Command
#define EEPROM_CMD_WREN 0x06 // Set Write Enable Latch Command
#define EEPROM_CMD_RDSR 0x05 // Read Status Register Command
#define EEPROM_CMD_WRSR 0x01 // Write Status Register Command
#define EEPROM_CMD_SE 0xD8 // Sector Erase
#define EEPROM_CMD_BE 0XC7 // Bulk Erase
#define SPIMEM_DP 0xb9
#define SPIMEM_RES 0xab
void Init_Clk(void);
void delay(int n);
void delay1 (uint ms);
//SPI
void master_io_set();
void master_init();
void df_read_deviceid(char *buf);
void sub_init();
void sub_io_set();
void M25P32_Data_Initvol(void);
void M25P32_Sector_Erase(unsigned long address);
void M25P32_Bulk_Erase(void);
unsigned long M25P32_Data_Seek(unsigned long CurrectID, unsigned long TotalID);
void M25P32_WritePage(unsigned char * S,unsigned char num,unsigned char page,unsigned int address);
void M25P32_ReadData (unsigned char *EEPROM_data, unsigned char Num,unsigned char page,unsigned int address);
void read_ID(unsigned char *EEPROM_data);
void Write_Status(unsigned char com);
uchar Read_Status(void);
void M25P32_All_Erase(void);
void spi_reset (void);
unsigned char M25P32_Data[15];
unsigned int s_xuhao;
unsigned int Frequecy_Store ; //储器频率值,默认为0001-6553.5
unsigned int s_temper ; //存储温度寄存器
unsigned char Dat[9] = {1,2,3,4,5,6,7,8,9};
char buf1[4];
uchar xx=1;
uint DATA_0 = 0;
uint DATA_1 = 0;
uchar status=0;
void main()
WDTCTL = WDTPW + WDTHOLD; //停止看门狗定时器
//P11DIR |= BIT2 + BIT1 + BIT0; //P11:012设为输出模式
//P11SEL |= BIT2 + BIT1 + BIT0; //设为第二功能作为频率输出
Init_Clk(); //时钟初始化
//SPI
master_io_set();
master_init();
_BIS_SR(GIE);
//read_ID(M25P32_Data);
M25P32_All_Erase();
M25P32_WritePage(Dat,9,0,0X0000);
M25P32_ReadData (M25P32_Data, 9,0,0X0000);
//delay
void delay(int n)
while(n--);
uint i,j;
for(i=0;i<ms;i++)
for(j=0;j<1000;j++)
//时钟初始化
void Init_Clk(void)
P7SEL |= 0x03; // Port select XT1
UCSCTL6 &= ~(XT1OFF); // Set XT1 On
UCSCTL6 |= XCAP_3; // Internal load cap
UCSCTL3 |= SELREF_0; // 选 FLL 时钟源
UCSCTL4 = SELA_0 + SELM_4 + + SELS_4; //选时钟源:ACLK = XT1 = 32768Hz, MCLK = SMCLK = 8MHz
UCSCTL5 = DIVPA_0 + DIVA_0 + DIVM_0 + DIVS_0;
__bis_SR_register(SCG0); // Disable the FLL control loop
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; // Select DCO range 16MHz operation
UCSCTL2 = FLLD_1 + 243; // Set DCO Multiplier for 8MHz
// (N + 1) * FLLRef = Fdco
// (243 + 1) * 32768 = 8MHz
// Set FLL Div = fDCOCLK/2
__bic_SR_register(SCG0); // Enable the FLL control loop
// Loop until XT1,XT2 & DCO stabilizes
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG);
// Clear XT2,XT1,DCO fault flags
SFRIFG1 &= ~OFIFG; // Clear fault flags
while (SFRIFG1&OFIFG); // Test oscillator fault flag
//SPI
//spi 主机端口配置
P3SEL|=BIT1+BIT2+BIT3;
P3DIR|=BIT1+BIT3;
//P3DIR&=~BIT2;
void master_init()
UCB0CTL1|=UCSWRST;
UCB0CTL0|=UCMST+UCSYNC+UCCKPL+UCMSB;
UCB0CTL1|=UCSSEL_2;
UCB0BR0=8;
UCB0BR1=0;
UCB0CTL1&=~UCSWRST;
//UCB0IE|=UCRXIE;
//读ID号
unsigned char i;
SPI_CS_L;
delay1 (10);
while(!(UCB0IFG&UCTXIFG));
UCB0TXBUF = 0x9f;
for(i=0;i<4;i++)
while(!(UCB0IFG&UCRXIFG));
UCB0TXBUF = 0XFF;
EEPROM_data = UCB0RXBUF;;
SPI_CS_H;
//等内部写周期完成
void M25P32_Check(void)
do
SPI_CS_L;
UCB0TXBUF = 0X05;//EEPROM_CMD_RDSR;
UCB0TXBUF = 0xff;
SPI_CS_H;
while(UCB0RXBUF & 0x01);
//写使能
void M25P32_WriteEN(void)
SPI_CS_L;
delay1 (10);
UCB0TXBUF = 0X06;//EEPROM_CMD_WREN;
SPI_CS_H;
do
SPI_CS_L;
delay1 (10);
UCB0TXBUF = 0xff;
//SPI_CS_H;
SPI_CS_H;
//写数据
unsigned char i;
M25P32_WriteEN();
SPI_CS_L;
delay1 (10);
UCB0TXBUF = EEPROM_CMD_PP;
UCB0TXBUF = (page & 0xFF);
UCB0TXBUF = (unsigned char)((address>>8)& 0x00FF);
UCB0TXBUF = (unsigned char)((address)& 0x00FF);
for (i = 0;i < num;i++)
UCB0TXBUF = S;
SPI_CS_H;
// Step5: Poll on the Write In Progress (WIP) bit in Read Status Register
do
SPI_CS_L;
UCB0TXBUF = 0xff;
SPI_CS_H;
//return(0);
//读数据
unsigned char i;
SPI_CS_L;
delay1 (10);
UCB0TXBUF = 0X03;
UCB0TXBUF = (page & 0XFF);
UCB0TXBUF = (unsigned char)((address>>8) & 0x00FF);
UCB0TXBUF = (unsigned char)((address) & 0x00FF);
//while(!(UCB0IFG&UCTXIFG));
//UCB0TXBUF = 0XFF;
for(i=0;i<Num;i++)
UCB0TXBUF = 0XFF;
SPI_CS_H;
//写状态寄存器
M25P32_WriteEN();
SPI_CS_L;
UCB0TXBUF = 0x01;
UCB0TXBUF = com;
SPI_CS_H;
do
SPI_CS_L;
UCB0TXBUF = 0xff;
SPI_CS_H;
while( (UCB0RXBUF & 0x01) == 0x01 );
//读状态寄存器
unsigned char i=0;
SPI_CS_L; // Activate Slave Select
UCB0TXBUF = 0x05;
UCB0TXBUF = 0X00;
i = UCB0RXBUF;
SPI_CS_H; // Deactivate Slave Select
return(i);
//擦整片flash
M25P32_WriteEN();
SPI_CS_L;
delay1 (20);
UCB0TXBUF = 0xC7;
delay1 (1000);
do
SPI_CS_L;
UCB0TXBUF = 0xff;
SPI_CS_H;
SPI_CS_L; // Step1.1: Activate Slave Select
SPI_CS_H;
delay1 (1000);
// Send the SE command
UCB0TXBUF = 0xD8;
// Send the sector address (MSB first)
UCB0TXBUF = (unsigned char)((address >> 16)& 0x000000FF);
SPI_CS_H;
delay1 (50000);
// Poll on the Write In Progress (WIP) bit in Read Status Register
do
SPI_CS_L;
UCB0TXBUF = 0xff;
SPI_CS_H;
