CNC Maschine ICV 4030 mit Servo-Controller
General note
The ICV 4030 has been developed from the proven, 3D-enabled CNC machine CPV 4030, which is delivered ready for connection to the mains.
The sliding hood, opening upwards, can be operated conveniently from a sitting position. The completely bolted chassis produces higher precision when building the machine and is easier to service.
In addition, it was possible to optimise the resonance and vibration behaviour and therefore lower noise build-up has been achieved.
Prerequisites for working with the ICV 4030 are simply basic knowledge of CNC systems, general IT literacy and basic knowledge of graphics programs!
Fig: ICV 4030
Fig: ICV 4030 with milling spindle and suction Fig: ICV 4030 with milling spindle and suction
www.milling-spindles.isel.com www.milling-spindles.isel.com
Complete solution with:
- DC servo motors
- DC power electronics
- Control programm
- Ideal for training and small series
Particularly suitable for: Aufbau:
- 3-D modelling
- Rapid Prototyping
- Cylindrical surface machining
- Multi-side machining
- processing of control panels
Portal: fixed
Tisch: movable
Traverse path: Milling spindle:
X = 395 mm,
Y = 300mm,
Z = 100 mm
iSA 500 - details
iSA 750 - details
Workable materials:
Plastics for modeling, plastics, light metals, wood, expanded material, wax
Technical Data
ICV 4030
Traverse path X/Y/Z (mm) 395 x 300 x 95
Clamping table surface W×D (mm) 600 x 375
Throughput (mm) 150
Dimensions
W×D×H (mm) 780 x 835 x 806
Guides Linear units with precision steel shafts and recirculating ball slots, adjustable for no play
Processing speed. X/Y/Z (mm/s) 200
Repeatability (mm) ± 0,02
Drive motors Servomotors
Drive elements X/Y/Z Recirculating ball transmission 16 × 10/16 × 10/16 × 10 mm
clearance free adjustable (optional: 16 × 4 mm in X/Y/Z)
Controller iMC CAN controller with 3 drive controllers, integratedcontrol computer, I/O module, safety circuit and rest state monitoringPower supply unit 48V/1000 W
Operation Function keys and emergency shutdown
Software (optional) WinRemote (optional: ProNC, isy 2.5 PLUS)
Weight kg appr. 120
Part no. 280230 4405 *
* The deliverables include an accompanying pack with mechanical accessories (inter alia hand lever clamping device, stop rails, triangle wrench, open jaw wrench, hook wrench, allen key, one 6-socket bench extension, connection lead, power lead) |
