#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/altera/72/quartus/bishe/software/hello_world_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="$QUARTUS_ROOTDIR/bishe/bis
he.sof" --output="bishe.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert d:/altera/72/quartus/bishe/bish
e.sof bishe.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Allocated 48 megabytes of memory during processing
Info: Processing ended: Thu Apr 28 11:12:39 2011
Info: Elapsed time: 00:00:02
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01400000 --sidp=0x01801238
--id=219760927 --timestamp=1303787008 --instance=0 "bishe.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x01801238: verified
: Checksumming existing contents
00000000 : Reading existing contents
00002000 : Reading existing contents
00004000 : Reading existing contents
00006000 : Reading existing contents
00008000 : Reading existing contents
0000A000 : Reading existing contents
0000C000 : Reading existing contents
0000E000 : Reading existing contents
00010000 : Reading existing contents
000D0000 : Reading existing contents
Checksummed/read 60kB in 1.7s
00000000 ( 0%): Erasing
00002000 ( 4%): Erasing
00004000 ( 8%): Erasing
00006000 (12%): Erasing
00008000 (16%): Erasing
0000A000 (20%): Erasing
0000C000 (25%): Erasing
0000E000 (29%): Erasing
00010000 (33%): Erasing
000D0000 (66%): Erasing
Erased 192kB in 5.8s (33.1kB/s)
00000000 ( 0%): Programming
00002000 ( 0%): Programming
00004000 ( 1%): Programming
00006000 ( 2%): Programming
00008000 ( 3%): Programming
0000A000 ( 4%): Programming
0000C000 ( 5%): Programming
0000E000 ( 6%): Programming
00010000 ( 7%): Programming
Program failed at offset 11840
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x01400000 --end=0x17fffff --reset=0x1400
000 --input="hello_world_0.elf" --output="cfi_flash_0.flash" --boot="D:/altera/7
2/ip/nios2_ip/altera_nios2/boot_loader_cfi.srec"
# Programming flash with the project
--id=219760927 --timestamp=1303787008 --instance=0 "cfi_flash_0.flash"
Checksummed/read 54kB in 1.1s
00002000 ( 6%): Erasing
00004000 (12%): Erasing
00006000 (18%): Erasing
00008000 (25%): Erasing
0000A000 (31%): Erasing
0000C000 (37%): Erasing
0000E000 (43%): Erasing
00010000 (50%): Erasing
Erased 128kB in 3.6s (35.5kB/s)
00002000 ( 6%): Programming
00004000 (12%): Programming
00006000 (18%): Programming
00008000 (25%): Programming
0000A000 (31%): Programming
0000C000 (37%): Programming
0000E000 (43%): Programming
00010000 (50%): Programming
Program failed at offset 11A41
NIOS IDE 是7.2版本的。以前建的几个工程都可以正常下载!这次不知问题出在哪里。
老是下一半就错误!
难道是程序太大? |
