回复: 8
烧写程序部分组成
发表于 2011-4-26 12:54:19 | 显示全部楼层 |阅读模式
如下图
 楼主| 发表于 2011-4-26 12:56:07 | 显示全部楼层
1。code memory 2。data memory  3。memory分别代表什么啊 (原文件名:memory.jpg)
 楼主| 发表于 2011-4-26 12:57:17 | 显示全部楼层
小弟在写程序的时候 已经重新擦写了很多flash块  那程序又是下载到哪里呢
发表于 2011-4-26 12:59:05 | 显示全部楼层
code memory 就是你的程序烧进430以后要占用的FLASH字节数,
data memory 就是你的程序运行过程中要使用的RAM字节数,CONST memory我也不太清楚
 楼主| 发表于 2011-4-26 13:09:19 | 显示全部楼层
我找到这个 (原文件名:2.jpg)
发表于 2011-4-26 13:21:53 | 显示全部楼层
// This file should be used with the MSP430F149 microprocessor.
// Copyright 1996-2007 IAR Systems. All rights reserved.
// Usage:  xlink your_file(s) -f lnk430f149 library
// $Revision: 5305 $
// The memory areas of the MSP430F149 microprocessor:
//   Peripheral units:                0 - 01FF
//   Information memory (FLASH):   1000 - 10FF
//   Read-write memory (RAM):      0200 - 09FF
//   Read-only memory (FLASH):     1100 - FFDF
// The following segments are defined in this linker command file:
// Data read/write segments (RAM)
// segment     Restrictions    Usage
// DATA16_I    < 10000         Data16 initialized variables
// DATA16_Z    < 10000         Data16 zero initialized variables
// DATA16_N    < 10000         Data16 uninitialized variables
// DATA16_HEAP < 10000         Data16 heap used by malloc and free
// DATA20_I                    Data20 initialized variables
// DATA20_Z                    Data20 zero initialized variables
// DATA20_N                    Data20 uninitialized variables
// DATA20_HEAP                 Data20 heap used by malloc and free
// CSTACK      < 10000         Runtime stack
// Program and data read-only segments (FLASH)
// INFO                        Information memory
// CSTART      < 10000         Program startup code
// CODE                        Program code
// ISR_CODE    < 10000         Program code for interrupt service routines
// DATA16_C    < 10000         Data16 constant data and string literals
// DATA16_ID   < 10000         Data16 initializers for DATA16_I
// DATA20_C                    Data20 constant data and string literals
// DATA20_ID                   Data20 initializers for DATA20_I
// DIFUNCT     < 10000         Dynamic initialization vector used by C++
// CHECKSUM                    Checksum byte(s) generated by the -J option
// INTVEC      FFE0-FFFF       Interrupt vectors
// RESET       FFFE-FFFF       The reset vector
// Stack and heap sizes.
// Uncomment for command line use
//-D_STACK_SIZE=80
//-D_DATA16_HEAP_SIZE=80
// Define cpu.
-cmsp430
// Read-write memory.
-Z(DATA)DATA16_I,DATA16_Z,DATA16_N,DATA16_HEAP+_DATA16_HEAP_SIZE=0200-09FF
-Z(DATA)CSTACK+_STACK_SIZE#
// Read only memory
-Z(CODE)INFO=1000-10FF
-Z(CODE)INFOA=1080-10FF
-Z(CODE)INFOB=1000-107F
// Constant data
-Z(CONST)DATA16_C,DATA16_ID,DIFUNCT,CHECKSUM=1100-FFDF
// Code
-Z(CODE)CSTART,ISR_CODE=1100-FFDF
-P(CODE)CODE=1100-FFDF
// Interrupt vectors
-Z(CODE)INTVEC=FFE0-FFFF
-Z(CODE)RESET=FFFE-FFFF
// The end
发表于 2011-4-26 13:25:51 | 显示全部楼层
上面是149的数据地址定义。
路径为
C:\Program Files\IAR Systems\Embedded Workbench 5.4 Evaluation\430\config
data memory   Read-write memory (RAM):      0200 - 09FF
code memory   Read-only memory (FLASH):     1100 - FFDF
const memory  Read-only memory (FLASH):     1100 - FFDF
也就是说:
1、RAM字节数为data memory
2、FLASH字节数(所谓的程序量)为code memory+
const memory
 楼主| 发表于 2011-4-29 20:09:17 | 显示全部楼层
回复【6楼】liuzq1981
哦 谢谢 但是我现在想把flash当做EEPROM用 是不是只有Information的512字节能用啊?
发表于 2011-4-29 20:46:07 | 显示全部楼层
不是, information 和 code 都可以用来保存数据, 只不过是用code部分的时候实现要确定你要保存数据的段没有被程序代码使用,
在information 和code中保存数据我都测试过没问题的
GMT+8, 2024-7-28 15:22
