求助修改DE1开发板的音频采集与输出的功能,以下就的程序。
module DE1_i2sound
//////////////////// Clock Input ////////////////////
CLOCK_24, // 24 MHz
CLOCK_27, // 27 MHz
CLOCK_50, // 50 MHz
EXT_CLOCK, // External Clock
//////////////////// Push Button ////////////////////
KEY, // Pushbutton[3:0]
//////////////////// DPDT Switch ////////////////////
SW, // Toggle Switch[9:0]
//////////////////// 7-SEG Dispaly ////////////////////
HEX0, // Seven Segment Digit 0
HEX1, // Seven Segment Digit 1
HEX2, // Seven Segment Digit 2
HEX3, // Seven Segment Digit 3
//////////////////////// LED ////////////////////////
LEDG, // LED Green[7:0]
LEDR, // LED Red[9:0]
//////////////////////// UART ////////////////////////
UART_TXD, // UART Transmitter
UART_RXD, // UART Receiver
///////////////////// SDRAM Interface ////////////////
DRAM_DQ, // SDRAM Data bus 16 Bits
DRAM_ADDR, // SDRAM Address bus 12 Bits
DRAM_LDQM, // SDRAM Low-byte Data Mask
DRAM_UDQM, // SDRAM High-byte Data Mask
DRAM_WE_N, // SDRAM Write Enable
DRAM_CAS_N, // SDRAM Column Address Strobe
DRAM_RAS_N, // SDRAM Row Address Strobe
DRAM_CS_N, // SDRAM Chip Select
DRAM_BA_0, // SDRAM Bank Address 0
DRAM_BA_1, // SDRAM Bank Address 0
DRAM_CLK, // SDRAM Clock
DRAM_CKE, // SDRAM Clock Enable
//////////////////// Flash Interface ////////////////
FL_DQ, // FLASH Data bus 8 Bits
FL_ADDR, // FLASH Address bus 22 Bits
FL_WE_N, // FLASH Write Enable
FL_RST_N, // FLASH Reset
FL_OE_N, // FLASH Output Enable
FL_CE_N, // FLASH Chip Enable
//////////////////// SRAM Interface ////////////////
SRAM_DQ, // SRAM Data bus 16 Bits
SRAM_ADDR, // SRAM Address bus 18 Bits
SRAM_UB_N, // SRAM High-byte Data Mask
SRAM_LB_N, // SRAM Low-byte Data Mask
SRAM_WE_N, // SRAM Write Enable
SRAM_CE_N, // SRAM Chip Enable
SRAM_OE_N, // SRAM Output Enable
//////////////////// SD_Card Interface ////////////////
SD_DAT, // SD Card Data
SD_DAT3, // SD Card Data 3
SD_CMD, // SD Card Command Signal
SD_CLK, // SD Card Clock
//////////////////// USB JTAG link ////////////////////
TDI, // CPLD -> FPGA (data in)
TCK, // CPLD -> FPGA (clk)
TCS, // CPLD -> FPGA (CS)
TDO, // FPGA -> CPLD (data out)
//////////////////// I2C ////////////////////////////
I2C_SDAT, // I2C Data
I2C_SCLK, // I2C Clock
//////////////////// PS2 ////////////////////////////
PS2_DAT, // PS2 Data
PS2_CLK, // PS2 Clock
//////////////////// VGA ////////////////////////////
VGA_HS, // VGA H_SYNC
VGA_VS, // VGA V_SYNC
VGA_R, // VGA Red[3:0]
VGA_G, // VGA Green[3:0]
VGA_B, // VGA Blue[3:0]
//////////////// Audio CODEC ////////////////////////
AUD_ADCLRCK, // Audio CODEC ADC LR Clock
AUD_ADCDAT, // Audio CODEC ADC Data
AUD_DACLRCK, // Audio CODEC DAC LR Clock
AUD_DACDAT, // Audio CODEC DAC Data
AUD_BCLK, // Audio CODEC Bit-Stream Clock
AUD_XCK, // Audio CODEC Chip Clock
//////////////////// GPIO ////////////////////////////
GPIO_0, // GPIO Connection 0
GPIO_1 // GPIO Connection 1
//////////////////////// Clock Input ////////////////////////
input [1:0] CLOCK_24; // 24 MHz
input [1:0] CLOCK_27; // 27 MHz
input CLOCK_50; // 50 MHz
input EXT_CLOCK; // External Clock
//////////////////////// Push Button ////////////////////////
input [3:0] KEY; // Pushbutton[3:0]
//////////////////////// DPDT Switch ////////////////////////
input [9:0] SW; // Toggle Switch[9:0]
//////////////////////// 7-SEG Dispaly ////////////////////////
output [6:0] HEX0; // Seven Segment Digit 0
output [6:0] HEX1; // Seven Segment Digit 1
output [6:0] HEX2; // Seven Segment Digit 2
output [6:0] HEX3; // Seven Segment Digit 3
//////////////////////////// LED ////////////////////////////
output [7:0] LEDG; // LED Green[7:0]
output [9:0] LEDR; // LED Red[9:0]
//////////////////////////// UART ////////////////////////////
output UART_TXD; // UART Transmitter
input UART_RXD; // UART Receiver
/////////////////////// SDRAM Interface ////////////////////////
inout [15:0] DRAM_DQ; // SDRAM Data bus 16 Bits
output [11:0] DRAM_ADDR; // SDRAM Address bus 12 Bits
output DRAM_LDQM; // SDRAM Low-byte Data Mask
output DRAM_UDQM; // SDRAM High-byte Data Mask
output DRAM_WE_N; // SDRAM Write Enable
output DRAM_CAS_N; // SDRAM Column Address Strobe
output DRAM_RAS_N; // SDRAM Row Address Strobe
output DRAM_CS_N; // SDRAM Chip Select
output DRAM_BA_0; // SDRAM Bank Address 0
output DRAM_BA_1; // SDRAM Bank Address 0
output DRAM_CLK; // SDRAM Clock
output DRAM_CKE; // SDRAM Clock Enable
//////////////////////// Flash Interface ////////////////////////
inout [7:0] FL_DQ; // FLASH Data bus 8 Bits
output [21:0] FL_ADDR; // FLASH Address bus 22 Bits
output FL_WE_N; // FLASH Write Enable
output FL_RST_N; // FLASH Reset
output FL_OE_N; // FLASH Output Enable
output FL_CE_N; // FLASH Chip Enable
//////////////////////// SRAM Interface ////////////////////////
inout [15:0] SRAM_DQ; // SRAM Data bus 16 Bits
output [17:0] SRAM_ADDR; // SRAM Address bus 18 Bits
output SRAM_UB_N; // SRAM High-byte Data Mask
output SRAM_LB_N; // SRAM Low-byte Data Mask
output SRAM_WE_N; // SRAM Write Enable
output SRAM_CE_N; // SRAM Chip Enable
output SRAM_OE_N; // SRAM Output Enable
//////////////////// SD Card Interface ////////////////////////
inout SD_DAT; // SD Card Data
inout SD_DAT3; // SD Card Data 3
inout SD_CMD; // SD Card Command Signal
output SD_CLK; // SD Card Clock
//////////////////////// I2C ////////////////////////////////
inout I2C_SDAT; // I2C Data
output I2C_SCLK; // I2C Clock
//////////////////////// PS2 ////////////////////////////////
input PS2_DAT; // PS2 Data
input PS2_CLK; // PS2 Clock
//////////////////// USB JTAG link ////////////////////////////
input TDI; // CPLD -> FPGA (data in)
input TCK; // CPLD -> FPGA (clk)
input TCS; // CPLD -> FPGA (CS)
output TDO; // FPGA -> CPLD (data out)
//////////////////////// VGA ////////////////////////////
output VGA_HS; // VGA H_SYNC
output VGA_VS; // VGA V_SYNC
output [3:0] VGA_R; // VGA Red[3:0]
output [3:0] VGA_G; // VGA Green[3:0]
output [3:0] VGA_B; // VGA Blue[3:0]
//////////////////// Audio CODEC ////////////////////////////
inout AUD_ADCLRCK; // Audio CODEC ADC LR Clock
input AUD_ADCDAT; // Audio CODEC ADC Data
inout AUD_DACLRCK; // Audio CODEC DAC LR Clock
output AUD_DACDAT; // Audio CODEC DAC Data
inout AUD_BCLK; // Audio CODEC Bit-Stream Clock
output AUD_XCK; // Audio CODEC Chip Clock
//////////////////////// GPIO ////////////////////////////////
inout [35:0] GPIO_0; // GPIO Connection 0
inout [35:0] GPIO_1; // GPIO Connection 1
// Turn on all display
assign HEX0 = 7'h00;
assign HEX1 = 7'h00;
assign HEX2 = 7'h00;
assign HEX3 = 7'h00;
assign LEDG = VOL;
assign LEDR = 10'h3FF;
// All inout port turn to tri-state
assign DRAM_DQ = 16'hzzzz;
assign FL_DQ = 8'hzz;
assign SRAM_DQ = 16'hzzzz;
assign SD_DAT = 1'bz;
assign I2C_SDAT = 1'bz;
assign GPIO_0 = 36'hzzzzzzzzz;
assign GPIO_1 = 36'hzzzzzzzzz;
assign AUD_DACLRCK = AUD_ADCDAT;
assign AUD_XCK = CLK_18_4;
wire CLK_18_4;
PLL u0 ( .inclk0(CLOCK_27[0]),
.c0(CLK_18_4) );
I2C_AV_Config u1 ( // Host Side
.iCLK(CLOCK_50),
.iRST_N(KEY[0]),
.iVOL(VOL),
// I2C Side
.I2C_SCLK(I2C_SCLK),
.I2C_SDAT(I2C_SDAT) );
reg [6:0] VOL;
always@(negedge KEY[0])
begin
if(VOL<68)
VOL <= 98;
VOL <= VOL+3;
end
endmodule |
