发表于 2011-4-11 12:47:26
///////////////////// Macros / Structs etc //////////////////////////
#ifndef __SERIALPORT_H__
#define __SERIALPORT_H__
/////////////////////////// Classes ///////////////////////////////////////////
////// Serial port exception class ////////////////////////////////////////////
void AfxThrowSerialException(DWORD dwError = 0);
typedef void (* pOnReceiveData)(void*,DWORD);
class CSerialException : public CException
public:
//Constructors / Destructors
CSerialException(DWORD dwError);
~CSerialException();
//Methods
#ifdef _DEBUG
virtual void Dump(CDumpContext& dc) const;
virtual BOOL GetErrorMessage(LPTSTR lpstrError, UINT nMaxError, PUINT pnHelpContext = NULL);
CString GetErrorMessage();
//Data members
DWORD m_dwError;
protected:
DECLARE_DYNAMIC(CSerialException)
//// The actual serial port class /////////////////////////////////////////////
class CSerialPort : public CObject
public:
//Enums
enum FlowControl
NoFlowControl,
CtsRtsFlowControl,
CtsDtrFlowControl,
DsrRtsFlowControl,
DsrDtrFlowControl,
XonXoffFlowControl
enum Parity
EvenParity,
MarkParity,
NoParity,
OddParity,
SpaceParity
enum StopBits
OneStopBit,
OnePointFiveStopBits,
TwoStopBits
CSerialPort();
virtual ~CSerialPort();
//General Methods
BOOL Open(int nPort, DWORD dwBaud = 9600, Parity parity = NoParity, BYTE DataBits = 8,
StopBits stopbits = OneStopBit, FlowControl fc = NoFlowControl, BOOL bOverlapped = FALSE);
void Close();
void Attach(HANDLE hComm, BOOL bOverlapped = FALSE);
HANDLE Detach();
operator HANDLE() const { return m_hComm; };
BOOL IsOpen() const { return m_hComm != INVALID_HANDLE_VALUE; };
#ifdef _DEBUG
//Reading / Writing Methods
DWORD Read(void* lpBuf, DWORD dwCount);
BOOL Read(void* lpBuf, DWORD dwCount, OVERLAPPED& overlapped, DWORD* pBytesRead=NULL);
void ReadEx(void* lpBuf, DWORD dwCount);
DWORD Write(const void* lpBuf, DWORD dwCount);
BOOL Write(const void* lpBuf, DWORD dwCount, OVERLAPPED& overlapped, DWORD* pBytesWritten=NULL);
void WriteEx(const void* lpBuf, DWORD dwCount);
void TransmitChar(char cChar);
bool GetOverlappedResult(OVERLAPPED& overlapped, DWORD& dwBytesTransferred, BOOL bWait);
void CancelIo();
DWORD BytesWaiting();
BOOL DataWaiting(DWORD dwTimeout);
//Configuration Methods
void GetConfig(COMMCONFIG& config);
static void GetDefaultConfig(int nPort, COMMCONFIG& config);
void SetConfig(COMMCONFIG& Config);
static void SetDefaultConfig(int nPort, COMMCONFIG& config);
//Misc RS232 Methods
void ClearBreak();
void SetBreak();
void ClearError(DWORD& dwErrors);
void GetStatus(COMSTAT& stat);
void GetState(DCB& dcb);
void SetState(DCB& dcb);
void Escape(DWORD dwFunc);
void ClearDTR();
void ClearRTS();
void SetDTR();
void SetRTS();
void SetXOFF();
void SetXON();
void GetProperties(COMMPROP& properties);
void GetModemStatus(DWORD& dwModemStatus);
//Timeouts
void SetTimeouts(COMMTIMEOUTS& timeouts);
void GetTimeouts(COMMTIMEOUTS& timeouts);
void Set0Timeout();
void Set0WriteTimeout();
void Set0ReadTimeout();
//Event Methods
void SetMask(DWORD dwMask);
void GetMask(DWORD& dwMask);
bool WaitEvent(DWORD& dwMask);
BOOL WaitEvent(DWORD& dwMask, OVERLAPPED& overlapped);
//Queue Methods
void Flush();
void Purge(DWORD dwFlags);
void TerminateOutstandingWrites();
void TerminateOutstandingReads();
void ClearWriteBuffer();
void ClearReadBuffer();
void Setup(DWORD dwInQueue, DWORD dwOutQueue);
//Overridables
virtual void OnCompletion(DWORD dwErrorCode, DWORD dwCount, LPOVERLAPPED lpOverlapped);
int GetComPortNum() { return m_CurPortNum; }
protected:
HANDLE m_hComm; //Handle to the comms port
BOOL m_bOverlapped; //Is the port open in overlapped IO
HANDLE m_hEvent; //A event handle we need for internal synchronisation
int m_CurPortNum; //当前串口号
static void WINAPI _OnCompletion(DWORD dwErrorCode, DWORD dwCount, LPOVERLAPPED lpOverlapped);
DECLARE_DYNAMIC(CSerialPort)
public:
pOnReceiveData OnReceiveData;
#endif //__SERIALPORT_H__
///////////////////////////////// Includes //////////////////////////////////
#include "stdafx.h"
#include "serialport.h"
#ifndef _WINERROR_
#include "winerror.h"
///////////////////////////////// defines /////////////////////////////////////
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
//////////////////////////////// Implementation ///////////////////////////////
class _SERIAL_PORT_DATA
public:
//Constructors /Destructors
_SERIAL_PORT_DATA();
~_SERIAL_PORT_DATA();
HINSTANCE m_hKernel32;
typedef BOOL (WINAPI CANCELIO)(HANDLE);
typedef CANCELIO* LPCANCELIO;
LPCANCELIO m_lpfnCancelIo;
_SERIAL_PORT_DATA::_SERIAL_PORT_DATA()
m_hKernel32 = LoadLibrary(_T("KERNEL32.DLL"));
VERIFY(m_hKernel32 != NULL);
m_lpfnCancelIo = (LPCANCELIO) GetProcAddress(m_hKernel32, "CancelIo");
_SERIAL_PORT_DATA::~_SERIAL_PORT_DATA()
FreeLibrary(m_hKernel32);
m_hKernel32 = NULL;
//The local variable which handle the function pointers
_SERIAL_PORT_DATA _SerialPortData;
////////// Exception handling code
void AfxThrowSerialException(DWORD dwError /* = 0 */)
if (dwError == 0)
dwError = ::GetLastError();
CSerialException* pException = new CSerialException(dwError);
TRACE(_T("Warning: throwing CSerialException for error %d\n"), dwError);
//THROW(pException);
BOOL CSerialException::GetErrorMessage(LPTSTR pstrError, UINT nMaxError, PUINT pnHelpContext)
ASSERT(pstrError != NULL && AfxIsValidString(pstrError, nMaxError));
if (pnHelpContext != NULL)
*pnHelpContext = 0;
LPTSTR lpBuffer;
BOOL bRet = FormatMessage(FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
NULL, m_dwError, MAKELANGID(LANG_NEUTRAL, SUBLANG_SYS_DEFAULT),
(LPTSTR) &lpBuffer, 0, NULL);
if (bRet == FALSE)
*pstrError = '\0';
lstrcpyn(pstrError, lpBuffer, nMaxError);
bRet = TRUE;
LocalFree(lpBuffer);
return bRet;
CString CSerialException::GetErrorMessage()
CString rVal;
LPTSTR pstrError = rVal.GetBuffer(4096);
GetErrorMessage(pstrError, 4096, NULL);
rVal.ReleaseBuffer();
return rVal;
CSerialException::CSerialException(DWORD dwError)
m_dwError = dwError;
CSerialException::~CSerialException()
IMPLEMENT_DYNAMIC(CSerialException, CException)
#ifdef _DEBUG
void CSerialException::Dump(CDumpContext& dc) const
CObject::Dump(dc);
dc << "m_dwError = " << m_dwError;
////////// The actual serial port code
CSerialPort::CSerialPort()
m_hComm = INVALID_HANDLE_VALUE;
m_bOverlapped = FALSE;
m_hEvent = NULL;
CSerialPort::~CSerialPort()
Close();
IMPLEMENT_DYNAMIC(CSerialPort, CObject)
#ifdef _DEBUG
void CSerialPort::Dump(CDumpContext& dc) const
CObject::Dump(dc);
dc << _T("m_hComm = ") << m_hComm << _T("\n");
dc << _T("m_bOverlapped = ") << m_bOverlapped;
BOOL CSerialPort::Open(int nPort, DWORD dwBaud, Parity parity, BYTE DataBits, StopBits stopbits, FlowControl fc, BOOL bOverlapped)
//Validate our parameters
ASSERT(nPort>0 && nPort<=255);
Close(); //In case we are already open
//Call CreateFile to open up the comms port
CString sPort;
sPort.Format(_T("\\\\.\\COM%d"), nPort);
DWORD dwCreateProperty;
if(bOverlapped)
dwCreateProperty=FILE_ATTRIBUTE_NORMAL | FILE_FLAG_OVERLAPPED;
dwCreateProperty=FILE_ATTRIBUTE_NORMAL;
// bOverlapped ? FILE_FLAG_OVERLAPPED : 0
m_hComm = CreateFile(sPort, GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING,dwCreateProperty, NULL);
if (m_hComm == INVALID_HANDLE_VALUE)
TRACE(_T("Failed to open up the comms port\n"));
//AfxThrowSerialException();
return FALSE;
this->m_CurPortNum = nPort;
m_bOverlapped = bOverlapped;
//Get the current state prior to changing it
DCB dcb;
dcb.DCBlength = sizeof(DCB);
GetState(dcb);
//Setup the baud rate
dcb.BaudRate = dwBaud;
//Setup the Parity
switch (parity)
case EvenParity: dcb.Parity = EVENPARITY; break;
case MarkParity: dcb.Parity = MARKPARITY; break;
case NoParity: dcb.Parity = NOPARITY; break;
case OddParity: dcb.Parity = ODDPARITY; break;
case SpaceParity: dcb.Parity = SPACEPARITY; break;
default: ASSERT(FALSE); break;
//Setup the data bits
dcb.ByteSize = DataBits;
//Setup the stop bits
switch (stopbits)
case OneStopBit: dcb.StopBits = ONESTOPBIT; break;
case OnePointFiveStopBits: dcb.StopBits = ONE5STOPBITS; break;
case TwoStopBits: dcb.StopBits = TWOSTOPBITS; break;
//Setup the flow control
dcb.fDsrSensitivity = FALSE;
switch (fc)
case NoFlowControl:
dcb.fOutxCtsFlow = FALSE;
dcb.fOutxDsrFlow = FALSE;
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
case CtsRtsFlowControl:
dcb.fOutxCtsFlow = TRUE;
dcb.fRtsControl = RTS_CONTROL_HANDSHAKE;
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
case CtsDtrFlowControl:
dcb.fDtrControl = DTR_CONTROL_HANDSHAKE;
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
case DsrRtsFlowControl:
dcb.fOutxDsrFlow = TRUE;
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
case DsrDtrFlowControl:
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
case XonXoffFlowControl:
dcb.fOutX = TRUE;
dcb.fInX = TRUE;
dcb.XonChar = 0x11;
dcb.XoffChar = 0x13;
dcb.XoffLim = 100;
dcb.XonLim = 100;
default:
ASSERT(FALSE);
//Now that we have all the settings in place, make the changes
SetState(dcb);
return TRUE;
void CSerialPort::Close()
if (IsOpen())
//Close down the comms port
BOOL bSuccess = CloseHandle(m_hComm);
if (!bSuccess)
TRACE(_T("Failed to close up the comms port, GetLastError:%d\n"), GetLastError());
//Free up the event object we are using
if(m_hEvent)
CloseHandle(m_hEvent);
m_hEvent = NULL;
void CSerialPort::Attach(HANDLE hComm, BOOL bOverlapped)
Close();
m_hComm = hComm;
//Create the event we need for later synchronisation use
m_hEvent = CreateEvent(NULL, FALSE, FALSE, NULL);
if (m_hEvent == NULL)
Close();
TRACE(_T("Failed in call to CreateEvent in Attach\n"));
HANDLE CSerialPort::Detach()
HANDLE hrVal = m_hComm;
m_hEvent = NULL;
return hrVal;
DWORD CSerialPort::Read(void* lpBuf, DWORD dwCount)
ASSERT(IsOpen());
ASSERT(!m_bOverlapped);
DWORD Errors;
COMSTAT comstat;
BOOL ok;
ok = ::ClearCommError(this->m_hComm,&Errors,&comstat);
if(!ok)
return 0;
if(comstat.cbInQue==0)
return 0;
DWORD dwBytesRead = 0;
if (!ReadFile(m_hComm, lpBuf, comstat.cbInQue, &dwBytesRead, NULL))
TRACE(_T("Failed in call to ReadFile\n"));
return dwBytesRead;
BOOL CSerialPort::Read(void* lpBuf, DWORD dwCount, OVERLAPPED& overlapped, DWORD* pBytesRead)
ASSERT(IsOpen());
ASSERT(m_bOverlapped);
BOOL bSuccess = ReadFile(m_hComm, lpBuf, dwCount, &dwBytesRead, &overlapped);
if (!bSuccess)
if (GetLastError() != ERROR_IO_PENDING)
if (pBytesRead)
*pBytesRead = dwBytesRead;
return bSuccess;
DWORD CSerialPort::Write(const void* lpBuf, DWORD dwCount)
ASSERT(IsOpen());
DWORD dwBytesWritten = 0;
if (!WriteFile(m_hComm, lpBuf, dwCount, &dwBytesWritten, NULL))
TRACE(_T("Failed in call to WriteFile\n"));
return dwBytesWritten;
BOOL CSerialPort::Write(const void* lpBuf, DWORD dwCount, OVERLAPPED& overlapped, DWORD* pBytesWritten)
ASSERT(IsOpen());
BOOL bSuccess = WriteFile(m_hComm, lpBuf, dwCount, &dwBytesWritten, &overlapped);
if (!bSuccess)
if (pBytesWritten)
*pBytesWritten = dwBytesWritten;
return bSuccess;
bool CSerialPort::GetOverlappedResult(OVERLAPPED& overlapped, DWORD& dwBytesTransferred, BOOL bWait)
ASSERT(IsOpen());
BOOL bSuccess = ::GetOverlappedResult(m_hComm, &overlapped, &dwBytesTransferred, bWait);
if (!bSuccess)
TRACE(_T("Failed in call to GetOverlappedResult\n"));
return (bSuccess==TRUE?true:false);
void CSerialPort::_OnCompletion(DWORD dwErrorCode, DWORD dwCount, LPOVERLAPPED lpOverlapped)
ASSERT(lpOverlapped);
//Convert back to the C++ world
CSerialPort* pSerialPort = (CSerialPort*) lpOverlapped->hEvent;
ASSERT(pSerialPort);
ASSERT(pSerialPort->IsKindOf(RUNTIME_CLASS(CSerialPort)));
//Call the C++ function
pSerialPort->OnCompletion(dwErrorCode, dwCount, lpOverlapped);
void CSerialPort::OnCompletion(DWORD /*dwErrorCode*/, DWORD /*dwCount*/, LPOVERLAPPED lpOverlapped)
//Just free up the memory which was previously allocated for the OVERLAPPED structure
delete lpOverlapped;
//Your derived classes can do something useful in OnCompletion, but don't forget to
//call CSerialPort::OnCompletion to ensure the memory is freed up
void CSerialPort::CancelIo()
ASSERT(IsOpen());
if (_SerialPortData.m_lpfnCancelIo == NULL)
TRACE(_T("CancelIo function is not supported on this OS. You need to be running at least NT 4 or Win 98 to use this function\n"));
AfxThrowSerialException(ERROR_CALL_NOT_IMPLEMENTED);
if (!::_SerialPortData.m_lpfnCancelIo(m_hComm))
TRACE(_T("Failed in call to CancelIO\n"));
DWORD CSerialPort::BytesWaiting()
ASSERT(IsOpen());
//Check to see how many characters are unread
COMSTAT stat;
GetStatus(stat);
return stat.cbInQue;
BOOL CSerialPort::DataWaiting(DWORD dwTimeout)
ASSERT(IsOpen());
ASSERT(m_hEvent);
//Setup to wait for incoming data
DWORD dwOldMask;
GetMask(dwOldMask);
SetMask(EV_RXCHAR);
//Setup the overlapped structure
OVERLAPPED o;
o.hEvent = m_hEvent;
//Assume the worst;
BOOL bSuccess = FALSE;
DWORD dwEvent;
bSuccess = WaitEvent(dwEvent, o);
if (!bSuccess)
if (WaitForSingleObject(o.hEvent, dwTimeout) == WAIT_OBJECT_0)
DWORD dwBytesTransferred;
GetOverlappedResult(o, dwBytesTransferred, FALSE);
bSuccess = TRUE;
//Reset the event mask
SetMask(dwOldMask);
return bSuccess;
void CSerialPort::WriteEx(const void* lpBuf, DWORD dwCount)
ASSERT(IsOpen());
OVERLAPPED* pOverlapped = new OVERLAPPED;
ZeroMemory(pOverlapped, sizeof(OVERLAPPED));
pOverlapped->hEvent = (HANDLE) this;
if (!WriteFileEx(m_hComm, lpBuf, dwCount, pOverlapped, _OnCompletion))
delete pOverlapped;
TRACE(_T("Failed in call to WriteFileEx\n"));
void CSerialPort::ReadEx(void* lpBuf, DWORD dwCount)
ASSERT(IsOpen());
if (!ReadFileEx(m_hComm, lpBuf, dwCount, pOverlapped, _OnCompletion))
delete pOverlapped;
TRACE(_T("Failed in call to ReadFileEx\n"));
void CSerialPort::TransmitChar(char cChar)
ASSERT(IsOpen());
if (!TransmitCommChar(m_hComm, cChar))
TRACE(_T("Failed in call to TransmitCommChar\n"));
void CSerialPort::GetConfig(COMMCONFIG& config)
ASSERT(IsOpen());
DWORD dwSize = sizeof(COMMCONFIG);
if (!GetCommConfig(m_hComm, &config, &dwSize))
TRACE(_T("Failed in call to GetCommConfig\n"));
void CSerialPort::SetConfig(COMMCONFIG& config)
ASSERT(IsOpen());
if (!SetCommConfig(m_hComm, &config, dwSize))
TRACE(_T("Failed in call to SetCommConfig\n"));
void CSerialPort::SetBreak()
ASSERT(IsOpen());
if (!SetCommBreak(m_hComm))
TRACE(_T("Failed in call to SetCommBreak\n"));
void CSerialPort::ClearBreak()
ASSERT(IsOpen());
if (!ClearCommBreak(m_hComm))
void CSerialPort::ClearError(DWORD& dwErrors)
ASSERT(IsOpen());
if (!ClearCommError(m_hComm, &dwErrors, NULL))
TRACE(_T("Failed in call to ClearCommError\n"));
void CSerialPort::GetDefaultConfig(int nPort, COMMCONFIG& config)
//Create the device name as a string
CString sPort;
sPort.Format(_T("COM%d"), nPort);
if (!GetDefaultCommConfig(sPort, &config, &dwSize))
TRACE(_T("Failed in call to GetDefaultCommConfig\n"));
void CSerialPort::SetDefaultConfig(int nPort, COMMCONFIG& config)
CString sPort;
if (!SetDefaultCommConfig(sPort, &config, dwSize))
void CSerialPort::GetStatus(COMSTAT& stat)
ASSERT(IsOpen());
DWORD dwErrors;
if (!ClearCommError(m_hComm, &dwErrors, &stat))
void CSerialPort::GetState(DCB& dcb)
ASSERT(IsOpen());
if (!GetCommState(m_hComm, &dcb))
TRACE(_T("Failed in call to GetCommState\n"));
void CSerialPort::SetState(DCB& dcb)
ASSERT(IsOpen());
if (!SetCommState(m_hComm, &dcb))
TRACE(_T("Failed in call to SetCommState\n"));
void CSerialPort::Escape(DWORD dwFunc)
ASSERT(IsOpen());
if (!EscapeCommFunction(m_hComm, dwFunc))
TRACE(_T("Failed in call to EscapeCommFunction\n"));
void CSerialPort::ClearDTR()
Escape(CLRDTR);
void CSerialPort::ClearRTS()
Escape(CLRRTS);
void CSerialPort::SetDTR()
Escape(SETDTR);
void CSerialPort::SetRTS()
Escape(SETRTS);
void CSerialPort::SetXOFF()
Escape(SETXOFF);
void CSerialPort::SetXON()
Escape(SETXON);
void CSerialPort::GetProperties(COMMPROP& properties)
ASSERT(IsOpen());
if (!GetCommProperties(m_hComm, &properties))
TRACE(_T("Failed in call to GetCommProperties\n"));
void CSerialPort::GetModemStatus(DWORD& dwModemStatus)
ASSERT(IsOpen());
if (!GetCommModemStatus(m_hComm, &dwModemStatus))
TRACE(_T("Failed in call to GetCommModemStatus\n"));
void CSerialPort::SetMask(DWORD dwMask)
ASSERT(IsOpen());
if (!SetCommMask(m_hComm, dwMask))
TRACE(_T("Failed in call to SetCommMask\n"));
void CSerialPort::GetMask(DWORD& dwMask)
ASSERT(IsOpen());
if (!GetCommMask(m_hComm, &dwMask))
TRACE(_T("Failed in call to GetCommMask\n"));
void CSerialPort::Flush()
ASSERT(IsOpen());
if (!FlushFileBuffers(m_hComm))
TRACE(_T("Failed in call to FlushFileBuffers\n"));
void CSerialPort::Purge(DWORD dwFlags)
ASSERT(IsOpen());
if (!PurgeComm(m_hComm, dwFlags))
TRACE(_T("Failed in call to PurgeComm\n"));
void CSerialPort::TerminateOutstandingWrites()
Purge(PURGE_TXABORT);
void CSerialPort::TerminateOutstandingReads()
Purge(PURGE_RXABORT);
void CSerialPort::ClearWriteBuffer()
Purge(PURGE_TXCLEAR);
void CSerialPort::ClearReadBuffer()
Purge(PURGE_RXCLEAR);
void CSerialPort::Setup(DWORD dwInQueue, DWORD dwOutQueue)
ASSERT(IsOpen());
if (!SetupComm(m_hComm, dwInQueue, dwOutQueue))
TRACE(_T("Failed in call to SetupComm\n"));
void CSerialPort::SetTimeouts(COMMTIMEOUTS& timeouts)
ASSERT(IsOpen());
if (!SetCommTimeouts(m_hComm, &timeouts))
TRACE(_T("Failed in call to SetCommTimeouts\n"));
void CSerialPort::GetTimeouts(COMMTIMEOUTS& timeouts)
ASSERT(IsOpen());
if (!GetCommTimeouts(m_hComm, &timeouts))
TRACE(_T("Failed in call to GetCommTimeouts\n"));
void CSerialPort::Set0Timeout()
COMMTIMEOUTS Timeouts;
ZeroMemory(&Timeouts, sizeof(COMMTIMEOUTS));
Timeouts.ReadIntervalTimeout = MAXDWORD;
SetTimeouts(Timeouts);
void CSerialPort::Set0WriteTimeout()
GetTimeouts(Timeouts);
Timeouts.WriteTotalTimeoutMultiplier = 0;
Timeouts.WriteTotalTimeoutConstant = 0;
void CSerialPort::Set0ReadTimeout()
Timeouts.ReadTotalTimeoutMultiplier = 0;
Timeouts.ReadTotalTimeoutConstant = 0;
bool CSerialPort::WaitEvent(DWORD& dwMask)
ASSERT(IsOpen());
if (!WaitCommEvent(m_hComm, &dwMask, NULL))
TRACE(_T("Failed in call to WaitCommEvent\n"));
return false;
return true;
BOOL CSerialPort::WaitEvent(DWORD& dwMask, OVERLAPPED& overlapped)
ASSERT(IsOpen());
ASSERT(overlapped.hEvent);
BOOL bSuccess = WaitCommEvent(m_hComm, &dwMask, &overlapped);
if (!bSuccess)
return bSuccess;
