linux用2.6.30
文件系统用debian,爽啊,直接安装。
U-Boot 1.3.4 (Apr 2 2011 - 10:41:37)
DRAM: 64 MB
NAND: 512 MiB
DataFlash:AT45DB321
Nb pages: 8192
Page Size: 528
Size= 4325376 bytes
Logical address: 0xC0000000
Area 0: C0000000 to C00041FF (RO) Bootstrap
Area 1: C0004200 to C00083FF Environment
Area 2: C0008400 to C0041FFF (RO) U-Boot
Area 3: C0042000 to C0251FFF Kernel
Area 4: C0252000 to C041FFFF FS
In: serial
Out: serial
Err: serial
Net: macb0
macb0: Starting autonegotiation...
macb0: Autonegotiation complete
macb0: link up, 100Mbps full-duplex (lpa: 0xcde1)
Hit any key to stop autoboot: 0
## Booting kernel from Legacy Image at 22200000 ...
Image Name: Linux-2.6.30
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1691252 Bytes = 1.6 MB
Load Address: 20008000
Entry Point: 20008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux........................................................................................................... done, booting the kernel.
Linux version 2.6.30 (root@debian) (gcc version 4.3.5 (Buildroot 2011.02) ) #1 Sat Apr 2 13:54:45 CST 2011
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Atmel AT91SAM9260-EK
Memory policy: ECC disabled, Data cache writeback
Clocks: CPU 198 MHz, master 99 MHz, main 18.432 MHz
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: mem=64M console=ttyS0,115200 mtdparts=atmel_nand:4M(bootstrap/uboot/kernel)ro,480M(rootfs),-(data) root=/dev/mtdblock1 rw rootfstype=jffs2
NR_IRQS:192
AT91: 96 gpio irqs in 3 banks
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttyS0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61480KB available (2960K code, 232K data, 112K init, 0K highmem)
Calibrating delay loop... 99.12 BogoMIPS (lpj=495616)
CPU: Testing write buffer coherency: ok
net_namespace: 296 bytes
AT91: Power Management
AT91: Starting after software reset
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 120
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIAL
atmel_usart.2: ttyS2 at MMIO 0xfffb4000 (irq = 7) is a ATMEL_SERIAL
brd: module loaded
loop: module loaded
ssc ssc.0: Atmel SSC device at 0xc4870000 (irq 14)
Driver 'sd' needs updating - please use bus_type methods
MACB_mii_bus: probed
eth0: Atmel MACB at 0xfffc4000 irq 21 (3a:1f:34:08:54:54)
eth0: attached PHY driver [Davicom DM9161A] (mii_bus:phy_addr=ffffffff:00, irq=-1)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit)
AT91 NAND: 8-bit, Software ECC
Scanning device for bad blocks
3 cmdlinepart partitions found on MTD device atmel_nand
Creating 3 MTD partitions on "atmel_nand":
0x000000000000-0x000000400000 : "bootstrap/uboot/kernel"
0x000000400000-0x00001e400000 : "rootfs"
0x00001e400000-0x000020000000 : "data"
atmel_spi atmel_spi.1: Atmel SPI Controller at 0xfffcc000 (irq 13)
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
at91_ohci at91_ohci: AT91 OHCI
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1
at91_ohci at91_ohci: irq 20, io mem 0x00500000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
udc: at91_udc version 3 May 2006
mice: PS/2 mouse device common for all mice
input: gpio-keys as /class/input/input0
rtc-at91sam9 at91_rtt.0: rtc core: registered at91_rtt as rtc0
IRQ 1/rtc0: IRQF_DISABLED is not guaranteed on shared IRQs
rtc-at91sam9 at91_rtt.0: rtc0: SET TIME!
Registered led device: ds5
Registered led device: ds1
Advanced Linux Sound Architecture Driver Version 1.0.20.
at73c213 spi1.0: at73c213: supported bitrate is 48500 (64 divider)
ALSA device list:
#0: AT91SAM9260-EK external DAC on irq 14
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
lib80211: common routines for IEEE802.11 drivers
rtc-at91sam9 at91_rtt.0: hctosys: unable to read the hardware clock
Empty flash at 0x0a349d78 ends at 0x0a34a000
VFS: Mounted root (jffs2 filesystem) on device 31:1.
Freeing init memory: 112K
modprobe: FATAL: Could not load /lib/modules/2.6.30/modules.dep: No such file or directory
INIT: version 2.86 booting
Setting the system clock.
RTC_RD_TIME: Invalid or incomplete multibyte or wide character
ioctl() to /dev/rtc to read the time failed.
Unable to set System Clock to: Thu Jan 1 00:00:36 UTC 1970 (warning).
Activating swap...done.
Unable to set System Clock to: Thu Jan 1 00:00:37 UTC 1970 (warning).
Cleaning up ifupdown....
Loading kernel modules...FATAL: Could not load /lib/modules/2.6.30/modules.dep: No such file or directory
Checking file systems...JFFS2 warning: (510) jffs2_sum_write_data: Not enough space for summary, padsize = -1156
fsck 1.41.3 (12-Oct-2008)
done.
Setting kernel variables (/etc/sysctl.conf)...done.
Mounting local filesystems...done.
Activating swapfile swap...done.
Setting up networking....
Configuring network interfaces...done.
INIT: Entering runlevel: 2
Starting enhanced syslogd: rsyslogd.
Starting periodic command scheduler: crond.
Starting web server: apache2.
Debian GNU/Linux 5.0 NAS ttyS0
NAS login: root
Last login: Thu Jan 1 00:01:13 UTC 1970 on ttyS0
Linux NAS 2.6.30 #1 Sat Apr 2 13:54:45 CST 2011 armv5tejl
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
NAS:~# |
