发表于 2011-4-4 21:52:07
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
---------TOP LEVEL ENTITY---------
ENTITY CPLD IS
PORT
CLK:IN STD_LOGIC;
----------LEDS------------
LED : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
--------SDRAMIO-----------
signal sdram_clk : OUT STD_LOGIC;
signal sdram_cke : OUT STD_LOGIC;
signal sdram_ba : OUT STD_LOGIC_VECTOR (1 DOWNTO 0);
signal sdram_addr : OUT STD_LOGIC_VECTOR (11 DOWNTO 0);
signal sdram_cs_n : OUT STD_LOGIC;
signal sdram_ras_n : OUT STD_LOGIC;
signal sdram_cas_n : OUT STD_LOGIC;
signal sdram_we_n : OUT STD_LOGIC;
signal sdram_dq : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0);
-------CONNECTS2FSMC-------
FSMCNOE:IN STD_LOGIC;
FSMCNWE:IN STD_LOGIC;
FSMCNE:IN STD_LOGIC;
STMIO1:INOUT STD_LOGIC;
STMIO2:INOUT STD_LOGIC;
FSMCADDR0:IN STD_LOGIC;
FSMCADDR1:IN STD_LOGIC;
FSMCADDR2:IN STD_LOGIC;
FSMCDATA:INOUT STD_LOGIC_VECTOR(15 DOWNTO 0);
-------OUTIOS--------------
OUTCS:OUT STD_LOGIC;
OUTRS:OUT STD_LOGIC;
OUTRW:OUT STD_LOGIC;
OUTRD:OUT STD_LOGIC;
OUTRT:OUT STD_LOGIC;
OUTM3:OUT STD_LOGIC;
OUTM0:OUT STD_LOGIC;
OUTDATA:INOUT STD_LOGIC_VECTOR(15 DOWNTO 0)
END;
ARCHITECTURE behave OF CPLD IS
SIGNAL DATACI:STD_LOGIC_VECTOR (15 DOWNTO 0);
SIGNAL DATACO:STD_LOGIC_VECTOR (15 DOWNTO 0);
BEGIN
OUTRT <= '1';
OUTM3 <= '1';
OUTM0 <= '0';
OUTCS <=FSMCNE;
OUTRS <= FSMCADDR0;
OUTRW <= FSMCNWE;
OUTRD <= FSMCNOE;
PROCESS (FSMCDATA,FSMCNE,FSMCNWE)
BEGIN
-----------if CS
IF (FSMCNE='0') THEN
-----------if RW
IF (FSMCNWE='0') THEN
DATACO <=FSMCDATA;
ELSE ---------if nRW
DATACO <="ZZZZZZZZZZZZZZZZ";
END IF;
END IF;
OUTDATA <=DATACO;
END PROCESS;
PROCESS (OUTDATA,FSMCNE,FSMCNWE)
BEGIN
-----------if CS
-----------if RW------------
DATACI <=OUTDATA;
ELSE
DATACI <="ZZZZZZZZZZZZZZZZ";
END IF;
END IF;
FSMCDATA <=DATACI;
END PROCESS;
END; |
