发表于 2011-4-1 10:55:32
llf021421 马中马
还是不行,这个是配置的icf文件。
中断向量表是放在了0x200000的sram中,
启动运行代码及其它内容在0x20000000的sdram中,
为什么编译生成bin文件就很大,但是编译生成hex文件时正常大小呢?
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\a_v1_0.xml" */
/*-Memory Regions-*/
define symbol __ICFEDIT_region_SDRAM_start__ = 0x20000000;
define symbol __ICFEDIT_region_SDRAM_end__ = 0x23FFFFFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x200000;
define symbol __ICFEDIT_region_RAM_end__ = 0x203FFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_startup__ = 0x100;
define symbol __ICFEDIT_size_vectors__ = 0x100;
define symbol __ICFEDIT_size_cstack__ = 0x2000;
define symbol __ICFEDIT_size_sysstack__ = 0x60;
define symbol __ICFEDIT_size_irqstack__ = 0x60;
define symbol __ICFEDIT_size_heap__ = 0x0;
/*-Exports-*/
export symbol __ICFEDIT_region_SDRAM_start__;
export symbol __ICFEDIT_region_SDRAM_end__;
export symbol __ICFEDIT_region_RAM_start__;
export symbol __ICFEDIT_region_RAM_end__;
export symbol __ICFEDIT_size_startup__;
export symbol __ICFEDIT_size_vectors__;
export symbol __ICFEDIT_size_cstack__;
export symbol __ICFEDIT_size_sysstack__;
export symbol __ICFEDIT_size_irqstack__;
export symbol __ICFEDIT_size_heap__;
/**** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
define region STA_region = mem:[from __ICFEDIT_region_SDRAM_start__ size __ICFEDIT_size_startup__];
define region SDRAM_region = mem:[from __ICFEDIT_region_SDRAM_start__+__ICFEDIT_size_startup__ to __ICFEDIT_region_SDRAM_end__];
define region VEC_region = mem:[from __ICFEDIT_region_RAM_start__ size __ICFEDIT_size_vectors__];
define region RAM_region = mem:[from __ICFEDIT_region_RAM_start__+__ICFEDIT_size_vectors__ to __ICFEDIT_region_RAM_end__];
define block CSTACK with alignment = 8, size = __ICFEDIT_size_cstack__ { };
define block SYS_STACK with alignment = 8, size = __ICFEDIT_size_sysstack__ { };
define block IRQ_STACK with alignment = 8, size = __ICFEDIT_size_irqstack__ { };
define block HEAP with alignment = 8, size = __ICFEDIT_size_heap__ { };
initialize by copy { section .vectors };
do not initialize { section .noinit };
place in STA_region { section .cstartup };
place in VEC_region { section .vectors };
place in SDRAM_region { readonly, readwrite, block IRQ_STACK, block SYS_STACK, block CSTACK, block HEAP }; |
