发表于 2014-2-11 15:12:54
这是我的config配置,png显示没有问题,我的是0.92版本的
# Microwindows and Nano-X configuration file
# This package can be configured to run on Linux (MIPS, ARM, POWERPC or x86)
# UNIX, ELKS, DJGPP, or RTEMS.
# On Linux, we've got drivers for Linux 2.x framebuffers, X11, or,
# svgalib for VGA hardware.
# In addition, a gpm or direct serial mouse driver can be configured.
# On ELKS, the bios screen driver and serial mouse driver are always used.
# Either Microwindows and/or Nano-X can be built.
# Microwindows and Nano-X have several demos.
# For MSDOS makes, see mcmwin.mak and mcnanox.mak
# build target platform
# Valid ARCH values are:
# LINUX-NATIVE
# LINUX-AVR32 (BIGENDIAN=Y)
# LINUX-TCC
# LINUX-ARM
# LINUX-MIPS
# LINUX-POWERPC (BIGENDIAN=Y)
# LINUX-SPARC (BIGENDIAN=Y)
# LINUX-BLACKFIN
# LINUX-SH
# FREEBSD-X86
# SOLARIS (BIGENDIAN=Y)
# TRIMEDIA
# RTEMS
# DJGPP
# ELKS
# note: ELKS can't build client/server nano-X, nor widget lib
ARCH = LINUX-ARM
BIGENDIAN = N
NATIVETOOLSPREFIX =
ARMTOOLSPREFIX = arm-linux-
MIPSTOOLSPREFIX = mipsel-linux-
POWERPCTOOLSPREFIX = powerpc-linux-
SHTOOLSPREFIX = sh-linux-gnu
AVR32TOOLSPREFIX = avr32-linux-
BLACKFINTOOLSPREFIX = bfin-uclinux-
PSPTOOLSPREFIX = psp-
# Compiling options
OPTIMIZE = Y
DEBUG = N
VERBOSE = N
THREADSAFE = Y
GPROF = N
# Libraries to build: microwin, nano-X, nanowidget, object frameworks
MICROWIN = N
NANOX = Y
SHAREDLIBS = N
OBJFRAMEWORK = N
# Demos to build
MICROWINDEMO = N
NANOXDEMO = Y
# Applications to build
NANOWM = N
FBEMULATOR = N
# The pixeltype of the native hardware or underlying graphics library.
# This definition defines the PIXELVAL to be 32, 16 or 8 bits wide.
# If using Linux framebuffer, set to MWPF_TRUECOLOR0888, and use fbset.
# It also enables GdArea/GrArea for this particular pixel packing format.
# define MWPF_PALETTE /* pixel is packed 8 bits 1, 4 or 8 pal index*/
# define MWPF_TRUECOLOR8888 /* pixel is packed 32 bits A/R/G/B truecolor w/alpha*/
# define MWPF_TRUECOLORABGR /* pixel is packed 32 bits A/B/G/R truecolor w/alpha*/
# define MWPF_TRUECOLOR0888 /* pixel is packed 32 bits 0/R/G/B truecolor 0 alpha*/
# define MWPF_TRUECOLOR888 /* pixel is packed 24 bits 8/8/8 truecolor*/
# define MWPF_TRUECOLOR565 /* pixel is packed 16 bits 5/6/5 truecolor*/
# define MWPF_TRUECOLOR555 /* pixel is packed 16 bits 5/5/5 truecolor*/
# define MWPF_TRUECOLOR332 /* pixel is packed 8 bits 3/3/2 truecolor*/
SCREEN_PIXTYPE = MWPF_TRUECOLOR565
# NanoX: Put Y to the following line to link the nano-X application
# with the server. This is required for ELKS, if no network is present,
# or for speed or debugging. This affects the nano-X server only.
LINK_APP_INTO_SERVER = Y
# Shared memory support for Nano-X client/server protocol speedup
HAVE_SHAREDMEM_SUPPORT = Y
# File I/O support
# Supporting either below drags in libc stdio, which may not be wanted
HAVE_FILEIO = Y
# BMP, GIF reading support
HAVE_BMP_SUPPORT = Y
HAVE_GIF_SUPPORT = Y
HAVE_PNM_SUPPORT = N
HAVE_XPM_SUPPORT = N
# JPEG support through libjpeg, see README.txt in contrib/jpeg
HAVE_JPEG_SUPPORT = N
INCJPEG = .
LIBJPEG = /usr/lib/libjpeg.so
# PNG support via libpng and libz
HAVE_PNG_SUPPORT = Y
INCPNG = /usr/local/arm/3.4.1/arm-linux/include/
LIBPNG = /usr/local/arm/3.4.1/arm-linux/lib/libpng.a
INCZ = /usr/local/arm/3.4.1/arm-linux/include/
LIBZ = /usr/local/arm/3.4.1/arm-linux/lib/libz.so
# TIFF support through libtiff
HAVE_TIFF_SUPPORT = N
INCTIFF = .
LIBTIFF = /usr/lib/libtiff.a
# PCF font support - .pcf/.pcf.gz loadable fonts
HAVE_PCF_SUPPORT = N
HAVE_PCFGZ_SUPPORT = N
PCF_FONT_DIR = "fonts/pcf"
# Truetype fonts - .ttf loadable fonts thru Freetype 2.x
HAVE_FREETYPE_2_SUPPORT = Y
INCFT2LIB = /usr/local/arm/3.4.1/arm-linux/include/
LIBFT2LIB = /usr/local/arm/3.4.1/arm-linux/lib/libfreetype.a
FREETYPE_FONT_DIR = "/mnt/fonts/truetype"
# T1 adobe type1 fonts - .pfb/.afm loadable thru t1lib
# t1lib.config must be setup and in T1LIB_FONT_DIR
HAVE_T1LIB_SUPPORT = N
T1LIB_FONT_DIR = "fonts/type1"
INCT1LIB = /usr/include
LIBT1LIB = /usr/lib/libt1.a
# FNT font support - .fnt/.fnt.gz loadable fonts (native bdf-converted)
HAVE_FNT_SUPPORT = N
HAVE_FNTGZ_SUPPORT = N
FNT_FONT_DIR = "fonts/fnt"
# Japanese EUC-JP support using loadable MGL font
HAVE_EUCJP_SUPPORT = N
EUCJP_FONT_DIR = "fonts/japanese"
# Chinese Han Zi Ku loadable font support
HAVE_HZK_SUPPORT = Y
HZK_FONT_DIR = "/mnt/fonts/chinese"
# DBCS Chinese BIG5 compiled in font support (big5font.c)
HAVE_BIG5_SUPPORT = N
# DBCS Chinese GB2312 compiled in font support (gb2312font.c)
HAVE_GB2312_SUPPORT = N
# DBCS Japanese JISX0213 compiled in font support (jisx0213-12x12.c)
HAVE_JISX0213_SUPPORT = N
# DBCS Korean HANGUL font support (jo16x16.c)
HAVE_KSC5601_SUPPORT = N
# Fribidi and shape/joining support for right to left rendering
HAVE_FRIBIDI_SUPPORT = N
HAVE_SHAPEJOINING_SUPPORT = N
INCFRIBIDI = $(TOP)/../../../include
LIBFRIBIDI = $(TOP)/../../../lib/libfribidi.a
# Generate screen driver interface only with no fonts or clipping
NOFONTSORCLIPPING = N
# Window move algorithms for Microwindows
# Change for tradeoff between cpu speed and looks
# ERASEMOVE repaints only backgrounds while window dragging, quicker.
# Otherwise an XOR redraw is used for window moves only after button up,
# quickest (should set for ELKS)
# UPDATEREGIONS paints in update clipping region only for better look and feel
ERASEMOVE = N
UPDATEREGIONS = N
# Link with Gray Palette (valid only for 4bpp modes)
GRAYPALETTE = N
# If the platform is running UNIX, Linux
ifneq ($(ARCH), ELKS)
# X Window screen, mouse and kbd drivers
X11 = N
ifeq ($(X11), Y)
# startup screen width, height, (depth for palette mode only)
SCREEN_WIDTH = 480
SCREEN_HEIGHT = 272
SCREEN_DEPTH = 16
# You may want to turn this on for XFree86 4.x or if your backing store
# isn't functioning properly
USE_EXPOSURE = N
# framebuffer screen driver (linear and/or vga 4 planes)
# set VTSWITCH to include virtual terminal switch code
# set FBREVERSE to reverse bit orders in 1,2,4 bpp
FBVGA = N
FRAMEBUFFER = Y
FBVGA = N
VTSWITCH = N
FBREVERSE = N
# set HAVETEXTMODE=Y for systems that can switch between text & graphics.
# On a graphics-only embedded system, such as Osprey and Embedded
# Planet boards, set HAVETEXTMODE=N
HAVETEXTMODE = N
# svgalib screen driver
VGALIB = N
# direct VGA hardware access screen driver
HWVGA = N
# PSP screen driver
PSP = N
# Mouse drivers
# GPMMOUSE gpm mouse
# SERMOUSE serial Microsoft, PC, Logitech, PS/2 mice (/dev/psaux)
# SUNMOUSE Sun Workstation mouse (/dev/sunmouse)
# NOMOUSE no mouse driver
# Touchscreen drivers
# IPAQMOUSE Compaq iPAQ, Intel Assabet (/dev/h3600_tsraw)
# ZAURUSMOUSE Sharp Zaurus (/dev/sharp_ts)
# TUXMOUSE TuxScreen (/dev/ucb1x00-ts)
# ADSMOUSE Applied Data Systems GC+ (/dev/ts)
# ADS7846MOUSE ADS7846 chip, PSI OMAP Innovator (/dev/innnovator_ts)
# EPMOUSE Embedded Planet (/dev/tpanel)
# VHMOUSE Vtech Helio (/dev/tpanel)
# MTMOUSE MicroTouch serial (/dev/ttyS1)
# PSIONMOUSE Psion 5 (/dev/touch_psion)
# YOPYMOUSE Yopy (/dev/yopy-ts)
# HARRIERMOUSE NEC Harrier (/dev/tpanel)
# TSLIBMOUSE Use tslib (/dev/input/event0)
# TTMOUSE TomTom GO and ONE (/dev/ts)
GPMMOUSE = N
SERMOUSE = N
SUNMOUSE = N
NOMOUSE = N
IPAQMOUSE = N
ZAURUSMOUSE = N
TUXMOUSE = N
ADSMOUSE = N
ADS7846MOUSE = N
EPMOUSE = N
VHMOUSE = N
MTMOUSE = N
PSIONMOUSE = N
YOPYMOUSE = N
HARRIERMOUSE = N
LIRCMOUSE = N
TSLIBMOUSE = Y
TTMOUSE = N
PSPMOUSE = N
# keyboard or null kbd driver
TTYKBD = N
SCANKBD = N
PIPEKBD = N
IPAQKBD = N
LIRCKBD = N
NOKBD = Y
endif
# Secondary keyboard drivers.
# You may have a normal keyboard driver in addition to these
# drivers, e.g. for both normal keyboard and IR input.
LIRCKBD2 = N
# VNC server support through libvncserver
HAVE_VNCSERVER_SUPPORT = N
VNCSERVER_PTHREADED = N
LIBVNC = /usr/lib/libvncserver.a
INCVNC = /usr/include
# Screen driver specific configuration
# SA1100_LCD_LTLEND 4bpp driver with arm SA1100 LCD controller
# INVERT4BPP 4bpp inverted pixel driver for VTech Helio
SA1100_LCD_LTLEND = N
INVERT4BPP = N
endif
# If the platform is an ELKS box ...
ifeq ($(ARCH), ELKS)
# Higher speed asm driver, c driver of hercules screen driver
ASMVGADRIVER = Y
CVGADRIVER = N
HERCDRIVER = N
# Mouse support
SERMOUSE = Y
endif |
