发表于 2011-6-1 12:09:15
* Intrinsic functions for the IAR Embedded Workbench for MSP430.
* Copyright 2002-2006 IAR Systems. All rights reserved.
* $Revision: 4055 $
#ifndef __INTRINSICS_H
#define __INTRINSICS_H
#ifndef _SYSTEM_BUILD
#pragma system_include
#pragma language=save
#pragma language=extended
* The return value of "__get_interrupt_state".
typedef unsigned short istate_t;
#ifdef __cplusplus
extern "C"
__intrinsic void __no_operation(void);
__intrinsic void __enable_interrupt(void);
__intrinsic void __disable_interrupt(void);
__intrinsic istate_t __get_interrupt_state(void);
__intrinsic void __set_interrupt_state(istate_t);
__intrinsic void __op_code(unsigned short);
__intrinsic unsigned short __swap_bytes(unsigned short);
__intrinsic void __bic_SR_register(unsigned short);
__intrinsic void __bis_SR_register(unsigned short);
__intrinsic unsigned short __get_SR_register(void);
__intrinsic void __bic_SR_register_on_exit(unsigned short);
__intrinsic void __bis_SR_register_on_exit(unsigned short);
__intrinsic unsigned short __get_SR_register_on_exit(void);
__intrinsic unsigned short __bcd_add_short(unsigned short,
unsigned short);
__intrinsic unsigned long __bcd_add_long (unsigned long,
unsigned long);
__intrinsic unsigned long long __bcd_add_long_long(unsigned long long,
unsigned long long);
* Support for efficient switch:es. E.g. switch(__even_in_range(x, 10))
* Note that the value must be even and in the range from 0 to
* __bound, inclusive. No code will be generated that checks this.
* This is typically used inside interrupt dispatch functions, to
* switch on special processor registers like TAIV.
__intrinsic unsigned short __even_in_range(unsigned short __value,
unsigned short __bound);
/* Insert a delay with a specific number of cycles. */
__intrinsic void __delay_cycles(unsigned long __cycles);
* The following R4/R5 intrinsic functions are only available when
* the corresponding register is locked.
__intrinsic unsigned short __get_R4_register(void);
__intrinsic void __set_R4_register(unsigned short);
__intrinsic unsigned short __get_R5_register(void);
__intrinsic void __set_R5_register(unsigned short);
__intrinsic unsigned short __get_SP_register(void);
__intrinsic void __set_SP_register(unsigned short);
* MSP430X-specific intrinsic functions.
* Intrinsic functions to allow access to the full 1 Mbyte memory
* range in small data model.
* The functions are available in medium and large data model
* aswell, however it is recommended to access memory using normal
* __data20 variables and/or pointers.
* Please note that interrupts must be disabled when the following
* intrinsics are used.
__intrinsic void __data20_write_char (unsigned long __addr,
unsigned char __value);
__intrinsic void __data20_write_short(unsigned long __addr,
unsigned short __value);
__intrinsic void __data20_write_long (unsigned long __addr,
unsigned long __value);
__intrinsic unsigned char __data20_read_char (unsigned long __addr);
__intrinsic unsigned short __data20_read_short(unsigned long __addr);
__intrinsic unsigned long __data20_read_long (unsigned long __addr);
* The following two functions can be used to access 20-bit SFRs in the
* lower 64kB. They are only available in extended mode (--core=430X).
__intrinsic void __data16_write_addr (unsigned short __addr,
__intrinsic unsigned long __data16_read_addr (unsigned short __addr);
#ifdef __cplusplus
* Alias for locations used for global register variables. For example,
* "__no_init __regvar int x @ __R4;".
#define __R4 4
#define __R5 5
* Control bits in the processor status register, SR.
#define __SR_GIE (1<<3)
#define __SR_CPU_OFF (1<<4)
#define __SR_OSC_OFF (1<<5)
#define __SR_SCG0 (1<<6)
#define __SR_SCG1 (1<<7)
* Functions for controlling the processor operation modes.
#define __low_power_mode_0() (__bis_SR_register( __SR_GIE \
| __SR_CPU_OFF))
#define __low_power_mode_1() (__bis_SR_register( __SR_GIE \
| __SR_CPU_OFF \ |
