/* FILE :NOHALL_BLDC.c */
/* DATE :Thu, Mar 03, 2011 */
/* DESCRIPTION :main program file. */
/* CPU GROUP :2K */
/* This file is generated by Renesas Project Generator (Ver.4.18). */
/* NOTE:THIS IS A TYPICAL EXAMPLE. */
#include "includes.h"
/* RAM
#define pLED p1_3 //LED
#define pTBU p1_6 //摇头同步电机光耦
#define pkey_TBU p1_5 //同步电机启/停
#define pkey_ON p3_3 //开关
#define pIR p1_4 //遥控接收
#define pTSU p0_5 //调试按钮
#define pIerror p4_5 //过流检测,过流保护
#define pICHECK p0_2 //启动电流检测
#define pMos p3_4 //控制MOS管输出,强制截止
#define pHUPWM p2_1 //U上臂
#define pLUPWM p2_3 //U下臂
#define pNU p2_2 //U相位
#define pHVPWM p2_4 //V上臂
#define pLVPWM p2_6 //V下臂
#define pNV p1_7 //V相位
#define pHWPWM p2_5 //W上臂
#define pLWPWM p2_7 //W下臂
#define pNW p2_0 //W相位
#define SENSER_DEG0 0x80
#define SENSER_DEG60 0x81
#define SENSER_DEG120 0x01
#define SENSER_DEG180 0x05
#define SENSER_DEG240 0x04
#define SENSER_DEG300 0x84
#define MOTOR_OFF 0x00
#define MOTOR_START 0x01
/* RAM
unsigned char flag_on = 0;
unsigned char flag_TBU = 0;
unsigned char ad_num = 0;
unsigned int dianliu_ad = 0;
unsigned int tiaosu_ad = 0;
unsigned int DutyCycle = 0;
unsigned int ClockTick = 0;
unsigned char ErrorFlag = 0;
unsigned char motor_sts = 0;
unsigned int CountTick = 0;
unsigned char SENSINPUT = 0;
unsigned int sens_count = 0;
/* ROM
/* Pragma
void MCU_Clock_Init (void); /* Initial setting of MCU operation clock */
void IO_Init(void);
void Timer_RA_Init (void); /* Initial setting of Timer RA SFR */
void Timer_RC_Init (void); /* Initial setting of Timer RC SFR */
void Timer_RD_Init (void); /* Initial setting of Timer RD SFR */
void ADC_Init(void);
static u08 _Sens_Input ( void );
void Motor_Start (void); /* Starting motor */
void State_Switch (unsigned char state); /* Switching to next state */
void Delay_10ms (unsigned char n); /* Delay n*10ms */
void delay_ms (int ms);
void Error_Process (void); /* User's error processing routine */
void tra_handler(void); /* Timer RA interrupt service routine */
void trc_handler(void); /* Timer RC interrupt service routine */
void int0_handler(void); /* INT0 interrupt service routine */
/* Main Program
MCU_Clock_Init(); /* Initial setting of MCU operation clock */
IO_Init();
Timer_RA_Init(); /* Initial setting of Timer RA SFR */
//Timer_RC_Init(); /* Initial setting of Timer RC SFR */
Timer_RD_Init(); /* Initial setting of Timer RD SFR */
ADC_Init();
asm("FSET I");
if (pkey_ON == 0)
if (flag_on == 0)
DutyCycle = 1235;
//Timer_RD_Init();
State_Switch(SENSER_DEG120);
SENSINPUT = SENSER_DEG120;
sens_count = 0;
//delay_ms(1);
trdstr = 0x0F;
//delay_ms(5);
flag_on = 1;
//pLED = 0;
flag_on = 0;
//pLED = 1;
if (flag_TBU == 1)
flag_TBU = 0;
// pTBU =1;
Delay_10ms(10);
while(!pkey_ON);
Delay_10ms(30);
if (pkey_TBU == 0)
if (flag_on == 1)
if (flag_TBU == 0)
flag_TBU = 1;
// pTBU = 0;
flag_TBU = 0;
// pTBU = 1;
Delay_10ms(10);
while(!pkey_TBU);
Delay_10ms(30);
/* MCU clock initialization
void MCU_Clock_Init(void)
_asm("FCLR I"); //Interrupt disabled
prc0=1; //Protect off
// CPU Clock Setting
//Note: Include asm("nop") for oscillator's stabilization period after clock setting is done
cm13=0;cm05=1;cm02=0;cm14=0;ocd0=0;ocd1=0; //On-chip oscillator selected(cm0 bit 2 and 5, cm1 bit 3 and 4, ocd bit 0 and 1)
ocd2=1; //On-chip oscillator selected(ocd bit 2)
cm16=0;cm17=0;cm06=0; //CPU时钟不分频
fra00=1;fra01=1;fra20=0;fra21=0;fra22=0;
prc0=0; //Protect on
void IO_Init()
// Port0 Setting
//Read/write data to register P0
prc2=1; //Enable write to PD0(prcr bit 2)
pd0=0x0B; //Port P0 direction register
// Port1 Setting
//Read/write data to register P1
pd1=0xCF; //Port P1 direction register
// Port2 Setting
//Read/write data to register P2
pd2=0xFA; //Port P2 direction register
p2drr=0xFA; //Port P2 drive capacity control register
p2 = 0b11001000;
// Port3 Setting
//Read/write data to register P3
pd3=0x30; //Port P3 direction register
// Port4 Setting
//Read/write data to register P4
pd4=0x00; //Port P4 direction register
pLED = 1;
// Timer RA Setting
tstart_tracr=0; //t = trapre * tra /(Fosc/2) = 250 * 40 /(40 / 2) = 500us = 0.5ms
tcstf_tracr=0; //t = trapre * tra /(Fosc/2) = 250 * 2 /(40 / 2) = 25us = 0.025ms
trapre=249; //Set timer value(for timer mode)/half period timing(for pulse output mode) to trapre and tra
tra=4; //Set timer value(for timer mode)/half period timing(for pulse output mode) to trapre and tra
tmod0_tramr=0;tmod1_tramr=0;tmod2_tramr=0;//Timer mode selected(tramr bit 0, 1 and 2)
tck0_tramr=0;tck1_tramr=0;tck2_tramr=0; //Count source f1 selected(tramr bit 4, 5 and 6)
traic=0x06; //Set interrupt priority level 0(traic)
tstart_tracr=1; //Set tstart_tracr=1 to start Timer RA counting
//Note: Timer RA does not start yet for event counter mode.
//The first active edge of external signal is used not to decrement the timer count register but to start timer RA.
//The second active edge will trigger the first decrement on timer count register.
pur0 = 0x84; /* Pull-up P1_1, P1_2 and P3_4 when using as input */
/* capture port: TRCIOA, TRCIOB, TRCIOC */
trcic = 0x00; /* Disable Timer RC Interrupt */
trcmr = 0x08; /* Stop Timer RC and set Timer RC to work in Timer Mode */
/* (Input Capture Function) */
trccr1 = 0x40; /* Select Counter Source: f32 */
trcier = 0x87; /* Enable Input Capture interrupts on channel A, B and */
/* C. Enable Timer RC Overflow interrupt */
trcior0 = 0x6E; /* Input Capture occurs at both rising and falling */
trcior1 = 0x66; /* edges on channel A, B and C */
trc = 0; /* Clear counter register and general regesters A, B */
trcgra = 0; /* and C */
trcgrb = 0;
trcgrc = 0;
trcdf = 0x05; /* Enable digital filter on channel A, B and C */
/* digital filter's sampling clock: f32 */
trcmr |= 0x80; /* Start Timer RC */
trd0ic = 0x00; /* Disable Timer RD Interrupt */
trd1ic = 0x00; /* Disable Timer RD Interrupt */
trdstr = 0x0C; /* Stop Timer RD. Count continues after compare match */
/* between TRD0 and TRDGRA0; between TRD1 and TRDGRA1 */
trdmr = 0xE0; /* TRDGRD0, TRDGRC1 and TRDGRD1 function as buffer */ /* registers of TRDGRB0, TRDGRA1 and TRDGRB1 */
trdfcr = 0x07; /* Transfer value set in buffer registers to general */ /* registers at the compare match between TRD0 and */
/* TRDGRA0. Normal-phase and Counter-phas output: */
/* Initial output 'L', Active level 'H' */
//trdoer1 = 0xff; /* Disable all PWM output */
ols0_trdfcr=1; //Normal-phase initial output "L", active level "H"(trdfcr bit 2)
ols1_trdfcr=0; //Counter-phase initial output "H", active level "L"(trdfcr bit 3)
eb0_trdoer1=1; //TRDIOB0 output disabled(trdoer1 bit 1)
ec0_trdoer1=1; //TRDIOC0 output disabled(trdoer1 bit 2)
ed0_trdoer1=1; //TRDIOD0 output disabled(trdoer1 bit 3)
ea1_trdoer1=1; //TRDIOA1 output disabled(trdoer1 bit 4)
eb1_trdoer1=1; //TRDIOB1 output disabled(trdoer1 bit 5)
ec1_trdoer1=1; //TRDIOC1 output disabled(trdoer1 bit 6)
ed1_trdoer1=1; //TRDIOD1 output disabled(trdoer1 bit 7)
trdcr0 = 0x06; /* Count source: f1 */
trdcr1 = 0x06; /* Count source: f1 */
trd0 = 30; /* Dead time: 1/fk*p = 3.6us */
trd1 = 0;
trdgra0 = 1240; /* Carrier frequency: 1/(1/fk*(m+2-p)*2) = 15kHz */
trdgrb0 = DutyCycle; /* -----------------PWM duty cycle----------------------*/
trdgra1 = DutyCycle; /* Active level width of normal-phase: 1/fk*(m-n-p+1)*2 */
trdgrb1 = DutyCycle; /* Active level width of counter-phase: 1/fk*(n+1-p)*2 */
/* fk: Frequency of count source */
/* m: Value set in the TRDGRA0 register */
/* n: Value set in the TRDGRB0 register (PWM1 output) */
/* Value set in the TRDGRA1 register (PWM1 output) */
/* Value set in the TRDGRB1 register (PWM1 output) */
/* p: Value set in the TRD0 register (dead time) */
//trdgrd0 = DutyCycle; /* Load new duty cycle value in buffer registers */
//trdgrc1 = DutyCycle; /* New duty cycle value will be load from buffer */
//trdgrd1 = DutyCycle; /* registers to general registers at the compare match */
/* between TRD0 and TRDGRA0 */
int0ic = 0x00; /* Disable INT0 Interrupt */
inten = 0x01; /* Enable INT0 input, one edge */
intf = 0x03; /* INT0 input filtered with f32 sampling */
trdoer2 = 0x80; /* Enable pulse output forced cutoff signal input INT0 */
int0ic = 0x07; /* Enable INT0 Interrupt, priority level: 7 */
//trdstr = 0x0F; /* Start timer RD */
//p2 = 0x11001000;
// ADC Setting
void ADC_Init(void)
//When using the repeat mode, use the undivided XIN clock as the CPU clock. Do not select the fOCO-F as ADC operating clock
//Note:For 8-bit resolution, when conversion finished, read AD result at AD register(00C0H).
//Note:For 10-bit resolution, when conversion finished, read AD result at AD register(00C0H,00C1H).
vcut=1;adgsel0=0;ch0=0;ch1=1;ch2=0; //Port P0 group: AN2 is selected(adcon0 bit 0-3)
md=0; //Repeat mode selected(adcon0 bit 3)
cks1=0; cks0=0; //f4 selected(adcon1 bit 4 and adcon0 bit 7)
bits=1; //8-bit mode selected(adcon1 bit 3)
smp=0; //Without sample and hold selected(adcon2 bit 0)
adst=1; //A/D conversion starts(adcon0 bit 6)
adic=0x04; //Set interrupt priority level 4(adic)
#pragma INTERRUPT /B timer_ra
void timer_ra(void) //定时器A中断子程序
ClockTick++;
if (flag_on == 1)
if (SENSINPUT!=_Sens_Input())
sens_count++;
if (sens_count == 5)
sens_count = 0;
SENSINPUT = _Sens_Input();
State_Switch(SENSINPUT);
if(motor_sts == MOTOR_OFF)
if (DutyCycle>tiaosu_ad)
CountTick++;
if (CountTick>=40)//2400ms = 620*n*25us
CountTick = 0;
DutyCycle--;
motor_sts = MOTOR_START;
if (motor_sts == MOTOR_START)//速度改变
if (DutyCycle>(tiaosu_ad-10))
DutyCycle = tiaosu_ad;
if (DutyCycle<(tiaosu_ad+10))
if(motor_sts == MOTOR_START)
if (DutyCycle<1240)
CountTick++;
CountTick = 0;
DutyCycle++;
sens_count++;
sens_count = 0;
motor_sts = MOTOR_OFF;
Timer_RD_Init();
DutyCycle = 0;
trdstr = 0;
p2 = 0b11001000;
//开机LED显示
if (flag_on == 1)
pLED = 0;
if (flag_TBU == 1)
pTBU = 0;
pTBU = 1;
pLED = 1;
if (flag_TBU == 1)
pTBU = 1;
#pragma INTERRUPT /B trc_handler
#pragma INTERRUPT /B int0_handler
p2 = 0b11001000; /* Stop motor */
trdoer1 = 0xff; /* Disable Timer RD outputs */
trdstr = 0;//traic = 0; /* Disable Timer RC Interrupt */
ErrorFlag = 1; /* Indicate over current error occured */
flag_on = 0;
DutyCycle = 1240;
Timer_RD_Init();
/* ADC interrupt service routine
#pragma INTERRUPT /B ADC_Interrupt
void ADC_Interrupt(void) //ADC中断子程序
ir_adic=0;
/*用户程序*/
if(ad_num == 0)//检测电机运行电流
ad_num = 1;
tiaosu_ad=ad;//0x00~0x3ff
tiaosu_ad = tiaosu_ad*1.22;
if(tiaosu_ad>1240)
tiaosu_ad = 0;
tiaosu_ad = 1240 - tiaosu_ad;
ch0=1;ch1=0;ch2=1;//P0_2 AN5
else//检测用户调速,速度
ad_num = 0;
dianliu_ad = ad;//0x00~0xff
ch0=0;ch1=1;ch2=0;//P0_5 AN2
if (dianliu_ad>700)//0.29V
flag_on = 0;
DutyCycle = 1240;
Timer_RD_Init();
adst = 1;
/* Starting motor
switch (state) {
case SENSER_DEG0: /* State 1: UpVn */
eb0_trdoer1=1;//HU -- p2_1 //TRDIOB0 output enabled(trdoer1 bit 1)
ec0_trdoer1=1;//TRDIOC0 output disabled(trdoer1 bit 2)
ea1_trdoer1=0;//HV -- p2_4 //TRDIOA1 output enabled(trdoer1 bit 4)
eb1_trdoer1=1;//HW -- p2_5 //TRDIOB1 output enabled(trdoer1 bit 5)
ec1_trdoer1=1;//TRDIOC1 output disabled(trdoer1 bit 6)
ed1_trdoer1=1;//TRDIOD1 output disabled(trdoer1 bit 7)
//p2_3 = 0; //LU
//p2_6 = 1; //LV
//p2_7 = 1; //LW
p2 = 0b11000000;
case SENSER_DEG60:/* State 2: UpWn*/
ea1_trdoer1=1;//HV -- p2_4 //TRDIOA1 output enabled(trdoer1 bit 4)
eb1_trdoer1=0;//HW -- p2_5 //TRDIOB1 output enabled(trdoer1 bit 5)
//p2_3 = 0; //LU
//p2_6 = 1; //LV
//p2_7 = 1; //LW
p2 = 0b11000000;
case SENSER_DEG120:/* State 3: VpWn*/
//p2_3 = 1; //LU
//p2_6 = 0; //LV
//p2_7 = 1; //LW
p2 = 0b10001000;
case SENSER_DEG180:/* State 4: VpUn*/
eb0_trdoer1=0;//HU -- p2_1 //TRDIOB0 output enabled(trdoer1 bit 1)
//p2_3 = 1; //LU
//p2_6 = 0; //LV
//p2_7 = 1; //LW
p2 = 0b10001000;
case SENSER_DEG240:/* State 5: WpUn*/
//p2_3 = 1; //LU
//p2_6 = 1; //LV
//p2_7 = 0; //LW
p2 = 0b01001000;
case SENSER_DEG300:/* State 6: WpVn*/
//p2_3 = 1; //LU
//p2_6 = 1; //LV
//p2_7 = 0; //LW
p2 = 0b01001000;
default:
/* _Sens_Input
u08 work0,work1;
work0 = p2 & 0b00000101;
work1 = p1 & 0b10000000;
return (work0 |= work1);
/* Delay n*10ms
ClockTick = 0;
while(ClockTick <= n);
void delay_ms(int ms)
while(ms--)
_asm("nop");
_asm("nop");
_asm("nop");
NOHALL_BLDCourdev_623338WBJDZ6.pdf(文件大小:65K) (原文件名:NOHALL_BLDC.pdf)
那位帮忙指点一下,谢谢! |
