回复: 34
讨论一下能承受12V/10A的直流电的最小开关的体积有多大? 是否能为 AR.Drone增加一只
头像被屏蔽
发表于 2011-3-9 19:32:24 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-9 19:44:09 | 显示全部楼层
支持一下,很需要
发表于 2011-3-9 19:55:09 | 显示全部楼层
我觉得应当考虑MOSFET做开关
发表于 2011-3-9 21:04:23 | 显示全部楼层
回复【2楼】888888888888
我觉得应当考虑mosfet做开关
我顶2楼的看法。
头像被屏蔽
 楼主| 发表于 2011-3-9 21:13:19 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-9 21:13:41 | 显示全部楼层
支持2楼的看法,mosfet体积小,控制栅极不需要多大电流,很小的开关就可以
发表于 2011-3-9 21:23:23 | 显示全部楼层
看看AR.Drone被捅一下Reset都发生了啥:
# strace /bin/factory_reset_cb
open("/dev/event0", O_RDONLY)           = 6
fstat64(6, {st_mode=S_IFCHR|0660, st_rdev=makedev(13, 64), ...}) = 0
ioctl(6, SNDCTL_TMR_TIMEBASE or TCGETS, 0xbeeffbdc) = -1 EINVAL (Invalid argumen
t)
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40
01e000
read(6, "\317\0\0\0\305\22\6\0\1\0e\0\1\0\0\0\317\0\0\0\337\22\6\0\0\0\0\0\0\0\0
\0", 4096) = 32
read(6, ====> 等在这儿. 捅一下Reset后往下运行...
read(6, "\317\0\0\0\262`\r\0\1\0e\0\0\0\0\0\317\0\0\0\304`\r\0\0\0\0\0\0\0\0\0",
4096) = 32
rt_sigaction(SIGINT, {SIG_IGN, [], 0x4000000 /* SA_??? */}, {SIG_DFL, [], 0}, 8)
= 0
rt_sigaction(SIGQUIT, {SIG_IGN, [], 0x4000000 /* SA_??? */}, {SIG_DFL, [], 0}, 8
) = 0
rt_sigprocmask(SIG_BLOCK, [CHLD], [], 8) = 0
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, chil
d_tidptr=0x4001f048) = 1059
wait4(1059, sh: /bin/reset_config.sh: not found
[{WIFEXITED(s) && WEXITSTATUS(s) == 127}], 0, NULL) = 1059
rt_sigaction(SIGINT, {SIG_DFL, [], 0x4000000 /* SA_??? */}, NULL, 8) = 0
rt_sigaction(SIGQUIT, {SIG_DFL, [], 0x4000000 /* SA_??? */}, NULL, 8) = 0
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
--- SIGCHLD (Child exited) @ 0 (0) ---
unlink("/data/accs_infos.bin")          = 0
unlink("/data/fact_accs_infos.bin")     = 0
sync()                                  = 0
rt_sigaction(SIGINT, {SIG_IGN, [], 0x4000000 /* SA_??? */}, {SIG_DFL, [], 0x4000
000 /* SA_??? */}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_IGN, [], 0x4000000 /* SA_??? */}, {SIG_DFL, [], 0x400
0000 /* SA_??? */}, 8) = 0
d_tidptr=0x4001f048) = 1063
wait4(1063, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 1063
read(6, ====> 此时AR.Drone系统开始重启, 四灯闪烁...
看来有加软开关的可能!
出0入85汤圆
发表于 2011-3-9 21:34:29 | 显示全部楼层
(原文件名:Example.jpg)
点击此处下载 ourdev_621265M07TFS.pdf(文件大小:515K) (原文件名:CSD16403Q5A.pdf)
例图,仅供参考~~
出0入85汤圆
发表于 2011-3-9 21:41:11 | 显示全部楼层
对于带感性的负载(如:导线过长,或有电机等负载),应加如下吸收及钳位电路,防止关断时MOSFET被关断尖峰电压击穿
(原文件名:Example2.jpg)
出0入85汤圆
发表于 2011-3-9 21:46:17 | 显示全部楼层
MOSFET有很多选择,只要是逻辑MOSFET,电流、耐压足够,设计好散热,一般问题不大,再有就是注意开关速度,开关过程不能太长,否则发热严重甚至爆管~~(推荐值:t(on)<100ns)
也可以用P沟道管,图可以依上图类推
头像被屏蔽
 楼主| 发表于 2011-3-9 22:42:27 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-9 23:21:36 | 显示全部楼层
有时候最简单也是最有效的
还是机械开关好
头像被屏蔽
 楼主| 发表于 2011-3-9 23:27:54 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-9 23:32:20 | 显示全部楼层
手电的尾按很小,过的电流也不小。
头像被屏蔽
 楼主| 发表于 2011-3-9 23:42:37 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2011-3-10 00:10:49 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-10 03:16:51 | 显示全部楼层
学习
发表于 2011-3-10 07:54:21 | 显示全部楼层
最好不加。对10a 电流来说,0.05欧都太大了。
出0入85汤圆
发表于 2011-3-10 08:00:17 | 显示全部楼层
回复【10楼】armok  阿莫
看看楼上这么复杂的线路?
还是找最小的机械开关算了 :)
呵呵,看起来复杂而已~
其实做起来的面积,应该可以控制在1平方厘米之内
如果这个面积还觉得大,那就看看楼下高手有什么方案了。。
发表于 2011-3-10 08:48:23 | 显示全部楼层
模型上一般都是直接用插头的
发表于 2011-3-10 09:08:43 | 显示全部楼层
回复【19楼】xj6588
模型上一般都是直接用插头的
对头,我误导大家,抱歉
头像被屏蔽
 楼主| 发表于 2011-3-10 11:00:46 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-10 12:04:38 | 显示全部楼层
对于这种大电流,模型上这么多年还是一直用的插头,这应该不是没有道理。
从这个问题看来,AR.D除马达以外耗的电也不小嘛~~~有人测过吗?
发表于 2011-3-10 13:27:51 | 显示全部楼层
用腭鱼夹连个线夹下不行吗?
出0入96汤圆
发表于 2011-3-10 15:06:52 | 显示全部楼层
有的,我回头找找图片,尺寸约14mm×14m其中拨杆部分约5mm
回头上图
出0入96汤圆
发表于 2011-3-10 15:16:01 | 显示全部楼层
开关 (原文件名:DSC070640.JPG)
这个是卧式的,还有一种是立式的,即管脚不是弯的!
头像被屏蔽
 楼主| 发表于 2011-3-10 15:45:40 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-10 15:56:33 | 显示全部楼层
用钮子开关,不过体积可不小
发表于 2011-3-10 16:46:09 | 显示全部楼层
程序里修改为定时关断或增加一个按键及一段程序较可靠
发表于 2011-3-10 18:06:31 | 显示全部楼层
要么分两路:
一路直通四个电调板, 不用加开关. 平时耗电应很小吧? (有人测过吗?)
一路加开关通主板. 我没测过电流, 但推算6小时待机的话电流应该<200mA.
头像被屏蔽
 楼主| 发表于 2011-3-10 18:08:39 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-3-10 19:04:46 | 显示全部楼层
不是有那种6个脚双联纽子开关么?一个承受5A应该可以的吧?
不过还真没接触过电流如此之大的模型
发表于 2011-4-1 10:22:45 | 显示全部楼层
【楼主位】 armok 阿莫
这个东东应该好用 (本人没用过~~)
http://item.taobao.com/item.htm?id=8769540156
好盈 速龙 Justock/Xtreme Sotck/45A/60A/120A/80A/150 电调开关
发表于 2011-4-1 11:10:32 | 显示全部楼层
10A的小开关不好找,用50n06MOS可行吧
发表于 2011-4-1 11:23:31 | 显示全部楼层
10A的小开关难找3moh 以下的.   使用寿命还难说,多用几次电阻就加大,  难免很快发热烧坏.
还是mos可靠.    几只另件占空间其实不大的.
GMT+8, 2024-7-24 10:30
