回复: 2
430制作的音频播放器程序
发表于 2011-3-4 18:26:25 | 显示全部楼层 |阅读模式
使用VS1003,这个程序还在调试中,正弦测试通过,但是播放音频没有声音,自己也在找问题,现在公开代码,大家可以一起讨论讨论.
#include "VS1003.h"
unsigned char szBeepMP3[864] =
0x4d, 0x54, 0x68, 0x64, 0x0, 0x0, 0x0, 0x6, 0x0, 0x0, 0x0, 0x1, 0x0, 0x78, 0x4d, 0x54, 0x72,
0x6b, 0x0, 0x0, 0x11, 0x33, 0x0, 0xff, 0x1, 0x47, 0x47, 0x65, 0x6e, 0x65, 0x72, 0x61, 0x74,
0x65, 0x64, 0x20, 0x62, 0x79, 0x20, 0x47, 0x4e, 0x4d, 0x49, 0x44, 0x49, 0x20, 0x32, 0x2e, 0x30,
0x20, 0x64, 0x65, 0x6d, 0x6f, 0x20, 0x76, 0x65, 0x72, 0x73, 0x69, 0x6f, 0x6e, 0x20, 0x64, 0x75,
0x72, 0x69, 0x6e, 0x67, 0x20, 0x31, 0x34, 0x20, 0x64, 0x61, 0x79, 0x73, 0x20, 0x66, 0x72, 0x65,
0x65, 0x20, 0x74, 0x65, 0x73, 0x74, 0x69, 0x6e, 0x67, 0x20, 0x70, 0x68, 0x61, 0x73, 0x65, 0xa,
0x0, 0xff, 0x1, 0x47, 0x47, 0x65, 0x6e, 0x65, 0x72, 0x61, 0x74, 0x65, 0x64, 0x20, 0x62, 0x79,
0x20, 0x47, 0x4e, 0x4d, 0x49, 0x44, 0x49, 0x20, 0x32, 0x2e, 0x30, 0x20, 0x64, 0x65, 0x6d, 0x6f,
0x20, 0x76, 0x65, 0x72, 0x73, 0x69, 0x6f, 0x6e, 0x20, 0x64, 0x75, 0x72, 0x69, 0x6e, 0x67, 0x20,
0x31, 0x34, 0x20, 0x64, 0x61, 0x79, 0x73, 0x20, 0x66, 0x72, 0x65, 0x65, 0x20, 0x74, 0x65, 0x73,
0x74, 0x69, 0x6e, 0x67, 0x20, 0x70, 0x68, 0x61, 0x73, 0x65, 0xa, 0x0, 0xff, 0x3, 0x14, 0xce,
0xa7, 0xcd, 0xfe, 0xec, 0xbf, 0xd6, 0xc6, 0xd7, 0xf7, 0x71, 0x71, 0x33, 0x31, 0x36, 0x33, 0x38,
0x32, 0x35, 0x36, 0x0, 0xff, 0x1, 0x9, 0x2e, 0x75, 0x2e, 0x2e, 0x66, 0x2e, 0x2e, 0x72, 0xa,
0x0, 0xff, 0x58, 0x4, 0x4, 0x2, 0x18, 0x8, 0x0, 0xff, 0x59, 0x2, 0x0, 0x0, 0x0, 0xff,
0x51, 0x3, 0xb, 0xbc, 0xcf, 0x0, 0xff, 0x1, 0x47, 0x47, 0x65, 0x6e, 0x65, 0x72, 0x61, 0x74,
0x0, 0xc0, 0x50, 0x0, 0xb0, 0x7, 0x7f, 0x0, 0xa, 0x40, 0x0, 0xff, 0x1, 0x47, 0x47, 0x65,
0x6e, 0x65, 0x72, 0x61, 0x74, 0x65, 0x64, 0x20, 0x62, 0x79, 0x20, 0x47, 0x4e, 0x4d, 0x49, 0x44,
0x49, 0x20, 0x32, 0x2e, 0x30, 0x20, 0x64, 0x65, 0x6d, 0x6f, 0x20, 0x76, 0x65, 0x72, 0x73, 0x69,
0x6f, 0x6e, 0x20, 0x64, 0x75, 0x72, 0x69, 0x6e, 0x67, 0x20, 0x31, 0x34, 0x20, 0x64, 0x61, 0x79,
0x73, 0x20, 0x66, 0x72, 0x65, 0x65, 0x20, 0x74, 0x65, 0x73, 0x74, 0x69, 0x6e, 0x67, 0x20, 0x70,
0x68, 0x61, 0x73, 0x65, 0xa, 0x0, 0xc1, 0x19, 0x0, 0xb1, 0x7, 0x46, 0x0, 0xa, 0x40, 0x0,
0xff, 0x1, 0x47, 0x47, 0x65, 0x6e, 0x65, 0x72, 0x61, 0x74, 0x65, 0x64, 0x20, 0x62, 0x79, 0x20,
0x47, 0x4e, 0x4d, 0x49, 0x44, 0x49, 0x20, 0x32, 0x2e, 0x30, 0x20, 0x64, 0x65, 0x6d, 0x6f, 0x20,
0x76, 0x65, 0x72, 0x73, 0x69, 0x6f, 0x6e, 0x20, 0x64, 0x75, 0x72, 0x69, 0x6e, 0x67, 0x20, 0x31,
0x34, 0x20, 0x64, 0x61, 0x79, 0x73, 0x20, 0x66, 0x72, 0x65, 0x65, 0x20, 0x74, 0x65, 0x73, 0x74,
0x69, 0x6e, 0x67, 0x20, 0x70, 0x68, 0x61, 0x73, 0x65, 0xa, 0x0, 0xc2, 0x21, 0x0, 0xb2, 0x7,
0x64, 0x0, 0xa, 0x40, 0x0, 0xff, 0x1, 0x47, 0x47, 0x65, 0x6e, 0x65, 0x72, 0x61, 0x74, 0x65,
0x64, 0x20, 0x62, 0x79, 0x20, 0x47, 0x4e, 0x4d, 0x49, 0x44, 0x49, 0x20, 0x32, 0x2e, 0x30, 0x20,
0x64, 0x65, 0x6d, 0x6f, 0x20, 0x76, 0x65, 0x72, 0x73, 0x69, 0x6f, 0x6e, 0x20, 0x64, 0x75, 0x72,
0x69, 0x6e, 0x67, 0x20, 0x31, 0x34, 0x20, 0x64, 0x61, 0x79, 0x73, 0x20, 0x66, 0x72, 0x65, 0x65,
0x20, 0x74, 0x65, 0x73, 0x74, 0x69, 0x6e, 0x67, 0x20, 0x70, 0x68, 0x61, 0x73, 0x65, 0xa, 0x0,
0xc3, 0x3, 0x0, 0xb3, 0x7, 0x78, 0x0, 0xa, 0x40, 0x0, 0xff, 0x1, 0x47, 0x47, 0x65, 0x6e,
0x65, 0x72, 0x61, 0x74, 0x65, 0x64, 0x20, 0x62, 0x79, 0x20, 0x47, 0x4e, 0x4d, 0x49, 0x44, 0x49,
0x20, 0x32, 0x2e, 0x30, 0x20, 0x64, 0x65, 0x6d, 0x6f, 0x20, 0x76, 0x65, 0x72, 0x73, 0x69, 0x6f,
0x6e, 0x20, 0x64, 0x75, 0x72, 0x69, 0x6e, 0x67, 0x20, 0x31, 0x34, 0x20, 0x64, 0x61, 0x79, 0x73,
0x20, 0x66, 0x72, 0x65, 0x65, 0x20, 0x74, 0x65, 0x73, 0x74, 0x69, 0x6e, 0x67, 0x20, 0x70, 0x68,
0x61, 0x73, 0x65, 0xa, 0x0, 0xc4, 0x50, 0x0, 0xb4, 0x7, 0x3c, 0x0, 0xff, 0x1, 0x47, 0x47,
0x65, 0x6e, 0x65, 0x72, 0x61, 0x74, 0x65, 0x64, 0x20, 0x62, 0x79, 0x20, 0x47, 0x4e, 0x4d, 0x49,
0x44, 0x49, 0x20, 0x32, 0x2e, 0x30, 0x20, 0x64, 0x65, 0x6d, 0x6f, 0x20, 0x76, 0x65, 0x72, 0x73,
0x69, 0x6f, 0x6e, 0x20, 0x64, 0x75, 0x72, 0x69, 0x6e, 0x67, 0x20, 0x31, 0x34, 0x20, 0x64, 0x61,
0x79, 0x73, 0x20, 0x66, 0x72, 0x65, 0x65, 0x20, 0x74, 0x65, 0x73, 0x74, 0x69, 0x6e, 0x67, 0x20,
0x70, 0x68, 0x61, 0x73, 0x65, 0xa, 0x0, 0xc5, 0x47, 0x0, 0xb5, 0x7, 0x46, 0x0, 0xa, 0x40,
void Waitms(unsigned int i)
    unsigned int ct;
    while(i--)
        for(ct=0; ct <100 ;ct++);
#define COUNTER 8000
    unsigned int ct=i;
    while(ct--)
        CCR0  = COUNTER;
        TACTL = TASSEL1+TACLR;              // ACLK, upmode
        TACTL |= MC0;
        while(TAIFG == 0 ) ;
        TACTL = MC0 | MC1;
void SerialWrite(unsigned char Data)
    unsigned char   i;
    for(i=0; i<8 ;i++)
        P1DIR |= REQ;
        P1OUT |= REQ;
        P1DIR &= ~REQ;
        while(! ( P1IN & REQ ) ) ;
        CLR(SCLK);
        if(Data & 0x80)
            SET(SI);
            CLR(SI);
        Data <<=  1;
        SET(SCLK);
unsigned char SerialRead()
    unsigned char   i;
    unsigned char   res=0x00;
    for(i=0; i<8 ;i++)
        SET(SCLK);
        _NOP();
        CLR(SCLK);
        res <<=1;
        if( P1IN & SO )
            res |= 0x01;
    return res;
void SCIWrite(unsigned char addr, unsigned int Data)
    SET(DCS);
    CLR(CS);
    SerialWrite(SI_WRITE);
    SerialWrite(addr);
    SerialWrite(Data >> 8);
    SerialWrite(Data);
    SET(CS);
    CLR(DCS);
unsigned int SCIRead(unsigned char addr)
    unsigned char i;
    unsigned int r;
    SET(DCS);
    CLR(CS);
    SerialWrite(SI_READ);
    SerialWrite(addr);
    r = SerialRead() << 8;
    r += SerialRead();
    SET(CS);
    CLR(DCS);
    for( i=20 ; i>0; i--);
    return r;
void SetVolume(unsigned char l, unsigned char r)
    SCIWrite(SCI_VOL, ((l << 8) + r));
void SetBass(unsigned char amp, unsigned char freq)
    SCIWrite(SCI_BASS, ((amp & 0x0f) << 4) | (freq & 0x0f));
unsigned char Version()
    return (SCIRead(SCI_STATUS) >> 4) & 0x7;
void PlayBeep()
    unsigned int i;
    SET(CS);
    CLR(DCS);
    for( i=0; i< 864 ;i++)
        SerialWrite(szBeepMP3);
    CLR(CS);
    SET(DCS);
    for(i=0; i<30;i++)
        SerialWrite(0x00);
void InitVS1003()
    SET(SI|SCLK|DCS|CS);
    CLR(REQ|SO);
    CLR(RST);
    _NOP();
    _NOP();
    SET(RST);
    while(! ( P1IN & REQ ) ) ; // Wait untill the REQ is high
    SCIWrite(SCI_MODE, SM_SDINEW | SM_RESET);
    SetBass(0, 10);                     // 0db, 100Hz
    SCIWrite(SCI_CLOCKF, 0x9800);
    SetVolume(0, 0);
void InitPort()
    P1DIR |= (RST|SI|SCLK|CS|DCS);
    P1DIR &=~(REQ|SO);
void SineTest(void)
    //向vs1003发送正弦测试命令:0x53 0xef 0x6e n 0x00 0x00 0x00 0x00
    //其中n = 0x24, 设定vs1003所产生的正弦波的频率值,具体计算方法见vs1003的datasheet
    SET(CS);
    CLR(DCS);
    SCIWrite(0x00,0x0820);
    SerialWrite(0x53);
    SerialWrite(0xef);
    SerialWrite(0x6e);
    SerialWrite(0x24);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    while(!(P1IN & REQ ));
    CLR(CS);
    SET(DCS);
    Waitms(500);
    //退出正弦测试
    SET(CS);
    CLR(DCS);
    SerialWrite(0x45);
    SerialWrite(0x78);
    SerialWrite(0x69);
    SerialWrite(0x74);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    CLR(CS);
    SET(DCS);
    //再次进入正弦测试并设置n值为0x44,即将正弦波的频率设置为另外的值
    SET(CS);
    CLR(DCS);
    SerialWrite(0x53);
    SerialWrite(0xef);
    SerialWrite(0x6e);
    SerialWrite(0x44);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    CLR(CS);
    SET(DCS);
    Waitms(500);
    //退出正弦测试
    SET(CS);
    CLR(DCS);
    SerialWrite(0x45);
    SerialWrite(0x78);
    SerialWrite(0x69);
    SerialWrite(0x74);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    SerialWrite(0x00);
    CLR(CS);
    SET(DCS);
void play (unsigned char dat){
   SerialWrite(dat);
发表于 2011-3-4 20:20:25 | 显示全部楼层
mark 一下,帮顶
发表于 2011-3-10 14:58:28 | 显示全部楼层
mark 一下..嘿嘿
GMT+8, 2024-7-28 15:18
