大家好,最近我把rt-thread-0.4.0移植到at91sam9260芯片上,并成功跑起来了,但是在这个过程中遇到了一些问题,请各位指教。
目前开启了三个测试线程,情况如下:
线程一:点亮led灯
线程二:打印串口信息
线程三:获取按键中断发的邮箱信号,并打印串口信息
代码如下:
static rt_thread_t key_tid1 = RT_NULL;
/* 邮箱控制块 */
static struct rt_mailbox mb;
/* 用于放邮件的内存池 */
static char mb_pool[16];
static char mb_str1[] = "PC15";
static char mb_str2[] = "PC7";
/* 线程1入口 */
static void key_thread_entry(void* parameter)
unsigned char* str;
while (1)
rt_kprintf("thread1: try to recv a mail\n");
/* 从邮箱中收取邮件 */
if (rt_mb_recv(&mb, (rt_uint32_t*)&str, RT_WAITING_FOREVER) == RT_EOK)
rt_kprintf("KEY pressed on PC15:%s\n", str);
/* 延时10个OS Tick */
//rt_thread_delay(10);
void rt_pioc_handler(int vector)
rt_uint32_t status;
status = at91_sys_read(AT91_PIOC+0x4c);
if (status & (1<<15))
//rt_kprintf("KEY pressed on PC15\n");
rt_mb_send(&mb, (rt_uint32_t)&mb_str1[0]);
if (status & (1<<7))
//rt_kprintf("KEY pressed on PC7\n");
rt_mb_send(&mb, (rt_uint32_t)&mb_str2[0]);
void key_init(void)
at91_sys_write(AT91_PIOC, (1<<15)|(1<<7));
at91_sys_write(AT91_PIOC+0x14, (1<<15)|(1<<7));
at91_sys_write(AT91_PIOC+0x20, (1<<15)|(1<<7));
at91_sys_write(AT91_PIOC+0x40, (1<<15)|(1<<7));
at91_sys_write(AT91_PIOC+0x64, (1<<15)|(1<<7));
/* 初始化一个mailbox */
rt_mb_init(&mb,
"key_mb", /* 名称是mbt */
&mb_pool[0], /* 邮箱用到的内存池是mb_pool */
sizeof(mb_pool)/4, /* 大小是mb_pool大小除以4,因为一封邮件的大小是4字节 */
RT_IPC_FLAG_FIFO); /* 采用FIFO方式进行线程等待 */
/* 创建线程1 */
key_tid1 = rt_thread_create("key",
key_thread_entry, RT_NULL, /* 线程入口是thread1_entry, 入口参数是RT_NULL */
512, 20, 10);
if (key_tid1 != RT_NULL)
rt_thread_startup(key_tid1);
rt_kprintf("start thread key failed\n");
rt_hw_interrupt_install(AT91SAM9260_ID_PIOC, rt_pioc_handler, RT_NULL);
rt_hw_interrupt_umask(AT91SAM9260_ID_PIOC);
void rt_led_thread_entry(void* parameter)
rt_uint8_t cnt = 0;
led_init();
/* light on leds for one second */
rt_thread_delay(40);
cnt++;
if (cnt&0x01)
led_on(1);
led_off(1);
if (cnt&0x02)
led_on(2);
led_off(2);
if (cnt&0x04)
led_on(3);
led_off(3);
void rt_test_thread_entry(void *parameter)
rt_kprintf("test thread enter\n");
rt_thread_delay(400);
int rt_application_init()
rt_thread_t led_thread;
rt_thread_t test_thread;
#if (RT_THREAD_PRIORITY_MAX == 32)
led_thread = rt_thread_create("led",
rt_led_thread_entry, RT_NULL,
512, 20, 20);
test_thread = rt_thread_create("test",
rt_test_thread_entry, RT_NULL,
512, 24, 20);
#else
512, 200, 20);
512, 240, 20);
if(led_thread != RT_NULL)
rt_thread_startup(led_thread);
if(test_thread != RT_NULL)
rt_thread_startup(test_thread);
key_init();
return 0;
目前遇到的问题是在频繁按键后,中断会消失,即按键不会进入中断,正常情况下在按键过程中,在按键信号的上升沿和下降沿都会产生中断。
串口打印信息如下:
finsh>>test thread enter
KEY pressed on PC15:PC15
test thread enter
test thread enter ------------> 之后无论怎样按键都不会进入中断处理函数,但是其他的功能都正常,
test thread enter 不过有个奇怪的现象,在finsh中多次执行list_thread()命令会导致idle线程栈溢出死机
test thread enter
test thread enter
test thread enter
test thread enter
除此之外,不进行任何按键动作,只是在finsh终端中执行list_thread()命令,会出现idle线程栈溢出的警告信息,多次执行后会出现栈溢出死机。
串口打印信息如下:
finsh>>
finsh>>list_thread()
thread pri status sp stack size max used left tick error
tidle 0xff ready 0x0000007c 0x00000100 0x000000f4 0x0000001e 000
timer 0x08 suspend 0x00000094 0x00000200 0x000000e4 0x00000008 000
tshell 0x14 ready 0x000001cc 0x00001000 0x0000024c 0x00000009 -04
key 0x14 suspend 0x000000ac 0x00000200 0x000000ac 0x00000008 000
test 0xf0 suspend 0x000000a4 0x00000200 0x000000a4 0x00000014 000
led 0xc8 suspend 0x000000ac 0x00000200 0x000000ac 0x00000014 000
0, 0x00000000
tidle 0xff ready 0x0000007c 0x00000100 0x000000f4 0x0000000b 000
tshell 0x14 ready 0x000000a4 0x00001000 0x0000024c 0x00000004 -04
0, 0x00000000
tidle 0xff ready 0x00000054 0x00000100 0x000000f4 0x00000018 000
tshell 0x14 ready 0x000000a4 0x00001000 0x0000024c 0x00000009 -04
led 0xc8 ready 0x000000ac 0x00000200 0x000000ac 0x00000014 -02
0, 0x00000000
tidle 0xff ready 0x0000007c 0x00000100 0x000000f4 0x0000001c 000
tshell 0x14 ready 0x000000a4 0x00001000 0x0000024c 0x00000002 -04
0, 0x00000000
tidle 0xff ready 0x00000070 0x00000100 0x000000f4 0x00000010 000
tshell 0x14 ready 0x000000a4 0x00001000 0x0000024c 0x00000006 -04
0, 0x00000000
tidle 0xff ready 0x0000006c 0x00000100 0x000000f4 0x00000007 000
0, 0x00000000
finsh>>list_thread()warning: tidle stack is close to end of stack address.
thread:tidle stack overflow
tidle 0xff ready 0x00000124 0x00000100 0x00000100 0x0000001f 000
tshell 0x14 suspend 0x000000a4 0x00001000 0x0000024c 0x00000006 000
led 0xc8 suspend 0x000000ac 0x00000200 0x00000170 0x00000014 000
请教一下,这些问题是什么原因导致?
谢谢! |
