发表于 2011-4-19 16:40:56
【42楼】 RENMA
17.4 SYNCHRONIZING MULTIPLE ADC10D1000/1500S IN A SYSTEM
The ADC10D1000/1500 has two features to assist the user with synchronizing multiple ADCs in a system; AutoSync and
DCLK Reset. The AutoSync feature is new and designates
one ADC10D1000/1500 as the Master ADC and other
ADC10D1000/1500s in the system as Slave ADCs. The
DCLK Reset feature performs the same function as the AutoSync
feature, but is the first generation solution to synchronizing
multiple ADCs in a system; it is disabled by default. For
the application in which there are multiple Master and Slave
ADC10D1000/1500s in a system, AutoSync may be used to
synchronize the Slave ADC10D1000/1500(s) to each respective
Master ADC10D1000/1500 and the DCLK Reset may be
used to synchronize the Master ADC10D1000/1500s to each
other.
17.4.1 AutoSync Feature
AutoSync is a new feature which continuously synchronizes
the outputs of multiple ADC10D1000/1500s in a system. It
may be used to synchronize the DCLK and data outputs of
one or more Slave ADC10D1000/1500s to one Master ADC10D1000/
1500. Several advantages of this feature include:
no special synchronization pulse required, any upset in synchronization
is recovered upon the next DCLK cycle, and the
Master/Slave ADC10D1000/1500s may be arranged as a binary
tree so that any upset will quickly propagate out of the
system.
An example system is shown below in Figure 20 which consists
of one Master ADC and two Slave ADCs. For simplicity,
only one DCLK is shown; in reality, there is DCLKI and
DCLKQ, but they are always in phase with one another.
In order to synchronize the DCLK (and Data) outputs of multiple
ADCs, the DCLKs must transition at the same time, as
well as be in phase with one another. The DCLK at each ADC
is generated from the CLK after some latency, plus tOD minus
tAD. Therefore, in order for the DCLKs to transition at the same
time, the CLK signal must reach each ADC at the same time.
To tune out any differences in the CLK path to each ADC, the
tAD adjust feature may be used. However, using the tAD adjust
feature will also affect when the DCLK is produced at the output.
If the device is in Demux Mode, then there are four
possible phases which each DCLK may be generated on because
the typical CLK = 1GHz and DCLK = 250 MHz for this
case. The RCLK signal controls the phase of the DCLK, so
that each Slave DCLK is on the same phase as the Master
DCLK.
The AutoSync feature may only be used via the Control Registers.
(原文件名:1.JPG) |
