参考chrysler的自动对刀帖子和agree前辈的指点,试着改了一下对刀代码,目前已经可以扣除对刀器厚度
原贴地址
http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=4353898&bbs_page_no=1&search_mode=1&search_text=对刀&bbs_id=1027
改动后代码
'Rem Probe Down by PEU (Based on Erniebro Work)
FeedCurrent = GetOemDRO(818) 'Get the current settings
ZCurrent = GetDro(2)
Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "F100" 'slow feed rate to 100 MM/MIN
GageH = GetOEMDRO (1002)
ZCurrent = GetOemDro(802)
GageH = GetUserDRO(1152)
ZNew = ZCurrent - 30 'probe down 20 mm
Code "G31 Z" &ZNew
While IsMoving()
Wend
Call SetDro (2,XXXXX) 'XXXXX为对刀器厚度,请各位自行设置
'FinalMove = GageH * 1 '原代码中这两句保留会出现错误
'Code "G0 Z" &FinalMove
Code "G0 Z" &20 '20可改为其他高度,比如5 10 之类,如果Z轴行程有限,可以用比较小的数值
Code "F" &FeedCurrent 'restore starting feed rate |
