由于库函数的EEPROM写函数占据太长的系统时间,幽游梦蝶重写了EEPROM,但怕有别的问题,请大家来挑挑刺,谢谢!
PS:
早几天我在另外的帖子说把我的程序贴出来的:)
1> EEPROM.h:
#ifndef _EEPROM_H_
#define _EEPROM_H_
#ifdef _EEPROM_C_
#define EXTERN
#else
#define EXTERN extern
typedef enum
EEPROM_WRITE_STAT_EMPTY, // no data in the EEPROM Write buf
EEPROM_WRITE_STAT_FILL, // have data in the EEPROM Write but not full
EEPROM_WRITE_STAT_FULL // EEPROM Write buf full
}EEPROM_WRITE_STAT;
typedef enum
EEPROM_SERVER_STAT_NULL,
EEPROM_SERVER_STAT_WRITING
}EEPROM_SERVER_STAT;
typedef struct
unsigned int wAddress;
unsigned char bVal;
}S_EEPROM_POSITION;
#define EEPROM_WRITE_BUF_SIZE 16
EXTERN S_EEPROM_POSITION _sEEPROMBuf[EEPROM_WRITE_BUF_SIZE];
EXTERN volatile EEPROM_WRITE_STAT _eEEPROMWriteStat;
EXTERN volatile U8 _bEEPROMWritePoint;
EXTERN volatile U8 _bEEPROMReadPoint;
EXTERN volatile EEPROM_SERVER_STAT _eEEPROMServerStat;
EXTERN U8 WriteDataToEEPROM(U16 wAddress, U8 bVal);
EXTERN U8 ReadDataFromEEPROM(U16 wAddress, U8 *pbVal);
EXTERN void EEPROMServer(void);
EXTERN void InitEEPROM(void);
#undef EXTERN
2> EEPROM.c
#define _EEPROM_C_
#include "DrvHead.h"
#pragma interrupt_handler EE_READY:iv_EE_READY
void EE_READY(void)
if(_eEEPROMWriteStat != EEPROM_WRITE_STAT_EMPTY)
EEAR = _sEEPROMBuf[_bEEPROMReadPoint].wAddress;
EEDR = _sEEPROMBuf[_bEEPROMReadPoint].bVal;
EECR |= BIT(EEMWE);
EECR |= BIT(EEWE);
_eEEPROMServerStat = EEPROM_SERVER_STAT_WRITING;
_bEEPROMReadPoint++;
if(_bEEPROMReadPoint >= EEPROM_WRITE_BUF_SIZE)
_bEEPROMReadPoint = 0;
if(_bEEPROMReadPoint == _bEEPROMWritePoint)
_eEEPROMWriteStat = EEPROM_WRITE_STAT_EMPTY;
_eEEPROMWriteStat = EEPROM_WRITE_STAT_FILL;
EECR &= ~BIT(EERIE);
_eEEPROMServerStat = EEPROM_SERVER_STAT_NULL;
if(_eEEPROMWriteStat == EEPROM_WRITE_STAT_FULL)
return RET_BUSY;
_sEEPROMBuf[_bEEPROMWritePoint].wAddress = wAddress;
_sEEPROMBuf[_bEEPROMWritePoint].bVal = bVal;
_bEEPROMWritePoint++;
if(_bEEPROMWritePoint >= EEPROM_WRITE_BUF_SIZE)
_bEEPROMWritePoint = 0;
if(_bEEPROMWritePoint == _bEEPROMReadPoint)
_eEEPROMWriteStat = EEPROM_WRITE_STAT_FULL;
return RET_SUCCESS;
if(EECR & BIT(EEWE))
return RET_BUSY;
EEAR = wAddress;
EECR |= BIT(EERE);
*pbVal = EEDR;
return RET_SUCCESS;
if( (_eEEPROMServerStat == EEPROM_SERVER_STAT_NULL)
&& (_eEEPROMWriteStat != EEPROM_WRITE_STAT_EMPTY) )
EECR |= BIT(EERIE);
EECR = 0x00;
-----此内容被Louis Bright于2005-06-20,08:53:09编辑过 |
