发表于 2011-2-9 21:24:52
贴段原理吧:
The diagram illustrates an array of rings threaded on a grid of wires,
X1 to X4 and Y1 to Y4. If a sufficiently large current is passed along the wire X3,
then a magnetic field is generated around the wire and all the cores threaded on the wire in the X3 row will become magnetised.
They will remain magnetised when the current is switched off.
Similarly, if a large current is passed along the wire Y3, all the Y3 cores will become magnetised.
If a small current is passed along the wire X3, the field produced is not sufficient to have any effect on the cores.
For a given arrangement, there is a particular current which is just sufficient to magnetise the cores.
Now, here comes the clever bit.
If a current equal to half this magnetising current is passed along X3 and another half current is passed along Y3,
then only the red core at the intersection will receive the full magnetic field.
The red core will be magnetised but all the other cores will be unaffected.
If the direction of the currents in X3 and Y3 is now reversed,
then the direction of magnetisation of the red core will be reversed, but again, no other cores will be affected.
So far, we have been able to select a particular core and set it into one of two possible states,
equivalent to "0" and "1".
It doesn't matter which direction of magnetisation we chose to represent a "1"
but we do need to be able to detect which of the two possible states a particular core is in. How can we do this?
The diagram shows a third wire (the sense wire) threaded through all cores.
Now, when the core changes its magnetic state, the magnetic field inside the ring suddenly flips direction.
This moving magnetic field generates a small electrical current in the sense wire,
which can be amplified and detected.
So, if we write a "1" to a particular core and this core is in the "0" state,
the the field will flip and a pulse will be detected in the sensing wire.
On the other hand, if the core was in the "1" state,
writing a "1" would have no effect and no pulse would appear on the sense winding.
In this way, the state of a particular core can be detected.
Note that the act of reading core memory is destructive.
In normal use, the value read would have to be stored and then the core would have to be remagnetised in its original state.
Although the action of reading is destructive, once written,
core memory will retain its contents indefinitely (or for a very long time).
It does not require any power to maintain its contents. |
