下面是阿莫站长早先发的一个帖子“建立一个属于自己的AVR的RTOS”里的一个例程,使用时间片轮转调度的
#include <avr/io.h>
#include <avr/Interrupt.h>
#include <avr/signal.h>
unsigned char Stack[400];
register unsigned char OSRdyTbl asm("r2"); //任务运行就绪表
register unsigned char OSTaskRunningPrio asm("r3"); //正在运行的任务
#define OS_TASKS 3 //设定运行任务的数量
struct TaskCtrBlock
unsigned int OSTaskStackTop; //保存任务的堆栈顶
unsigned int OSWaitTick; //任务延时时钟
} TCB[OS_TASKS+1];
//防止被编译器占用
register unsigned char tempR4 asm("r4");
register unsigned char tempR5 asm("r5");
register unsigned char tempR6 asm("r6");
register unsigned char tempR7 asm("r7");
register unsigned char tempR8 asm("r8");
register unsigned char tempR9 asm("r9");
register unsigned char tempR10 asm("r10");
register unsigned char tempR11 asm("r11");
register unsigned char tempR12 asm("r12");
register unsigned char tempR13 asm("r13");
register unsigned char tempR14 asm("r14");
register unsigned char tempR15 asm("r15");
register unsigned char tempR16 asm("r16");
register unsigned char tempR16 asm("r17");
//建立任务
void OSTaskCreate(void (*Task)(void),unsigned char *Stack,unsigned char TaskID)
unsigned char i;
*Stack--=(unsigned int)Task>>8; //将任务的地址高位压入堆栈,
*Stack--=(unsigned int)Task; //将任务的地址低位压入堆栈,
*Stack--=0x00; //R1 __zero_reg__
*Stack--=0x00; //R0 __tmp_reg__
*Stack--=0x80;
//SREG 在任务中,开启全局中断
for(i=0;i<14;i++) //在 avr-libc 中的 FAQ中的 What registers are used by the C compiler?
*Stack--=i; //描述了寄存器的作用
TCB[TaskID].OSTaskStackTop=(unsigned int)Stack; //将人工堆栈的栈顶,保存到堆栈的数组中
OSRdyTbl|=0x01<<TaskID; //任务就绪表已经准备好
//开始任务调度,从最低优先级的任务的开始
void OSStartTask()
OSTaskRunningPrio=OS_TASKS;
SP=TCB[OS_TASKS].OSTaskStackTop+17;
__asm__ __volatile__( "reti" "
\t" );
//进行任务调度
void OSSched(void)
// 根据中断时保存寄存器的次序入栈,模拟一次中断后,入栈的情况
__asm__ __volatile__("PUSH __zero_reg__
\t"); //R1
__asm__ __volatile__("PUSH __tmp_reg__
\t"); //R0
__asm__ __volatile__("IN __tmp_reg__,__SREG__
\t"); //保存状态寄存器SREG
\t");
__asm__ __volatile__("CLR __zero_reg__
\t"); //R0重新清零
__asm__ __volatile__("PUSH R18
\t");
__asm__ __volatile__("PUSH R19
\t");
__asm__ __volatile__("PUSH R20
\t");
__asm__ __volatile__("PUSH R21
\t");
__asm__ __volatile__("PUSH R22
\t");
__asm__ __volatile__("PUSH R23
\t");
__asm__ __volatile__("PUSH R24
\t");
__asm__ __volatile__("PUSH R25
\t");
__asm__ __volatile__("PUSH R26
\t");
__asm__ __volatile__("PUSH R27
\t");
__asm__ __volatile__("PUSH R30
\t");
__asm__ __volatile__("PUSH R31
\t");
__asm__ __volatile__("Int_OSSched:
\t"); //当中断要求调度,直接进入这里
__asm__ __volatile__("PUSH R28
\t"); //R28与R29用于建立在堆栈上的指针
__asm__ __volatile__("PUSH R29
\t"); //入栈完成
TCB[OSTaskRunningPrio].OSTaskStackTop=SP; //将正在运行的任务的堆栈底保存
if(++OSTaskRunningPrio>=OS_TASKS) //轮流运行各个任务,没有优先级
OSTaskRunningPrio=0;
//cli(); //保护堆栈转换
SP=TCB[OSTaskRunningPrio].OSTaskStackTop;
//sei();
//根据中断时的出栈次序
__asm__ __volatile__("POP R29
\t");
__asm__ __volatile__("POP R28
\t");
__asm__ __volatile__("POP R31
\t");
__asm__ __volatile__("POP R30
\t");
__asm__ __volatile__("POP R27
\t");
__asm__ __volatile__("POP R26
\t");
__asm__ __volatile__("POP R25
\t");
__asm__ __volatile__("POP R24
\t");
__asm__ __volatile__("POP R23
\t");
__asm__ __volatile__("POP R22
\t");
__asm__ __volatile__("POP R21
\t");
__asm__ __volatile__("POP R20
\t");
__asm__ __volatile__("POP R19
\t");
__asm__ __volatile__("POP R18
\t");
__asm__ __volatile__("POP __tmp_reg__
\t"); //SERG 出栈并恢复
__asm__ __volatile__("OUT __SREG__,__tmp_reg__
\t"); //
\t"); //R0 出栈
__asm__ __volatile__("POP __zero_reg__
\t"); //R1 出栈
__asm__ __volatile__("RETI
\t"); //返回并开中断
//中断时出栈完成
void IntSwitch(void)
\t"); //去除因调用子程序而入栈的PC
\t");
__asm__ __volatile__("RJMP Int_OSSched
\t"); //重新调度
void TCN0Init(void) // 计时器0
TCCR0 = 0;
TCCR0 |= (1<<CS02); // 256预分频
TIMSK |= (1<<TOIE0); // T0溢出中断允许
TCNT0 = 100; // 置计数起始值
SIGNAL(SIG_OVERFLOW0)
TCNT0=100;
IntSwitch(); //任务调度
void Task0()
unsigned int j=0;
PORTB=j++;
//OSTimeDly(50);
void Task1()
unsigned int j=0;
PORTC=j++;
//OSTimeDly(5);
void Task2()
unsigned int j=0;
PORTD=j++;
//OSTimeDly(5);
void TaskScheduler()
OSSched(); //反复进行调度
int main(void)
TCN0Init();
OSRdyTbl=0;
OSTaskCreate(Task0,&Stack[99],0);
OSTaskCreate(Task1,&Stack[199],1);
OSTaskCreate(Task2,&Stack[299],2);
OSTaskCreate(TaskScheduler,&Stack[399],OS_TASKS);
OSStartTask();
我有两个疑问:
<1> OSSched()函数里一开始把一堆通用寄存器PUSH,转换完任务以后又一个一个地POP,这有什么用?这些寄存器里好像没有什么重要的东西呀
<2> IntSwitch()函数里前两句用汇编嵌入的两个"POP"有什么作用?(注释说“去除因调用子程序而入栈的PC ”,我看不太懂)
先行谢过啦~ |
